3 Liter Turbo Registry
Old 11-30-2008, 12:59 PM
Tom M'Guinn
Tom M'Guinn's Avatar
Default Official 3 Liter 944/968 Turbo Registry (Congrats to Darwin!)
This is the place to post about your 3 liter (or otherwise big) 944/968 turbo motor, and to keep a list of the running motors/projects as a reference for aspiring 3 liter builders. Feel free to ask questions and include details about your motor in your post -- with extra points for pictures . If you have a running motor or project for the lists below, be sure to post or PM me a one-line entry I can copy into the list below.
Back by popular demand (well, demand anyway), below is the full list of running motors, starting in 2008, with the latest additions added and hopefully growing at the bottom:
00. ModdedEverything951S, 3.1, Darton Wet, 106, 88, Wossner/Pauter, 2.7, TecGT, VR Cam, VR5
1. Duke, 3.0, Alusil, 104.5, 88, mod 968 variocam, Link G3+, Garrett GT3582R, builder: Duke 514/450 at wheels
2. Diver944, 3.2, Nikasil, 108, 88, JE, 2.7, Vittese, stock, Garret hybrid, 393/480
3. John Torgersen, 3.0,Steel, 104, 88, JE, 2.7, Motec M4 Pro,K27/8, 383HP@15
4. John Torgersen, 3.0,Steel, 104, 88, JE, 2.5, LR/Stg3 MAF, T04 Hybrid, 366HP@15
5. Targa72e, 3.0, Alusil, 104, 968 mod, 968 head, Motronic, T04E, cam and hp n/a
6. Mike O, 3.0, Alusil, 104.5, 88, HMR, 16v, TECgt, HMR turbo, cam and HP n/a
7. SoloRacer, 3.0, 16V, Motec
8. Kasturbo, 3.0, Alusil, 104.5, 88, Mahle/Andial, 2.7, LRS75, VR turbo, Webcam, HP n/a
9. George D 3.1, 105 Nicom, 88.6, Custom Ross Racing, TECGT, 951 cam, 540hp@23psi
10. Arto951 3.0, Alusil, 104.5, 88, Mahle/Andial, 2.7, Holset Turbo, Tatech EMS, dBilas cam
11. Pete96zhn, 3.0 darton mid, Wossner pistons, 944 head, VR EMS, Holset turbo, Standard cam
12. Phlip, 3.0 Darton Dry, 105.5JE pistons, S2 16v head, Autronic SM2 EMS, T3 turbo (R.I.P. 3/15/09)
13. Ski, 2.8, Alusil, 100.5 Ski/Mahle pistons, 88 stroke, 951 head, LR EMS
14. TurboTommy. 3.0, Alusil, 968 mod pistons, 2.7 head, VR EMS, VR turbo, JME cam
15. Weston D., 3.0, Alusil, 968 pistons, 951 head, LR EMS, rest n/a
16. Jason@paragon, factory 968 turbo. Nuff said.
17. Boost Feen, 3.0, Alusil, Tom C/Arias Pistons, 2.7 head, Motronic, LR61 turbo, 951 cam, hp n/a
18. Joel8005 3.2, bore material n/a, JE pistons, 2.7 head, LR EMS, turbo/cam/hp n/a
19. David Floyd, 106mm SFR bores, JE pistons, 951 head, VR EMS, VR4 turbo, cam and hp n/a
20. Jason Judd, 3.0 (?), Mahle pistons, Carillo rods, head n/a, Lindsey Super 75, Autronic
21. ShApe, 3.0, Alusil?, Pauter, JE, LR solid lifter conversion, 2.7 head, Web cam, HP n/a
22. CMF, 3.0, Alusil, PO rods, 88, 951 head mod, VEMS 3.3, webcam, Garrett GT3582, 421.8hp@16psi
23. Corleone, 3.0, Darton MID, JE, 951 head, Link G2, JME solid cam, 449hp/560hp@1/1.25 bar
24. Turbo-Uli, 3.0, 104 Alusil, 88 crank, 16v head, rest n/a
25. Nick_968, 3.0, Alusil, 104, Mahle/Andial, 2.7 head, Motec, VR5 turbo, JME cam, 370/355 @?
26. jm964cab 3.0, Alusil?, JE pistons, KKK28/9, Mafterbuner, APE MAF, cam and hp n/a
27. zagaone, 3.4, 16v. 108mm bore/93mm stroke; electromotive; 493rwhp/486tq @1bar.
28. 968TurboS, 3.0 Nikasil block, Carillo rods, JME 2.7 head, GT3076R
29. Josh B, 3.0, 8V, Mahle, VR EMS, Wasted Spark, VR5Turbo, Pauter, Webcam, LR Solid cam
30. Miles968, 3.0, 16V, Mahle Pistons, PH Custom Rods, PH K29 Turbo
31. tone3721, 3.0, Alusil, 104mm, 88, mahle, 2.7, LR, stock(951), VR3
32. 420WHP944, 2.8, 8V, Carillo Rods, Mahle Pistons, Kokeln Club Turbo, MAP Sensor, 422bhp @1.2 bar
33. dand86951, 104.75 alusil, 88 crank, JE coated, 2.7 head, TEC3, K27/8, Carillo Rods
34. tomjshore, holy grail motor -- factory 3 liter turbo
35. Thom 104.5 M/Andial, 88mm, '89 8v, carrillos, GTX3076R, PT Vi-Pec/J&S, SFR I/C, LR 3", KEP2/930
36. A.Anon, 3.2, Nikasil 108 bore, 88 crank, JE pistons, Carrillos, 2.7 8v, VR Maf, 3" exhaust, SPS turbo
37. Fortysixandtwo, 3.0, 968 head, 968 block, Tec-3, Under Pressure Performance turbo
38. apitts73, Lindsay built 3L with everything
39. mikes3.0cabturbo 3.0 16v alusil, 104.5 wossner pistons/wossner rods, 60-1, 4424EMS2.
40. Tom M'Guinn, 3.0, Alusil, 104.5, 88, Mahle/Andial, 2.7, VR, Gomes, VR5, 498/503 (35k miles and going as of 9/20)
41. Urs, 3.0, Carillo, Walh/Mahle, 7mm valve guides, K27
42. JET951, S2 engine, wossner 8.0:1 CR 16V, SFR intake, vitesse stage 5
43. ninfiveone, 3.0 MID, Wossner Pistons, Haltech, VR 8V Sledge head, cam, 415 rwhp @ 20psi
44. tkgb, 104.5 S2, 88 stroke, wössner piston/rods, LR super 75, motronic, 4-1 headers, 408 RWHP at 1.2bar
45. ChrisJ951, S2, Wossner Pistons, Carillos, Spec S3 hybrid, LR Super 65, LR stage 2 head, Webcam
46. SSI Performance, 105S2/88 Nikasil, JE, 2.7 ported , Wossner Rods, Vi-PEC, more, 402/443@17 dynapac
47. 951_VAB, 104mm JE, Carillo, 2.7 worked head, JME cam, LR 75/10/P, LR MAF, 951Max chips
48. Thingo, 3.0, 8 valve, Arrows/Wossner, Twin scroll FP HTA GT35 twin tial WG, Motec ecu,sdl,cdi
49. blown 944, 2.85 custom stroker, JE, Eagle, sleeved/filled, Holset HX40/35 S w/Garrett hotside, Rogue tune
50. Grushy, Lindsey-Built 3.0 JE pistons, alusil, solid lifters...
51. Bri Bro, New factory Block, 100.5, 88, Mahle, Carrillo, Vflex+ E85, VR4, South Bend, LR intake, Ported head
52. Rluciano 104/88, Mahle/CEP pistons, Carrillo, 2.7 by Neil H., GT3582R, Link G4, mystery cam
53. Refresh951, 3.12L, Hybrid Stroker, 8V, JE, Eagle, sleeved/filled, 102, 95, GT3582R, Rogue tuned, 535/487
54. blown 944, 3.0 custom stroker, 105.5, FRF Deckplate, Eagle, sleeved, Holset HX40, 95One Intake, Rogue tune
55. Jon951, 3.0L, 104mm, 16V, JE, Crower Rods, Revline Racing Intake, VR S5 Turbo, Rogue, 500 rwhp at 15.5 psi
56.. Player0, JE/Molnar 3.0, darton dry, web274, 2.7 8v, gtx3582v2, haltech #958
57. gpr8er, 2.7 block and 2.7 head, turbo valves,
S2 crank knifed, 104.5 Andial/Mahle, GT 3582r vband. VEMS
Old 11-30-2008, 01:35 PM
Thom
Thom's Avatar
Mine is in the works. Will hopefully start in Spring.
Edited to add:
Engine #1, August 2009 -> December 2019, 110000km
Bore: 104.5, Alusil bores
Stroke: 88
Pistons: Mahle/Andial 8V turbo
Rods: Carrillo
Block/Crank: 968
Head/cam(s): 89 2.7 with 9R camshaft
Turbo: Garrett GTX3576R 0.82
Engine Management: Pauertuning's Vi-PEC/J&S set up
Other: Tial WG, LR full 3" exhaust, Bosch 044 fuel pump, KEP St. 2 PP with 930 disc, Area 951 carbon/alu intake, Audi 20V TB
Engine #2, since December 2019
Stroke: 88
Pistons: Custom forged Mahle 16V turbo
Rods: Carrillo
Block/Crank: 968, closed deck
Head/cam(s): 968
Other: TTV 60-2 flywheel, Tial 38mm MVS WG, LR full 3" exhaust, Bosch 044 fuel pump, KEP St. 2 PP with 930 disc, 4FF 16V intake, Audi 20V TB
Old 11-30-2008, 01:36 PM
Olli Snellman
Olli Snellman's Avatar
Mine is under building process
Old 11-30-2008, 02:58 PM
Joel8005
Joel8005's Avatar
3.2 Liter 968. Just working out the final details, should be on the Dyno in a couple of weeks for a final tune.
Old 11-30-2008, 03:07 PM
Diver944
Diver944's Avatar
Does a 3.2L Turbo count or am I too big
Old 11-30-2008, 04:21 PM
333pg333
333pg333's Avatar
2 builds. One 3L 8v awaiting final parts before re-assembly/dyno work. Larger 16v project half done. Waiting on the world's economy to change....
Bore:106 (3.1?)
Stroke:88
Rods: Arrow
Block: 2.5 Darton dry sleeves
Mgmt: Link G4
Head: 2.5 CEP racespec w big Cam
Turbo: Borg Warner ETT 362 hybrid
E85 map.
Other stuff etc.....
Old 11-30-2008, 05:30 PM
Tom M'Guinn
Seems to be a growing group -- and yes post up all 2.8 and up motors! Would be interesting to hear basic specs. I'll start:
Bore: 104.5 (no sleeve)
Stroke: 88
Pistons: Mahle/Andial 104.5 turbo pistons
Rods: Carrillo
Block: 89 2.7
Head: 89 2.7
Turbo: VR5
Engine Management: VR
Other: Gomes cam
Old 11-30-2008, 05:43 PM
Diver944
Diver944's Avatar
Bore: 108 (Sleeved, Nikasil coated)
Stroke: 88
Pistons: JE
Rods: Carrillo
Block: 89 2.7
Head: 89 2.7
Turbo: Garret/KKK hybrid
Other:
Old 11-30-2008, 06:20 PM
CP944T
CP944T's Avatar
2.8 needs rebuild this winter (some stuff already in works):
Bore: 101 (likely - stock bores are scored and still need machined, staying Alusil)
Stroke: S2 crank (is this the 88 as mentioned in other posts here?)
Pistons: Wossner (to be ordered for alusil use)
Rods: Carrillo
Block: 87 2.5
Head: 87 2.5, 944S 16v
Turbo: VR stage 4
Engine Management: VR (93oct mostly, want 100oct tune and may try e85 down the road)
Other: probably add the Saiko-michi oil catchcan, need a Tial 38mm, need a new muffler, need venturi-delete
Old 11-30-2008, 07:55 PM
dm44951
4th Gear
dm44951's Avatar
Default OK, I'm in / 3ltr @7psi until it breaks in
Running 7psi for now. Will get back with a dyno in the near future...
T.Bone (06-01-2020)
Old 11-30-2008, 09:10 PM
333pg333
333pg333's Avatar
Be interested to know the details on this one?
Old 11-30-2008, 09:34 PM
Jeremy Himsel
Jeremy Himsel's Avatar
Bore: 104.5 Stroke: 88
Rods: Pauter
Block: 91 3.0
Head: 89 2.7
Turbo: VR5
Other: JME CAM
Old 11-30-2008, 09:49 PM
targa72e
targa72e's Avatar
I have one (and its running!!) I will have to do a write up some time. 8V head, machined 968 pistons, TO4E maf,3" turbo back.
john
Old 11-30-2008, 09:55 PM
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
A bunch, many flavors! 8v, 16v, 104mm, 105mm, 106mm and one 108mm.
2.5 blocks, S2 blocks, 968 blocks.
Mostly Electromotive management
BTW - here is my 'Black Friday' picture - lots of stuff showed up on Friday. 4 TecGTs (2 going to 3.1 engines), 2 sets of pistons (one set is for 8v 3.1), a Vitesse turbo, a rather fancy dry sumpump and some other odd and ends.
Hmmm....might be able to make a '12 days of christmas' song out of that!
Old 11-30-2008, 10:22 PM
tone3721
tone3721's Avatar
My build will be done by Christmas.
89 2.7 block
89 2.7 head
pauter rods
mahle pistons
968 crank
VR stg3 turbo
lindsey mafterbrurner
951max chips
Quick Reply: 3 Liter Turbo Registry
