How to roll a fender like a champ... kinda
Yeah I'm gonna use a hardwood dowel or a baseball bat or maybe a pipe or something.
I've heard of guys put tons of newspaper on the corner of their tire and slamming the car down off the jack and it pulls the fender. Not sure if I trust it, and your car has to be real low to begin with.
I had a fender roller but it didnt fit, even with the truck adapter. Oh well, maybe someone on here can make a 5x130 adapter for the fender roller and rend that bad boy out!
I think if I ever roll my fender I'm going to use a dowel. That way I can get just the clearance I need. I don't want the lip sticking out too far or protruding too much.
That does look like a Special Tool...
Freedom Enthusiast
For those who want to try a dowel or baseball bat, I've got a couple of bats with groves I can sell cheap. My fender did not change at all but it put nice groves in the bats. I ended up using a 5lb hammer.
On the Radar
A helpful video on the "special tool"
Tool in action from pic posted by Mike
http://www.youtube.com/watch?v=5CzP-a3bPFw
Fender rolling with the eastwood fender roller.
http://www.youtube.com/watch?v=f812S3qm0hA
Check here 5 minutes in he uses something similar to a bat.
http://www.youtube.com/watch?v=DDTK9IjKIYU
Are the slots too large to fit 130mm?
From Eastwood's site:
"Our 25271 Truck Adapter is for larger applications. It will accommodate up to a 140mm (5.5") 5 lug bolt circle and up to a 152.4mm (6") 6 lug pattern"
I used the Eastwood roller trying to stuff 315's on the rear of my friends '89 with less than ideal offset. I mentioned in another thread you need to get the truck hub adapter, but someone said it still dosent fit. What i did was cut the bolt holes so they were essentially slots instead. This fit on the hub fine and does not effect the function or mounting of the roller. Nothing an air saw or sawz-all couldnt handle.
