Exhaust flex connector used for headers?
Old 01-24-2009, 06:49 PM
billthe3
billthe3's Avatar
Default Exhaust flex connector used for headers?
Has anybody ever tried using a flex connector in the headers to deal with the cracking issue? Or would a flex connector not hold up to the high heat/back pressure of a turbo system?
Just thinking about possibilities for exhaust stuff.
Old 01-24-2009, 06:59 PM
Brett
Brett's Avatar
It should hold up to the pressure since the Mitsu Evo has one
Old 01-24-2009, 07:35 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
The Evo does not have a flex connector before the turbo...
-Rogue
Old 01-24-2009, 07:51 PM
95ONE
95ONE's Avatar
I've replaced many on the DC sports headers for the NSX. They heat up and crack within a year. I highly doubt they'll last very long on a turbo header.
Old 01-24-2009, 08:45 PM
ShApE
ShApE's Avatar
I only do flex connectors when I build downpipes, unless there is no room, then I put them in the mid pipe.
Old 01-25-2009, 01:59 AM
billthe3
billthe3's Avatar
Ok, thats what I was thinking. Thanks.
Old 01-25-2009, 02:09 AM
globalmike
globalmike's Avatar
if these are stainless steel then they will not last in the high temp and oxidizing envirpnment. the only option would be to get a inconel material or other high temp alloy.
Old 05-11-2010, 05:27 PM
aromocki
aromocki's Avatar
I used an inconel below style vibration isolator before my wastegate and it works perfectly.
Old 05-11-2010, 07:10 PM
theedge
theedge's Avatar
I have one on my header. Local shop that welded it in said it would hold up in that position and they had used it in headers before (not 951 headers though).
IIRC the flex part was $50 or so.
Quick Reply: Exhaust flex connector used for headers?
