Camber plates info thread
Old 02-21-2009, 05:42 PM
Lorax
The Impaler
Lorax's Avatar
Default Camber plates info thread
There are about 1000 different manufacturers of camber plates for our cars it seems. Mookeeh, kokeln, racers edge, weltmeister, ground control, lindsey racing and more.
There are top mount, bottom mount, extended types and some the look like they have more adjustment than others. Some seem to use different bearing designs, some have proprietary spring hats etc.
Post up the info about what you are running, how you like it, and observable differences with the different brands...
Old 02-21-2009, 06:05 PM
Lorax
The Impaler
Lorax's Avatar
Here are some different products and their cost/info
Ground control bottom mount: $299 LINK
Ground control top mount: $439 LINK
Kokeln raised mount: $750 LINK
Mookeeh camber plates: $250 LINK
Racers Edge camber plates: $499 LINK
Weltmeister camber plates:$689 LINK
Lindsey Racing camber plates: $429 LINK
Tarett camber plates: $429 LINK
Dynatech camber plates: NLA
Old 02-21-2009, 06:09 PM
Lorax
The Impaler
Lorax's Avatar
I can add that I just got my GC top mount type, they are a very very well made piece and have the added benefit of easy caster adjustment.
Old 02-21-2009, 06:43 PM
PorscheDoc
PorscheDoc's Avatar
Last set of racer's edge camber plates we ordered, the camber plates were wrapped with paper/tape that said weltmeister all over it. I thought they were awfully similar.
Old 02-21-2009, 06:48 PM
roman944
roman944's Avatar
what is the difference between "top mount" and "bottom mount"?
and it appers that no one has much good to say about mookeh ones (hm maybe I'm wrong ...)
Old 02-21-2009, 06:57 PM
Thom
Thom's Avatar
I run Weltmeisters. They rock.
Old 02-21-2009, 07:15 PM
Lorax
The Impaler
Lorax's Avatar
Doh. Is that confirmation that they are identical?
Old 02-21-2009, 07:16 PM
chris951
chris951's Avatar
Top mount plates mount above the body and cannot be used with strut braces. Bottom mount is how the factory strut mounts are installed, so you can use a strut brace in conjunction with the camber plates.
I am running the Lindsey Racing plates and absolutely hate them. The design is sweet if you have coilovers as the 2.5'' spring hat is part of the plate and has a thrust bearing so the weight of the car sets on the actual plate, not the small bearing inside.
The negatives about the LR plates is that the hardware was as cheap as it can get(I replaced all the bolts and nuts), There is no room for a lock nut or a lock washer for the top strut bolt, because there is not enough room for adequate thread clearance.
The spherical bearing inside the plate has soo much play in it that I can see it moving and when I told Dave Lindsey about it, he told me that the whole bearing is loose in the plate and he would send me some shims to fix it. After ruining my struts to remove the plates to "shim" the bearings, the bearing were NOT loose in the plate, the bearing had play inside of it...so I was right from the beginning.
The bearing that the strut is fastened to has soo much play in it that I physically see it moving inside of the outer race. Everytime I hit any bump at all, there is an enormous clunking noises from the camber plates. Suspension components should not have ANY play in them, especially components that are supposed to be used for racing.
I would advocate the Racer's Edge, bottom mount Cround Control, and the Weltmeister plates. I would also recommend a coilover conversion if you are thinking about installing camber plates, so you have adjustable ride height as well as an adjustable alignment. I have personally seen Racer's Edge ones and they are really really NICE!...just kinda expensive, but what isn't on these cars.
Old 02-21-2009, 07:17 PM
Lorax
The Impaler
Lorax's Avatar
Top mount types generally allow for more suspension travel, which is good for cars that are lowered a lot. Stops you from hitting bump stops. Also bottom mounts will almost always raise the ride height on a stock car a bit.
As for the mookeehs, I've never used em. They look pretty cheaply made honestly, but then again they are pretty cheap.
Old 02-21-2009, 07:19 PM
Lorax
The Impaler
Lorax's Avatar
I have to disagree, I believe ground control sells a stress bar that works with their top mount camber plates. Also top mounts give an extra inch or so in suspension travel, which is absolutely necessary when your car is as low as mine.
Old 02-21-2009, 07:30 PM
SamGrant951
SamGrant951's Avatar
Ground control bottom mount here, no complaints...good piece at a fair price.
Tarett Engineering offers a set as well: http://www.tarett.com/items/944-seri...amp-detail.htm
Old 02-21-2009, 07:32 PM
Lorax
The Impaler
Lorax's Avatar
Thanks, I'l add those to the list.
Old 02-21-2009, 07:34 PM
chris951
chris951's Avatar
top mounts are just more of a hassle in my mind. The way the top mount supports itself seems like an accident waiting to happen if any mount bolts come loose.
If you have the plate installed underneath, the weight of the car is supported more securely without worries. The plates installed underneath will raise the ride height like you said, however, with coilovers, it is much easier to adjust the height on the coilovers than it is to have to screw around with top mounted plates. I understand your point about having a very low car and maybe it is the best thing for you, but I guess it is just a matter of opinion. I had a KLA strut brace on my car before upgrading to camber plates, so it was much easier to reuse the strut brace, than to buy a proprietary strut bar.
Old 02-21-2009, 07:40 PM
Lorax
The Impaler
Lorax's Avatar
FWIW the ground control top mount types are designed with a piece of metal that bridges between two bolts, in case on of the locking nuts somehow manages to back out.
Just thought I'd add that.
Old 02-21-2009, 08:04 PM
PorscheDoc
PorscheDoc's Avatar
That was my take. Side by side they are identical, and when we ordered the RE plates from RE, and got camber plates wrapped in weltmeister packing, it seemed to confirm it.
Quick Reply: Camber plates info thread
