3" Cat Back DIY (lots of pictures now)
Old 09-25-2009, 04:34 PM
gtomarty
gtomarty's Avatar
Wow thats nice I will be doing this soon! thanks for the post, and the part numbers
Old 09-25-2009, 04:39 PM
minho78
minho78's Avatar
Was itTig or Mig welded?
Old 09-25-2009, 09:45 PM
gt37vgt
gt37vgt's Avatar
looks like mig .
the other thing you can do if you don't have a welder .
is asemble it with hard hubber hose or cut down stainless in side .
the mark the orintation of were the bends meeting the strait perabs "A" "B" "C" etc then take it somwhere to weld .
I would suspect this is definatly the best way into a 4" system as well
Old 09-26-2009, 02:06 AM
95ONE
95ONE's Avatar
Clearly mig'd.
Great do it yourself.. the different angles aren't easy to get right.. bends are simple, but there are "twists" you have to get just right. Or it won't sit right.. THat's where much of the work is.. Also, the adjustment wing on the end of the muffler takes a little bit of work also.. I should know!!!! So, in knowing how much work that really is...... GREAT JOB!
Old 09-26-2009, 02:17 AM
CarbonRevo
CarbonRevo's Avatar
Someday I'll have what's pictured above. A full V-Band exhaust!
Nice DIY if you're happy with it. I'm happy with my SFR exhaust though. Different strokes for different folks I guess lol
Old 09-28-2009, 01:53 AM
porschefig
porschefig's Avatar
Certainly MIG! and yes it did take some time to get the muffler to sit at the right angle and the right clearance under the sway bar.
Thanks everyone for the kudos!
Old 09-28-2009, 02:26 AM
Keithr726
Keithr726's Avatar
After seeing this thread again, I can't help but to say how cool this really is. This could save a lot of people a lot of money. When I discovered my cat-back had a few holes I wish this post was around.
Old 09-28-2009, 08:33 AM
Van
Van's Avatar
For those looking to use your MIG for stainless, go pick up a spool of stainless wire (and you'll have to use a CO2/Argon mix - or straight Argon). That way the weld won't ever corrode...
I didn't notice if Kyle mentioned it, but an easy way to get the alignment all right is to tack weld each joint in place under the car (might need a helper to hold everything), then take it off and do your final welds. Being comfortable, and not welding upside down will help your welds be maximum quality.
Old 09-28-2009, 08:45 AM
toddk911
Drive-by provocation guy
toddk911's Avatar
Is it possible to get at the downpipe without pulling the turbo?
Old 09-28-2009, 05:59 PM
eniac
eniac's Avatar
Anything is possible but by the time you figure out a way to do it, you could have had the turbo off and back on already.
Old 11-27-2009, 06:16 PM
supes6
supes6's Avatar
Anyone know where I can get the exhaust flange needed to bolt up the cat-back? I've got everything I need to build my exhaust but can't seem to find any place that sells the 4-bolt 3" flange in stainless.
Old 11-27-2009, 07:51 PM
Tom M'Guinn
Tom M'Guinn's Avatar
I don't sorry, but another option is to cut the square flange off the end of the cat, expand and slot the cat back, and connect with with a lap joint collar like this:
http://www.summitracing.com/parts/WLK-33222/
Old 11-27-2009, 08:16 PM
gt37vgt
gt37vgt's Avatar
er perhaps use 2 flanges from the back of GT35 garrett i think they are 3" and they are common as on ebay
Old 11-28-2009, 01:10 AM
supes6
supes6's Avatar
The lap joint could work.. seems like it would be prone to leak though. Are the GT35 flanges the same bolt pattern?
Old 11-28-2009, 02:04 AM
TRACKIN951
TRACKIN951's Avatar
Consider this done in the spring! I never though it wpould be this easy. 2 pieces and a muffler(+flanges of course). Thanks for the write up!
Quick Reply: 3" Cat Back DIY (lots of pictures now)
