classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat     |
Sign in using an external account
Thread Tools | Search this Thread |
#1 | ||
User
#2 |
Rennlist Member Rennlist Site Sponsor |
You just named the 2 to look at, lol.
Most people buy the entire transaxle because they probably don't want to have to deal with installing a differential into the transaxle.
Doc Wilen PCA/NASA Instructor 86 951: 5.3L v8 06 Jetta TDI 02 2500HD 00 JGC My P-car blog: RennsportKC Blog |
#3 |
User
Cost!! you can remove and replace the trans in about 3 hours with hand tools,,just the limited slip requires special tools and is not a do it yourself, as a rule. That said I just put a limited slip box in the car and WOW big change, on the track no more one wheel peel out of corners and stable hard braking, not 100% sure why on the braking, but I know it stopped squirming.
#4 |
Rennlist Member |
AOR transaxles also have harder first and second gears.
#5 |
Rennlist Member Join Date: Feb 2006
The downside is that the factory LSD isn't really up to any track work etc. Doesn't last too long in my experience and only 40% locking.
#6 | |
Rennlist Member Join Date: Aug 2007
Quote:
incase it wasn't clear |
#7 |
Rennlist Member Rennlist Small Business Sponsor Join Date: Jul 2001
It is if you play nice!
PCA Instructor BMW CCA Instructor PCA Tech Inspector 4 wide bodied 944s in various states of build 94 968 Cab - 16v 3.0 turbo Cayenne S 07 Audi A4 Cab (w 3.2 V6) 00 Ford F150 65 Shelby GT-350 - track rat from 1980's 66 Mustang convertible - Getting 944 suspension! 02 Mini Cooper S 85 Barth - 8.2 turbo
#8 |
Official Rennlist
Borat Impersonator Rennlist Member Join Date: Sep 2003
#9 |
Super User
Check out the most recent issue of Excellence. There is an article on how to install a Guards LSD in a 944 trans.Nothing crazy in terms of tools needed.. seems like a very reasonable job to do.
#10 |
#11 |
User
Do you have a link to that by any chance??
#12 |
Super User
I had a factory one shimmed up for more lock ..
I would expect as it would slip less it would take a little longer to wear out you can test it with a torque rench there is a given break out torque for given lock ratio i believe.. there was also i good thread on here if you search saying that they will perform differently according to the oil used in them . it basicly said you build them a bit tight put one type of oil in then when they start to slip a little you change to anther kind of oil and they get grippy again and you get another little bit from them befor pulling them out to service |
#13 |
Rennlist Member Join Date: Feb 2008
I installed a Guard this winter. You don't want to tackle the installation of a $2,500 part in your trans unless you're pretty damn proficient and have the tools and shims. You further need additonal cooling if you expect to run sessions longer than 45 minutes. Removal and install are the straightforward.
#14 | ||
Rennlist Junkie Forever
Quote:
Kinda silly. You're much better off buying a non-lsd turbo trans for cheap and installing a Guard LSD for a few dollars more than a AOR trans with 50K+ miles on it. Quote:
TonyG
Tony Garcia tonygATarchsoft.biz Current Toy: LS6 951 (mu ha ha...) In the Works: Vision LSx 951 with GT3 suspension Current Driver: 2011 STi Limited Sedan www.tonygarcia.org/944V8 |
#15 |
+1
23 years later and only one rebuild this year, the LSD was in good shape and this is with plenty of DE's on it. |
| Tags |
| 944, 968, 997, cayman, differential, gt, guard, guards, limited, lsd, shimming, slip, transaxle, turbo, years |
