Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > 924/944/951/968 Model Specific Technical Forums > 944 Turbo and Turbo-S Forum
Old 07-03-2009, 05:08 PM   #16
Tom M'Guinn
Tom M'Guinn's Avatar
Most of the bigger aftermarket turbo's have over-sized inlets, meaning you have to modify or replace the stock J-boot to use them. The MAF kits solve this problem because they come with their own j-boots, couplers, etc. If you are looking for economical upgrades (i.e., not changing out the AFM, injectors, etc.), then a good k26/8 or "cheater" version thereof with performance S chips from VR would get you more power without breaking the bank and adding tons of supporting parts. On the other hand, if you ultimately want lots of power, VR's kit gets my vote.
Tom M'Guinn is offline   Reply With Quote
Old 07-03-2009, 05:51 PM   #17
jasonlp
jasonlp's Avatar
you wont make 350rwhp but a KKK 27/6 would make you happy and or a KKK 26/8. The 26/8 would just need new chips.
Like watching a gremlin destroy your airplane engine from your window seat at 20 000 feet.... A.K.A. Stephen King's Christine A.K.A. Bad Luck Betty: 86 951 Guards red and black
Parts site's:
http://www.facebook.com/group.php?gid=2253320745
jasonlp is offline   Reply With Quote
Old 07-03-2009, 06:27 PM   #18
dillon410021
dillon410021's Avatar
if you go with lindsey racing, if you have any of the parts that are on the list to make a certain power like the 340 hp kit, they will lower the cost since you have a part.
Dillon
1987 944 parts car- sold
1987 944S- 68K miles
1987 944 Turbo- daily driver
-- stage II M.A.F./intake, stage II chips, 1988 dme, 3 bar F.P.R., LR SS fuel lines, Billet bov, LR vacuum line kit/ venturi delete, LR MBC, LR gauge pod,Prosport gauges, 996 wheels, 122K miles
dillon410021 is offline   Reply With Quote
Old 07-03-2009, 06:42 PM   #19
Over Boost
Over Boost's Avatar
I have 2g to spend right now but i can come up with more its just a matter of time. And yes my car has LSD. Im really liking the sound of this 60-1 though. What other supporting mods would i need for say 300whp with that turbo? The only other mods i have are 3bar fuel pressure regulator and i have a electronic boost controller with a vitesse chip.
Over Boost is offline   Reply With Quote
Old 07-03-2009, 10:43 PM   #20
mtnman82
mtnman82's Avatar
Have the PowerHaus K27DR (not sure if it's a /6 or /8) and I see 1 bar by 3200 rpm. I suspect I have a small intake leak or two (small exhaust leak too) so I think that can be improved. I suspect I'm somewhere ~300rwhp @ 15psi also. It breaks the 245 Dunlop SP9000's loose in 1st gear if I stomp on it (2nd too if I'm @18psi). It does this with the AFM or with the MAF installed. The MAF (Vitesse) makes it much more driveable at lower rpm's & around town - very nice improvement over the AFM.
If you have a Vitesse chip for AFM, I'm betting you have a very nice tune right now, and the way John writes the software you can probably just upgrade the turbo a bit without changing/upgrading. I don't think John recommends his stage 2/3 with the AFM setup. If you don't have a 3" exhaust yet I'd recommend getting that too, as stock/2.5" is definitely a limiting factor (just going from stockish exhaust to 3" made the difference in the tires breaking loose). Just someting to think about... You might take care of the turbo since you have to at present and also get the exhaust, then save up for the MAF kit.
I have a Vitesse stage 2 on the shelf waiting to go on, but am content enough with the K27 to leave it there for now and take care of other things on the car first(need to find the vacuum/exhaust leaks, fix a bonehead oil leak or two, and start suspension/brakes). That being said, if this is what the K27 can do, I can hardly wait to get that Vitesse turbo on there..... .
'89 951 TiAL 46mm, black knob MBC, Powerhaus K27DR, Vitesse MAF, Delphi 75# injectors, Lart SS Fuel Lines, Fabspeed 3" exhaust, KEP I pp, 930 disk, Blazack flywheel & clutch fork, urethane tranny mount
mtnman82 is offline   Reply With Quote
Old 07-03-2009, 11:26 PM   #21
badcoupe
User
badcoupe's Avatar
My K-27 would kill the nitto drag radials, I ran it with the Guru MAP kit for awhile and I actually got it to work really well, in fact I still have the setup somewhere put away. I went to the Vitesse after I made my headers, 2.5" crossover pipe and TRUE 3" downpipe for my 60-1. It's a straight T3 meaning I have a T3 exh inlet and V-band out. I think you'll love a 27/6 really well. I sent a 27 from diesel motor and my blown 26 to michigan turbo and had it back in 48 hours. He put the 27 cold side on my 6 hotside with a new not re-man center section for 600. Granted that was a few years ago, someone on here ended up with it can't remeber who.
badcoupe is offline   Reply With Quote
Old 07-04-2009, 12:00 AM   #22
Nurburger
Nurburger's Avatar
Very happy with my K27 / Vitesse set up.... Quick spool, plenty of boost to redline & very smooth running.
Nurburger is offline   Reply With Quote
Old 07-04-2009, 02:15 AM   #23
Over Boost
Over Boost's Avatar
ok so K27 and 60-1's are what i need to look for now then right? If anyone has any used parts they want to sell let me know. Also where are some good places to look for this stuff? I'll have to email powerhaus to get a price quote on a K27. Who sells the 60-1?
Old 07-04-2009, 02:41 AM   #24
jasonlp
jasonlp's Avatar
maybe
http://www.034motorsport.com/
Parts site's:
Old 07-04-2009, 04:24 AM   #25
ehall
ehall's Avatar
Quote:
Originally Posted by 2bridges View Post
VR stageIII kit is awsome! Complete night and day transformation.
I'd say that you'd be foolish to go anywhere else.
There are some other vendors that have HP kits, and they are also good.
Whatever you do, make sure the engine is solid and then go with a complete solution from a single vendor.
I prefer Vitesse, but Lindsey and Speed Force Racing are also solid choices.
951's that have problems are generally put together piece meal. I'm not saying always. We have some really sharp folks around this board, but quite often.
"I like your Christ. It is your christian's that I don't like. They are very different from your Christ." Ghandi
"Don't believe everything you read on rennlist. For every 15 opinions one of them actually has some experience."
Jeremy Himsel
"The Other Side is Worse', is not a very compelling bumper sticker' ". Gov. Bobby Jindal Rep. Gov. La.
ehall is offline   Reply With Quote
Old 07-04-2009, 06:30 PM   #26
ausgeflippt951
ausgeflippt951's Avatar
Send a message via AIM to ausgeflippt951
Vitesse, Vitesse, Vitesse! I've got his St. 3 kit, and it's splendid. Yes, you will pay a bit more than perhaps some other manufacturers, but it is well worth it.
Highly recommended.
Now, if you're simply wanting to keep the car stock, I have a K26/6 in great condition that I need to get rid of.
Collin
'86 951 -- The new guy: def not stock.
'86 951 -- Gone to the great 951 land among the clouds
Custom-built Dirt Bike w/ Yami 400cc motor...12k RPM and 12.5:1 CR
"Anybody can make something that works. It takes an engineer to make something that barely works."
ausgeflippt951 is offline   Reply With Quote
Old 07-04-2009, 09:12 PM   #27
rlm328
rlm328's Avatar
What ehall said, one of the big three and get the whole set up from one vendor. They have gone through alot trouble setting up their packages. Give any of them a call and they will tell you what you need to get started for your price range. But you definitely want to make sure your engine is solid.
Bob
87 951: 2.8L Stroker, Turbonetics T3/T4, Vitesse MAF, Siemens 72 lb Injectors, Tial 46 mm Wastegate, MBC, SFR Stage 1 Headers, Lindsey 3" Exhaust, AC and Heater Delete, Autopower Full Roll Cage, JIC Coil Overs, Weltmiester sway bars front and back, and to stop it all 996 monoblocks
06 Cayman S
rlm328 is offline   Reply With Quote
Old 07-09-2009, 04:54 AM   #28
Over Boost
Over Boost's Avatar
So can i get anymore info on the 60-1 set ups? I dont get how people can run that with just a MAF?
Old 07-09-2009, 06:10 AM   #29
ehall
ehall's Avatar
Quote:
They can't. It requires chips, maf, turbo, 3 bar FPR, injectors, manual or electronic boost controller, most often a new wastegate and I would HIGHLY reccomend a reliable wideband O2 monitor. Once you have all of that, it also makes sense to get full 3" exhaust. Now you can go to the dyno and tune the car to work correctly.
After those few things, you are golden.
Ya CAN'T just get a different turbo!
Jeremy Himsel
Old 07-09-2009, 09:09 AM   #30
gt37vgt
Super User
well ya can just a different turbo but you're only likely to reap 2% of the possible gains available from the new turbo.
gt37vgt is offline   Reply With Quote
Tags
27, 276, 360, bearing, chip, degree, fit, kkk, powerhaus, thrust, turbo, type, vehicles
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
