Mobil oil co. recommends 0w40 for our cars
Old 07-23-2009, 07:18 PM
marky522
marky522's Avatar
Yeah, I live in NC and have driven my 944 with 0w40 with no problems.
Mark
Old 07-23-2009, 08:38 PM
seattle951
seattle951's Avatar
Maybe a year ago, Panarama magazine did an article on oil and discussed why Porsche changed their oil recommendation to 0w-40 synthetic. I don't remember the details, but part of the discussion was around how oil technology has dramatically improved over the years making it possible to run this grade year round. Cold start up was also mentioned.
If somebody is really ambitous and saves these magazines, they could look it up and post it back to the group.
Old 07-24-2009, 12:43 AM
Fishey
Fishey's Avatar
0w-40
Is a PAO oil and 15w-50 is a type 3
Anyways, 0w-40 is far too light
Old 07-24-2009, 12:59 AM
gregeast
gregeast's Avatar
Originally Posted by Fishey
0w-40
Is it the '0' or the '40' that you think is too light?
Old 07-24-2009, 01:02 AM
Fishey
Fishey's Avatar
both...
Old 07-24-2009, 09:19 AM
dmalo810
dmalo810's Avatar
They just did another oil review just this year basically talking about ZDDP and the effects with studies done by L & N engineering (can't remember if that was the name).
Newer cars M-1 is great, older cars waste of $$. Also, conventional oil doesn't need changing till up in the 5k range unless you are doing performance driving (racing/DEs/Rally) or thrashing on dirt roads. They found that too early oil changes are causing excessive wear as oil is not reaching it's peak until past 4 to 5k.
I run high ZDDP oils like Brad Penn or Valvoline Motorcyle oil. Stopped my leaks (use to run M-1) and no consumption. Go to L & N website, they rate every oil in it's effectiveness and they can check your oil and see how well of a job it's doing and how much metal they find, giving you a recommendation needed for your particular car.
Old 07-24-2009, 10:01 AM
Jake951
Jake951's Avatar
It is a fact that Porsche now recommends 0W-40 synthetic for all models going back at least as far as the early 1980's. On all new Porsche models, there is a very limited range of recommended viscosities, with 0W-40 and 5W-40 among them. 15W50 is NOT recommended. Part of the reasoning, as I understand it, is that the motor oils also serve a hydraulic fluid function in the engine, which requires the oils have low viscosity numbers at low temperatures.
Old 07-24-2009, 10:11 AM
dillon410021
dillon410021's Avatar
Originally Posted by gregeast
Just for the record, I'm seeing less oil consumption with 0W-40.
Me too
and I run 20W-50 over the summer.
Old 07-24-2009, 11:17 AM
bearone
bearone's Avatar
Question
i guess porsche isn't too concearned with maintenance issues for older cars where oil wt was referenced by temps in the owners manual.
changing to synthetic oil on a used motor has been documented to use/leak more when the change is made.
it makes me wonder who they're thinking about, the owner/enthusiast or potential maintenance $$$$.
87951
95sl320 dd
Old 07-24-2009, 11:38 AM
dmalo810
dmalo810's Avatar
Hey, I stand corrected. The article on oils is in the Panorama Oct. 08 issue. Good stuff!
Old 07-24-2009, 01:15 PM
seattle951
seattle951's Avatar
The mechanic that built my engine stated that he wanted 10W-30 synthetic year round for street driving in my car. He was concerned about too much pressure in the system. The engine was completely rebuilt to tight tolerances and got an upgraded cooling and oil system.
I am currently running Royal Purple 10W-30 XPR. Their oil engineer concurred with my mechanic on what I should be running after we went down the list of modifications. Like my mechanic, he cautioned against heavier oils.
Your comments make sense based on the feedback from my mechanic and Royal Purple. Anyway, the car does exceptionally well on 10W-30 RP XPR.
Old 07-24-2009, 01:19 PM
seattle951
seattle951's Avatar
87951
95sl320 dd
Wasn't the owner's manual written in the early 1980s? Porsche changed their recommendations based on the performance of their products and changes to the make up of the oil.
I thought the oil leakage with synthetic was an old wise tale. I moved from non-synthetic to synthenic in my 1987 924S without issue. As far as I know, everything was original. It did not leak a drop of oil.
Old 07-24-2009, 01:34 PM
carlege
carlege's Avatar
isnt that what the OPRV is for
Old 07-24-2009, 01:44 PM
seattle951
seattle951's Avatar
Yes, I should have said flow rate through the external oil coolers instead of pressure.
With a thicker oil the pressure will build more quickly and be vented by OPRV and there would be a lower volume of oil going through the oil cooler. I am putting words in his mouth, but I believe this is what he meant.
Old 07-24-2009, 01:56 PM
carlege
carlege's Avatar
Its good information for people that newly rebuilt engines but 75% of us have for the most part factory engines. so the tolerances have maybe worn a little. i was told 20w 50 But of course i live in TN (as of right now) and it freezes maybe 10 days a year. I would still be very hesitant with 0w40
Quick Reply: Mobil oil co. recommends 0w40 for our cars
