How to clean dirty coolant tank?
Old 07-30-2009, 05:07 AM
333pg333
333pg333's Avatar
So do you think you'll have a faster trap speed now...hehehe
Old 07-30-2009, 10:54 AM
JohnKoaWood
JohnKoaWood's Avatar
Not sure if trap will improve, I'm just worried about shaking while idle...
Old 07-30-2009, 12:55 PM
reno808
reno808's Avatar
nice sweeeet my is yellowish brown. I'll give it a try tommorrow. sweeeeeeeet
Old 07-30-2009, 05:37 PM
porshhhh951
Monkeys Removed by Request
porshhhh951's Avatar
So wil that work on our coolant thanks that aren't white(mines original). If so this looks like how im going to spend my friday.
Old 07-30-2009, 06:08 PM
JohnKoaWood
If it is heat discollored, this method won't help make it clear, but if it is DIRTY on the inside, this worked wonders...
When I got this tank, it looked white, but was dirty on the inside, like it had been on a car that mixed oil and coolant... you know the scum inside the tank...
Old 07-30-2009, 06:53 PM
Paseb
Paseb's Avatar
wow i got to try that also, thx for the tip and great found!!
Old 07-30-2009, 10:08 PM
porshhhh951
ah thats what I figured. No way around buying a new one. Its on the to list for sure.
Old 08-02-2009, 05:20 PM
billthe3
billthe3's Avatar
I wonder if this would work on cleaning out all the crap that gets built up in the brake fluid resevoir over time...
Old 08-02-2009, 05:40 PM
JohnKoaWood
I bet it would... give it a try..
Old 10-13-2009, 03:34 PM
krystar
krystar's Avatar
so i wonder why coffee grinds work better than any other abrasive. i'd imagine sand would have done the same thing...
is this like something for a Materials Science engineer to study? hehe
Old 10-13-2009, 04:47 PM
black944 turbo
black944 turbo's Avatar
Very cool, I bought a slightly used one and had the same issue, tried most of the things you did and still was disapointed. I will try this next time I have my tank off.
Old 10-13-2009, 04:49 PM
fortysixandtwo
fortysixandtwo's Avatar
I had similar results using pool sand and either simple green or super clean, I honestly do not recall at this point. The solution removed all of the internal buildup and the tank looked way better than before, but was still yellow.
Old 10-13-2009, 09:21 PM
JohnKoaWood
I don't think I ever posted my final after pic...
Old 06-13-2011, 11:26 PM
A81Sturmer
2nd Gear
A81Sturmer's Avatar
I tried the coffee grounds. Pretty strenuous effort. Multiple flush and grind and shake and simple green and lots of water and grounds and shaking. Oh - and did I mention that I did a lot of shaking. Little improvement in my case. My car is getting some oil in the water (yeah, I know). The oil floats on the edge of the water level in the overflow. The oil has accumulated making it very hard to see the water level - since it float at the water level - dah. Anyway, the coffee may have done a little. I guess the proof will be when I refill it and try to see the water. But there is still a lot of black accumulation on the water line. I think I cleaned my old tank pretty well with detergent based cleaner and water. But that car was not leaking oil into the water. Guess I need to do the head gasket and look for another tank. Oh, by the way I was using New Orlean Chicory coffee, trying to get rid of it. Maybe it's not any good for cleaning overflow tanks either.
Old 06-14-2011, 01:07 AM
User 41221
User 41221's Avatar
I had pretty good luck with Polident (the denture cleaner and before you ask, no, I don't have dentures!) but the coffee is a new one and it looks like you got better results than I did. Awesome find!
Quick Reply: How to clean dirty coolant tank?
