Anyone familiar with Kreen Internal Engine Cleaner?
Old 12-29-2011, 03:15 AM
LFA951
LFA951's Avatar
Default Anyone familiar with Kreen Internal Engine Cleaner?
I just got a quart in the mail, but I'm leaking oil around the oil pan gasket to cross member and thinking it may make the leak bigger, any feedback or suggestions?
http://www.kanolabs.com/engCle.html
Old 12-29-2011, 11:05 AM
reno808
reno808's Avatar
yeah go check out the seafoam thread
Old 12-29-2011, 11:15 AM
pettybird
pettybird's Avatar
Better get this stuff instead:
http://kalecoauto.com/index.php?main...&products_id=7
Old 12-29-2011, 11:26 AM
lart951
Basic Sponsor
lart951's Avatar
Originally Posted by pettybird
The cross drilled brake lines are a perfect match for the cleaner
http://kalecoauto.com/index.php?main...&products_id=1
Old 12-29-2011, 02:32 PM
pettybird
pettybird's Avatar
I'm gonna get an O-pipe for my turbo, too. To hell with that Fabspeed downpipe I just bought...there's no backpressure there at all!
Old 12-29-2011, 03:30 PM
APKhaos
APKhaos's Avatar
Trust these guys. They were the first with high-spec muffler bearings.
Old 12-29-2011, 03:56 PM
lee101315
lee101315's Avatar
Just change your oil more frequently.
Ive been to many crankshaft machine shops, and none recommend engine oil cleaners. They tell me the main/journal bearings "are the last filter" and usually get damaged by debris breaking loose upstream in the oil supply.
If youre really dead set on cleaning the internals of your engine, next time you pull down the oil pan, wipe down the inside walls of the block and really scrub the oil pan. And then empty out your oil cooler. Your oil will be much cleaner looking next time you check it.
Quick Reply: Anyone familiar with Kreen Internal Engine Cleaner?
