Feedback on Lindsey Racing 270 kit?
Who has tried the Lindsey racing kits for 270+? Feedback? I've always liked those guys there and am thinking about future mods. I don't want to get too aggressive or complicated as drive-ability, reliability, and time are the keys for me.
They also offer a heat coating??? Worth it?
Thanks for your input.
I dont understand why people buy these premade exhaust kits. Im sure there are shops in your town that can custom fab an exhaust just like that for around 350.
The other stuff is nice but the exhuast like alot of the polished ones seem so overly price for what you get. seriously polished exhaust? (its under the car)
On the Radar
I have the 300 kit on my 86.
With a fresh head and fesh 26/6, it dynoed @255/292 RWHP (IIRC)
I think this was @ 15psi.
not bad for the cost. But not 100% happy with the result.
but for 1800 dollars
Nothing wrong with going that route, just different methods of execution.
Herr Unmöglich
I had a local exhaust shop make me an exhaust for my 944 in my avatar. Looked real nice, seemed pretty decent. It was $325 IIRC including muffler and tip.
Last weekend the pipe straight up broke at the muffler inlet, in the middle of a 944 Cup sprint race. It did not break at the weld but rather next to it... the pipe cracked around the entire diameter, and then cracked back up the pipe too. It sure appears that the shop used less than top of the line steel, and it could not take the heat. This exhaust is still mounted with factory rubber mounts so it is even vibration isolated.
I threw a factory system back on for now but I am buying a Lindsey rather than spend time having it fabbed again by someone who doesn't know jack about 944's. I have faith that the LR system is designed and tested on and for this specific car, and that for the money it will last in a track environment. I want it to bolt up with no hacks.
Personally, I will be buying a coated header and a regular uncoated system from the header to the muffler.
I have seen 30% difference in HP from exhaust systems that all look very simular. Very little things like smoothness of the joimts internally make a big difference. Small changes in the lengths between connections or where the crossover is mated makes a difference. I agree with going with someone who knowa these things. The stock system out performs many custom exhaust systems through 6,000. As mention above the bad quality jobs can be miles down the road before it shows up.
We found 1/2" Difference in the header tube lengths on our Boss 302 Mustang in Trans-Am racing could change the pulse length and timing of the cylinders. Where every 3,300 (IIRC) RPMs they were almost opposing each other and not complimenting them. So twice in our usable RPM band we went flat on power.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Most local muffler places are hacks (not all, just most!). They use cheaper materials and less than optimum welding - all stainless steel should be welded with a back gas treatment (the other side of the weld should be shielded with an inert gas when welding). I can't say I have ever seen that at a 'local muffler shop'....
Sometimes you get what you pay for...
for your information. Most exhaust shops weld instead of clamp the exhaust in place. Essentially the same parts muifflers and such. I just see clamps as more of a leak factor then welds. No re-inventing necessary
