LR cam tower gasket
What's wrong with stock
Hi,
Mine just started to leak (on the exhaust - and subsequently smokes nicely) and I was going to replace with a stock one.
What happened to your stock one that caused grief?
George
The nice thing about the Lindsey is putting the cam tower back on with out the gasket getting pinched and moving around. You have to remember that it has a oil hole on one end only so has to go on the correct way ask me how I know. Mine has been on and off 3 or 4 times and just started leaking a little on the rear corner.
Clifton
Clifton
What does high boost have to do with a cam tower gasket? Boost only effects the intake path, correct? I'd be more inclined to think that stock gasket failures are due to warpage, age of the gasket or poor wrenching technique, rather than design.
Sounds like Lindsey may have designed a cam tower gasket that adress those issues, good for them. Otherwise, you can go back and fix the underlying cause of the issue and drive for many miles with a stock one.
Completely agree. I had a very unique issue which should hopefully be fixed now. Like I stated in my post, these gaskets have worked well for over 20 years.
Having a flame on your header from dripping oil makes you nervous. At least it makes me nervous. I've got too much money tied up into this car.
The LR gasket is a great product. It's only a few bucks.
George
George
Hey George, sorry if I sounded like I was throwing rocks at you, I didn't mean it that way! The bottom line is that its nice that there is an alternative from Lindsey.
Regards,
Regards,
Basic Sponsor
We sell more of those gaskets then the stock one. Probably 2 or 3 to 1. They are re-usable providing
you don't scratch off the rubber Viton coating. Just wash with soap and water, and re-use. We didn't
produce that gasket for any other reason then we wanted a stable and consistent thickness gasket for our solid lifter packages to give us proper valve lash. Just so happens to work very well on any car as well!
Mike or Dave Lindsey
www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
We thought it was a warped head or cam box. Took everything off and all was good. OK, must be excessive crankcase pressure. The motor got pulled.
We are creating some additional crankcase breathing and checking everything. We are also adding the LR steam vent kit.
Then decided to change out the turbo, then decided to go with a 968 bell housing, 911TT sport spessure plate and disc made specifically for their flywheel and my high tq motor. OOPS forgot we need a 968 flywheel. Ordered a alum flywheel from 968barn. Realized we can now use the factory flywheel sensor from the 968. Rewired the TECGT to the new sensor........dang car.
I must have an addiction. Don't know why I like these cars so much. I need help. Are there any 951 support groups or 12step programs?
Seriously, when things are running well in these cars with proper suspension, brakes, and 400-500whp, these cars are just a blast. Nothing gives me the same thrill, and I've driven most of what's available.
Sometimes I do feel remorse when spending big money on this car......like I am now.
What turbo are you going with this time? I am considering a GT3561 for my 3 liter build. But I want fast spool not crazy high horsepower.
Thanks,
Richard
Know I did much research, and spoke with my engine builder, Garrity. Garrity used to teach the 951 engine building class for PCA in St. Louis. He has had much luck with his 3.0 engine builds using Garrett products. His shop has mostly 911TT's on the lifts, and some killer Cyclone motors being built.
Precision built a new ported housing using a forged billett wheel. It's called the 6262 Billett. They use a Garrett dual BB center section, forged wheel, and some other neat stuff on the housing.
We built a .58 hotside and a .62 coldside turbo. It's a T4, so my 4"intake will work fine. He also moved my intake filter outside of the engne bay to the front fender with a housing. To clean the filter, I'll have to take off the front driver wheel, but that's not an issue. Real cold air at intake will help make consistent power. Our engine bays get hot. Thought this was a great idea, and let him fabricate to his hearts content.
Hope this helps. Google the Precision 6262 turbo. They will build it to your specs. Precision makes good products. www.horsepowerfreaks.com uses their turbos for their M3 conversions.
Garrett makes great stuff. Speciality turbo manufacturers use their center sections for a reason.
Good luck with your build.
G
dual BB Garrett
G
dual BB Garrett
I only realized this because Chris White told me. Wanted to give Chris the credit.
So, thanks Chris. I'll be calling you end of the month for some baseline tuning maps.
Can't wait to see the results of the motor you are building for Rolex.
Regards,
George
Regards,
George
