Process - How to set boost level
Thinking about the possible rammifications inhearent with doing a procedure such as yours, I'd suggest not encouraging others as it could potentially damage their engine. Then again it's not my engine and if they wanna blow it up, more power to them!
I'm turning mine in A LOT and then working my way out. But I'm only gonna go up to about stock boost for now until I get the chips in. What was it that the stock computer would cut you out on? Overboost protection wouldn't allow you to go past stock very far would it?
I like to set mine and bench test the components before installing them. A little regulated air and some fittings and you can make sure everything works like you expect it before you put it in the car.
Keep the boost controler in the car, I put mine under the hood and I have boost changes with temp changes, running a linsey dp and mbc 15psi at 96 creeps to 17 at 70 degrees in 4th, I'll be moving it inside soon. Have fun with setting it up! did mine on nice back road, you will be speeding a bit or maybe a lot. Mine was the latter.
Some extra things I did: I drove my car with the wg line connected directly to the charge pipe followed by a drive with a completely clamped line (you'll want to be very attentive, obviously). This helped, giving me the ability to perceive the kind of onset associated with a far-too-overset controller before even sending my right foot into the danger zone.
I also borrow a gigantic, calibrated gauge significant to 0.5 from a steamfitter whenever I set my boost. You'll appreciate something like this vs. an autometer gauge with a giant needle pointing vaguely at a scale featuring 5-psi increment marks.
