Home Made MAF
Old 12-15-2009, 04:03 PM
carlege
carlege's Avatar
Originally Posted by Rogue_Ant
The Contour MAF might be ok for the NA, but it is not going to flow enough for the turbo guys.
-Rogue
and that would be a prob 86 951
Old 12-15-2009, 06:49 PM
pormgb
pormgb's Avatar
Originally Posted by toddk911
http://cgi.ebay.com/ebaymotors/ws/eB...d=390122396648
Injectors
Chip/Piggy back
= done and done.
I initially used this MAF but it was so big I had problems fitting it under the intercooler hard pipe, are there advantages using a larger MAF?
Old 12-15-2009, 07:04 PM
alxdgr8
alxdgr8's Avatar
Larger MAF generally means they can handle more before being maxed.
I wouldn't say there is any advantage of moving to a larger MAF so long as you aren't pegging your current one. In 99% of cases the MAF is going to be larger than any intake piping you've got so it won't be a restriction.
Large MAF's are definitely a pain to fit sometimes, especially in a blow-thru case where you want 6" of same length piping on both sides of the MAF before you step down to the smaller charge piping. I used to run a 70mm MAF in blow-thru on a turbo ford escort and it was a pain to fit the charge piping.
Old 12-15-2009, 10:05 PM
spyder348
spyder348's Avatar
Default blow thru
does blow through have close to the same value as draw thru MAF
Old 12-15-2009, 11:09 PM
alxdgr8
alxdgr8's Avatar
value? I'm not understanding what you are asking.
Old 12-15-2009, 11:17 PM
spyder348
spyder348's Avatar
Default sorry
I have been reading all day im getting confused but im down to almost getting a cobra or lightning maf custom making the pipe and running an ostrich 2.0 with tunerpro software in a laptop. i hope this works.
Old 12-15-2009, 11:20 PM
alxdgr8
alxdgr8's Avatar
That won't allow you to run a MAF
Old 12-15-2009, 11:29 PM
spyder348
spyder348's Avatar
jeez really i thought i could edit the maf code with the tuner pro. to put that maf in what essentially do i need an arc2? y am i getting the idea the ostrich and tuner pro is a good idea?
Old 12-16-2009, 12:08 AM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
That is not true.
You most certainly can run a MAF. Will it be 100% correct (without changing the transfer function code), no but it will work.
-Rogue
Old 12-16-2009, 12:18 AM
spyder348
spyder348's Avatar
does the ostrich massage the maf signal?
Old 12-16-2009, 12:55 AM
Rogue_Ant
Rogue_Ant's Avatar
No, the ostrich is like a real-time changeable chip, that you can tune...
-Rogue
Old 12-16-2009, 12:59 AM
spyder348
spyder348's Avatar
Default tunerpro
I just DL'd tunerpro rt. I geuss thats the software i need for the ostrich. Do i need the booster cable thing they sell too. I feel like thats the way to go instead of constantly pgramming chips for ur mods. Found a website where you can buy a chip burner too so you can make your own.
Old 12-16-2009, 01:08 AM
Bri Bro
Bri Bro's Avatar
Why not get a programmable MAF?
http://www.abacoperformance.com/products.htm
Old 12-16-2009, 01:13 AM
Rogue_Ant
Rogue_Ant's Avatar
That MAF is the new one that LR sells... But it is still essentially a piggyback.
-Rogue
Old 12-16-2009, 01:14 AM
Rogue_Ant
Rogue_Ant's Avatar
I'm pretty sure I explain most everything in that thread (DIY tuning)... If you have a 24pin DME, then you need the socket booster.
-Rogue
Quick Reply: Home Made MAF
