Home Made MAF
Old 01-02-2010, 08:19 PM
  #106
schip43
schip43's Avatar
What about the IAT sensor, I know the MAF's actually measure the air temp as it passes the air but I see some of the high end Maf kits add a temp sensor. I think I read in the Tuner Pro thread about flattening the DME temp compensation.
So what is the current feeling on the IAT is it an issue? I did a search and found tons of info but no real answer.
Old 01-02-2010, 09:59 PM
  #107
spyder348
spyder348's Avatar
Test run with new garrett turbo, afc neo, lightning maf, and thermal wrapped 40 series pvc intake went nice for 5 minutes @20 psi but then blew the o-ring on the seal plate. Anyone know where to find this seal. The big thin o-ring behind the snail shell.
Old 01-03-2010, 03:57 AM
  #108
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Originally Posted by 951_RS
guess I'm going to pull the trigger and get a 90mm lightning maf. Found one with housing for $40 on craigslist. What would be a better solution than using the SAFC2 as I hear it's really not the best set up
SAFC is plenty capable, why do you think it is not?
Old 01-03-2010, 03:58 AM
  #109
Rogue_Ant
Rogue_Ant's Avatar
The main thing that IAT will do is cause a drifting tune due to changes in weather... That is why it needs to be flattened on-chip.
Old 01-03-2010, 03:41 PM
  #110
schip43
schip43's Avatar
Sooo, if I add a MAf get a piggy back could I send my MAx chip in to have them flatten that function for me?
Old 01-03-2010, 05:23 PM
  #111
Rogue_Ant
Rogue_Ant's Avatar
You would have to ask them...
Old 01-03-2010, 05:36 PM
  #112
schip43
schip43's Avatar
I'll call and ask, thanks.
Old 01-04-2010, 10:29 AM
  #113
toddk911
Drive-by provocation guy
toddk911's Avatar
wow, you got that all set up and installed fast.
o ring for the turbo?
Nice use on the PVC for intake pipes. Not sure why more people don't use it. It will not hold up for IC pipes, but fine for intake and super cheap compared to any vendor sold piping.
Did you get bigger injectors? You will NEED them for anything over 15psi and that MAF.
Old 01-04-2010, 11:49 AM
  #114
spyder348
spyder348's Avatar
Up and running but not even close to looking like a nice car. No dash. No seats. lol just wanted to see what all the hype was about and now i understand these cars do have potential. Im using 72's from racetronix. paid 230$. Pvc intake is the way to go. Looks cool. Pipe is the same dia. as the maf running all the way to the turbo. Id imagine there is no restriction there whatsoever.
Old 01-04-2010, 12:07 PM
  #115
alxdgr8
alxdgr8's Avatar
I would steer clear from PVC even as an intake pipe (let alone IC piping)...it emits a noxious gas when heated which could cause corrosion of the aluminum cylinder head. Do it right...
Old 01-04-2010, 12:35 PM
  #116
toddk911
toddk911's Avatar
how did you set up the SAFC? i.e. which sensor, etc.
Old 01-04-2010, 02:52 PM
  #117
spyder348
spyder348's Avatar
I thermal wrapped the pipe. After the run felt the inside of the pipe it must have been no more than 75degrees. engine was up to normal temp. todd if your asking me i just hooked up the neo like the instructions said to. dialed in the best i could with the lightning maf. ran ok at higher speeds idling crappy and low end but thats because i didnt take more than 5 minutes messing with it. once i get the car back together for good im going to mess with the signal a lot more, also work on learning tunerpro.
Old 01-04-2010, 05:43 PM
  #118
toddk911
toddk911's Avatar
Ok. Do you have a chip for the new injectors or just control idle with the Neo?
I was not sure you could adjust idle much with a piggy back since it is open loop then and any adjustments are pulled back by the DME?? As when I have tried and watching real time wideband it adjusts but then seems to go back to the a/f. Rouge?
5 min? Nice! Goes to show that even though not "plug and play" it only takes very little time and effort to get it all tuned and for 1/10th the cost.
Old 01-04-2010, 05:49 PM
  #119
Rogue_Ant
Rogue_Ant's Avatar
Yes, idle is closed-loop. So the DME will try to correct to maintain a ~14.7:1 AFR. However, the DME will only adjust so much...
Quick Reply: Home Made MAF
