Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > 924/944/951/968 Model Specific Technical Forums > 944 Turbo and Turbo-S Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 12-14-2009, 09:48 PM   #1
spyder348
User
Default Home Made MAF
Anyone have any pics or info. about how to set up a MAF with custom pipe and sensor from another car?
spyder348 is offline   Reply With Quote
Old 12-14-2009, 10:05 PM   #2
alxdgr8
alxdgr8's Avatar
Any sensor can be made to work, so long as you know the transfer function for the MAF and then create some genuine MAF code for the DME. Don't be fooled by the thread talking about using a Ford Countour MAF (or whatever it was) by just plugging it in...not going to work "correctly". Many of the aftermarket MAF setups uses translators that go in between the MAF sensor and the DME. These "modify" the MAF sensor signal into looking like an AFM signal that the DME can understand. If you want a true MAF setup there is a lot of work involved and not something for the average DIY...hence why there are only a few people that have ever doen this (Vitesse Racing for example).
Lots of info on MAF setups, use the search and you'll find thread after thread about it.
-Alex-
1992 Porsche 968 [951 transplant in work]
(Wolf 3D V4+, J&S Safeguard, T04E 60 trim, 1000cc Injectors, 3" Fabspeed/SFR, 40mm JGS, Custom FMIC, S2 LSD Trans, and much more...)
1995 Audi 90QS (4.2L ABH V8, 034EFI IIc, and much more...)
2010 VW Touareg TDI (DD, tow rig)
1980 Honda CM400T, 2005 Ducati Monster S2R800
Past P-Cars: 1987 Porsche 944 Turbo, 1980 Porsche 924 Turbo, 1987 Porsche 924S
alxdgr8 is offline   Reply With Quote
Old 12-14-2009, 10:26 PM   #3
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
spyder,
Check out these threads - I explain the aforementioned issues:
Thread 1
Thread 2
-Rogue
-Joshua
www.RogueTuning.com
Rogue_Ant is online now   Reply With Quote
Old 12-14-2009, 11:04 PM   #4
gt37vgt
Super User
i found running 2 AFM in series (old and new )a good way to log and and compare out puts of the AFM's to get the initial set up data .
gt37vgt is offline   Reply With Quote
Old 12-14-2009, 11:27 PM   #5
pormgb
User
pormgb's Avatar
I'm running an 80mm Mustang Cobra MAF with Lindsey Mafterburner.
pormgb is offline   Reply With Quote
Old 12-15-2009, 12:24 PM   #6
toddk911
Drive-by provocation guy
toddk911's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...d=390122396648
Injectors
Chip/Piggy back
= done and done.
toddk911 is offline   Reply With Quote
Old 12-15-2009, 12:31 PM   #7
951_RS
951_RS's Avatar
Interesting todd, how did you get that to work and with what piggy back
-Drew
2006 Lotus Elise
1986 951 - t04e and supporting mods
2012 Street Triple R
951_RS is offline   Reply With Quote
Old 12-15-2009, 12:48 PM   #8
95ONE
95ONE's Avatar
Quote:
Originally Posted by toddk911 View Post
ebaymotors
Injectors
Chip/Piggy back
= done and done.
Quote:
I bought the exact same MAF once upon a time. I was going to buy a chip and piggy back from Lindsey, but the cost for the two came out to the same as buying just a chip programmed for my set up by Vitesse. Idle was flawless. Airfuel was perfect. Just never worked out as it should have due to my - Unknown at the time - Fried Dash harness feeding the wrong voltage to the ECU. Seriously frustrating part of my 951 history. Anything past 3K rpms got all screwed up. BEFORE the MAF and chip change, and after.
I still suggest the same to anyone with a currently working harness. lol
Since I'm running E-85, Does that mean my car has a Corn-Hole?
95ONE is offline   Reply With Quote
Old 12-15-2009, 01:36 PM   #9
carlege
Super User
carlege's Avatar
Suggest the "same" what is the same?
carlege is offline   Reply With Quote
Old 12-15-2009, 01:37 PM   #10
V2Rocket_aka944
Rainman
V2Rocket_aka944's Avatar
Send a message via AIM to V2Rocket_aka944
i have a contour maf wired up for a 944 afm plug and ready to go if you want for $60, youll need the software change to make it work properly though.
Spencer
1985 Porsche 944
Volvo fan upgrade / Low-mounted GM Alternator / Parallel-flow AC Condenser / Supercharger coming soon
V2Rocket_aka944 is offline   Reply With Quote
Old 12-15-2009, 03:05 PM   #11
alxdgr8
alxdgr8's Avatar
Quote:
Please don't try and sell the poor guy something that doesn't work.
-Alex-
Old 12-15-2009, 03:08 PM   #12
V2Rocket_aka944
Rainman
edited lol
Spencer
1985 Porsche 944
Old 12-15-2009, 03:33 PM   #13
carlege
Super User
carlege's Avatar
LOL Im not going to buy that.... If its not worth keeping on your car why would i want it on mine
Old 12-15-2009, 03:46 PM   #14
V2Rocket_aka944
Rainman
i never used it on my car as i dont have a late computer to use it with lol
Spencer
1985 Porsche 944
Old 12-15-2009, 03:53 PM   #15
Rogue_Ant
Rogue_Ant's Avatar
The Contour MAF might be ok for the NA, but it is not going to flow enough for the turbo guys.
-Rogue
-Joshua
www.RogueTuning.com
Tags
32812, 944, air, audi, craigslist, flow, home, homemade, housing, huntley, lfow, made, maf, mass, porsche, s4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
