GROUP BUY: Engine harness connectors:GB IS CLOSED!
Old 07-08-2010, 11:10 PM
JohnKoaWood
JohnKoaWood's Avatar
Default GROUP BUY: Engine harness connectors:GB IS CLOSED!
OK Everyone, we all have wondered... "Where can I get a new connector for ..."
Well, I have found a source, that carries a full setup of Bosche connectors, seals, pins, and boots. They also carry a few other interesting bits I have included for the purpose of this buy. (I have a request in to try to get 5 pin male connectors for those MAF users who don't want to cut up their AFM, or engine harness).
I have broken the pricing for this up a bit, First we have individual items, the connectors, boots, pins and such are individually listed, except where noted as "SET". Pay attention to the bits at the bottom of the list, as these are not for everyone, but I figured I would include them, as I know SOME people are using these! Also included is the famed "044" fuel pump. (OF NOTE: THE REFERENCE SENSOR CONNECTORS ON THE SENSOR ITSELF ARE 3M IN THE LIST BELOW)
Description ---- Price
CONNECTOR HOUSINGS - FEMALE
PLUG HOUSING 2 PIN, FEMALE ----- $1.93
PLUG HOUSING 3 PIN, FEMALE, GRAY ----- $2.33
PLUG HOUSING 4 PIN, FEMALE ----- $2.98
PLUG HOUSING 5 PIN, FEMALE ----- $3.11
PLUG HOUSING 6 PIN, FEMALE ----- $4.70
PLUG HOUSING 7 PIN, FEMALE ----- $4.33
CONNECTOR HOUSINGS - MALE
CONNECTOR PLUG 2 POLE MALE ----- $1.66
3 pole connector housing, male, (JPT) ----- $1.72
PLUG HOUSING 4 PIN MALE ----- $4.19
BOOTS
Short boot for 2 pole connectors ----- $2.36
PROTECTIVE CAP FOR 2 PIN ----- $2.49
PROTECTIVE CAP FOR 3 PIN ----- $2.44
PROTECTIVE CAP FOR 4 PIN ----- $2.98
PROTECTIVE CAP FOR 5 PIN ----- $2.93
PROTECTIVE CAP FOR 6 PIN ----- $3.86
PROTECTIVE CAP FOR 7 PIN ----- $3.66
CONNECTOR PINS
JPT Female pin up to 15 gauge wire ----- $1.20
JPT Female pin larger than 15 gauge wire ----- $1.23
JPT Female pin up to 15 gauge wire, Cold plated ----- $2.33
JPT Male pin up to 15 gauge wire ----- $1.20
JPT Male pin larger than 15 gauge wire ----- $1.27
WIRE SEALS
JPT seal, blue ----- $1.07
JPT seal, white ----- $1.07
SINGLE-WIRE BLIND PLUG ----- $1.47
ODDS AND ENDS
PROTECTIVE CAP (Fuel pump terminals) ----- $4.06
Extraction tool for JPT pins ----- $52.87
Connector GM 3 Bar MAP + pins + seals ----- $6.32
Injector Connector set EV6/EV14 USCAR + pins + seals ----- $3.00
Injector Connector ND/Sumitomo type SET ----- $3.00
ELECTRIC FUEL PUMP "044" (P/N 0580254044) ----- $180.56 (I HAVE conformation these are authentic Bosche 044 pumps made in the Czec republic, my source has been an authorized Bosche distributor for over 20 years, included is a picture taken of the pumps being offered!) Circled in the picture below is the OEM Bosche date code, which my source for these was kind enough to break down the coding for me... these are the real deal! FWIW the pump pictured (date code 002) corresponds to FEB 2010.
Next, I broke out individual connector sets, 2F indicates a 2 pin FEMALE PIN connector (Our OEM Bosche injector connection) SET (a set includes the connector, pins, wire seals, and the connector boot). (OF NOTE: THE REFERENCE SENSOR CONNECTORS ON THE SENSOR ITSELF ARE 3M IN THE LIST BELOW)
2F ----- $4.02
3F ----- $4.67
4F ----- $6.16
5F ----- $6.54
6F ----- $9.36
7F ----- $9.09
2M ----- $3.69
3M ----- $3.97
4M ----- $7.25
Lastly, I present complete engine bay connector sets, these sets are ALL the Bosche connectors in your engine bay listed for both N/A and Turbo 944 family. These sets are comprised of TPS connector, AFM connector, Injectors, Knock sensor (turbo only), ISV connector, DME Temp sensor connector, Reference sensor connectors (harness side), and N/A air valve (rear of the intake). If you want to add the MALE 3 pin connectors for the reference sensors let me know, and I will bundle it that way for you. I also priced out the 61 female pins needed for the DME and KLR plugs.
951 ----- $38.91
N/A ----- $34.70
968 ----- $47.18 (13 connectors total, by far the most!)
DME / KLR pin set ----- $13.20 (pins only, 61 in all)
Flat rate of $15 for shipping / handling PER ORDER to cover repackaging and sending to you via USPS Priority flat rate for US ORDERS ONLY, international orders MAY incur slightly higher shipping charges.
Payment due to secure your order.
Payment can be sent via PayPal to johnkoawood@aol.com. Please make sure you include in the text of your payment WHAT you are ordering, and make sure you include your address. Cash or Money order can also be accepted, however you don't have much time to get your payment to me, PM me for my address, and I will mark you down as payed on receipt.
Let me know if you have any questions, comments, or need something "special". If you have any questions regarding totals, or pricing please PM me, I will work with you to address each item you need, and MAY customize a quote specifically for you.
But hurry, this GB will be ending NOW 25 JULY 2010 and will be placing the order at that time. Lead time is minimum of 1 week, possibly longer for some items, depending on volume of our order, and specifically what is ordered.
FWIW, I am ordering a full set of connectors for my personal 951, a set for my N/A a pin tool, extra pins, and an 044 pump. My order secured the pricing for this sale. IF there are any proceeds from this sale, I will be forwarding them to PROJECT RENNWISH "Kelly's Kids". I will match the donation, with one of my own of not less than $50.
HAPPY MOTORING!
PAID:
1) Tom M'Guinn (951 engine set, extra pins)
2) Yuliang Ruan (Reference sensor complete set)
3) Pete Laches (N/A connector set)
4) CurlyDE (2x 951 kits, 1x 944 kit, pin extractor tool, 3x DME/KLR pin kits)
5) RedLineMan (2x N/A kits, 2x 944T kits, 2x extra pin sets)
6) Brian Broderick (951 Kit)
7) JoshB (2x 951 Kits, 2 DME Pin sets)
8) Techno Duck (2F and 6F connectors)
9) Mikerex (N/A Kit and 2 3M connector sets)
10) Shane Knapp (951 Kit)
11) DanG (951 Kit)
12) Christopher Ching (2 3M sets)
13) Julian Allen (4 fuel pump caps, Extractor tool, 20 each of each type of female pin)
14) Manuall Fernandes (951 Kit)
15) Kevincnc (N/A Kit)
16) CgkingTX (N/A kit and extractor tool)
17) thetintmaster (951 kit, and 2 3M sets)
18) 67King ( 951 Kit and 2 3M kits)
19) jlturpin (951 kit x2, 3M set x4 and an extractor tool)
20) Pauer Tuning (32 EV6/EV14 sets, 32 2F sets [16 short and 16 long boots], 24 3F sets, 10 6F sets, Extractor tool)
21) Keith Belcher (951 Kit, 3M kit x2, DME/KLR pin set and a tool)
22) Danny8774 (951 Kit, DME/KLR pin set, Extractor tool)
23) oazix (968 Kit)
24) dillon410021 (951 kit, DME/KLR pin set, Extractor tool)
25) Vitesse Racing (Per separate quote)
26) I8A4RE (N/A kit)
27) tommye (951 kit, DME/KLR pin set, Extractor tool, fuel pump terminal caps)
28) LUCKYJACKASS (951 Kit, 3 3M kits, 4 Fuel pump caps)
29) MikeV (2 Fuel Pump Caps, DME/KLR Pin Set, 1 6M kit)
30) E Hall (2 3F kits)
31) Curt P (951 kit and extractor tool)
32) Dave Mcgrath (per seperate quote)
33) disasterman (951 kit (x2), DME/KLR pin set (x2), extractor tool)
34) Chris White (per seperate quote)
35) Rluciano (951 Kit, N/A kit, DME/KLR set, extractor tool)
36) Chris Pacitto (per seperate quote)
37) mtnman82 (951 Kit, DME/KLR pins. Extractor tool)
JohnKoaWood is offline
Old 07-08-2010, 11:50 PM
Bri Bro
Bri Bro's Avatar
John, you have been busy. Am I getting this correctly, $38.91 gets me a engine connector set. Does this include the pins and seals?
Bri Bro is offline
Old 07-09-2010, 12:00 AM
Tom M'Guinn
Tom M'Guinn's Avatar
Right, how much for all the connectors in the 951 harness (sans the connectors at the DME and KLR I presume), plus the rubber boots, plus seals, plus the pins (with spares since some invariably get screwed up). Appreciate the effort! Sign me up.
Tom M'Guinn is offline
Old 07-09-2010, 12:08 AM
JohnKoaWood
Yup, $38.91 + $15 S&H complete engine bay connector SET, complete with Pins, connectors, wire seals, and boots, Delivered to your door. Sorry, but I AM working on DME and KLR connectors, don't have them tracked down just yet.
I will even throw in a few spare pins for each set... Add another $13.20 and you can get enough pins to completely repin the DME and KLR connectors in your car now... imagine all new harnesses!
I need the connectors as I am going stand alone, and am building my own harness, all brand new... figured as the pricing was good for the pieces I would offer it up to everyone out there with cracked TPS boots / connectors as well!
I have used some of these, but the catalog recently got updated... and expanded!
Old 07-09-2010, 12:37 AM
gt37vgt
gt37vgt's Avatar
John have you got your crank trigger stuff all sorted out as i can double up on my set up when i machine my trigger wheel..?
doe's this great sorce have other delco mitsu nippon tyco etc plugs ? is there a bosche workshop kit available with the tools pins and boots so one can determinate repair and recycle I'm also after some 2 pin male plugs that would effectivly simulate and injector..
nice work john
gt37vgt is offline
Old 07-09-2010, 12:52 AM
RolexNJ
RolexNJ's Avatar
Great job John! Let's make this stick for a while...
RolexNJ is offline
Old 07-09-2010, 12:59 AM
JohnKoaWood
nice work john
2 pin males are above at $3.69 a set, or $1.66 for just the connector... LED works great for this (12V,it will flicker)... could even wire 4 of them up to a panel to look at in the driver seat during cranking!
Hmmm, new diagnostic tool.....
I will PM you about a repair "kit"
Old 07-09-2010, 04:16 AM
porschefig
porschefig's Avatar
So, all I'd need is 61 different colored wires : and to reuse the KLR and DME pins and I'd have everything I need to make a new engine harness? For ~$68 shipped.
Wow, the pin tool costs almost as much!
porschefig is offline
Old 07-09-2010, 10:06 AM
JohnKoaWood
Well..another $13 and some change and you can have new DME and KLR pins... and I am working on sourcing the wires, my only problem is my EMS is coming with different wire colors than the OEM Porsche colors... I will update the GB if I come up with a wire solution....
the different colors is for ease of assembly and repair at the end of the day, you COULD use just one color, but it becomes tricky keep them all straight!
Old 07-09-2010, 12:49 PM
minho78
minho78's Avatar
John better yet, why don't you make a couple of new harnesses, and sell them to rennlist menbers at a profit. For example it costs 100 in parts, you sell it at 300.
minho78 is offline
Old 07-09-2010, 02:51 PM
CurlyDE
CurlyDE's Avatar
I'll be in for two 951 complete sets, the pin extraction tool, and at least one set of DME/KLR pins. I'm waiting on my neighbor to let me know if he wants a DME/KLR pin set also ... should have payment sent tonight.
I might be interested in wires and the male connector for the AFM to MAF harness ... if these items work out.
CurlyDE is offline
Old 07-09-2010, 04:20 PM
JohnKoaWood
OK, everyone.. ALL Pms have been replied too (whew).
I will keep eveyone updated on the wires AND Male AFM plugs... I am keeping my fingers crossed!
WOW, this has been quite the interesting thread... interesting indeed!
Thanks to everyone for the response on this, and I can't wait to see where it ends up by the end of the week!
John
Old 07-09-2010, 04:55 PM
CurlyDE
CurlyDE's Avatar
kk, payment sent. I'm in for 2x 951 kits, 1x 944 kit, 3x DME/KLR pin kits and the pin extraction tool.
CurlyDE is offline
Old 07-09-2010, 05:47 PM
MM951
MM951's Avatar
Would be nice backup for my mothers 86 NA and the only original connector in my engine bay is my TPS... hmm..
MM951 is offline
Old 07-10-2010, 09:16 AM
supes6
supes6's Avatar
wow.. $10 for the TPS plug vs. lindsey sells it for $69.95. that's some serious markup on their part!
supes6 is offline
Quick Reply: GROUP BUY: Engine harness connectors:GB IS CLOSED!
