Guess what I dyno'ed at today
Old 07-24-2010, 02:58 PM
DDP
Rocket Scientist
DDP's Avatar
That's not nice.
Old 07-24-2010, 04:36 PM
Techno Duck
Techno Duck's Avatar
Spill the beans Mike, considering the similarities between our cars im very interested . I am going to hope atleast 325whp @ 17psi.
Old 07-24-2010, 07:07 PM
awilson40
awilson40's Avatar
No matter what it was, it wont be enough
Old 07-24-2010, 07:08 PM
333pg333
333pg333's Avatar
What size is this turbo compared to a GT series equivalent?
Old 07-24-2010, 07:16 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
About the same size as the GT35R... A slightly bit smaller though.
Old 07-24-2010, 07:36 PM
MM951
MM951's Avatar
Once my coworkers leave I'll hop on my laptop and upload the chart.
I am quite dissapointed in my results but have my suspicions as to what is killing my output. At least now I know my butt dyno was not lying when I felt my car has been slower....
fast951
fast951's Avatar
I'll take a guess, of course if it's as hot when you dynoed as it is today, subtract 200rwhp across the board..
10 psi - 240-260
17 psi - 310-330
19 psi - 320-340
John
Email
www.vitesseracing.com
Old 07-24-2010, 07:40 PM
333pg333
333pg333's Avatar
Oh, ok. For some reason I thought it was smaller than that. So sort of halfway between a 3076 and a 35r. Actually a good size for some applications I think.
Old 07-24-2010, 07:42 PM
MM951
MM951's Avatar
Fast951: Your numbers are about what I was hoping for, although I was expecting less due to misc exhaust leaks possible dead knock sensor (I can not find a new one that ohms out! Etc
Once I post the graphs I'd love to hear any ideas or thoughts.
Old 07-24-2010, 08:46 PM
Van
Van's Avatar
Mike, in addition to my thinking your O2 sensor is suspect, I was also thinking you might/could have a faulty engine temp sensor.
Old 07-24-2010, 09:28 PM
gcb951
gcb951's Avatar
Well?
Old 07-24-2010, 10:56 PM
MM951
MM951's Avatar
I have the file in PDF format attached. If it doesn't work I'll try to take a screenshot and make it a JPEG so I can attach it easier.
I'm suspecting my knock sensor, temp sensor, TPS, intake/exhaust leaks, or false hopes for the low power. What interests me is the powerband seems much different from Vans car. My car makes LESS torque (and at a higher rpm) and makes peak HP at a lower rpm. Also, it really doesn't build power past 5K rpms, when I distinctly remember how before it would just be increasing pull all the way to the rev limiter...
Also, we did a run at 3/4 throttle and IRRC it made the same torque and almost the same HP IRRC. It confirms my butt dyno feelings that car feels just as fast at 75% throttle vs 100%. The car also used to have a distinct "power noticably increasing towards redline" feel that is no longer there. Well, I guess you guys will see for yourself. I do know the car used to be much faster, hell, my little 12 year old sister could tell the difference.
FWIW, all sensors (except the O2 sensor) are between 3,000 and 54,000 miles old (~3 weeks - 2 years)
File Type: pdf
Old 07-24-2010, 11:16 PM
JohnKoaWood
JohnKoaWood's Avatar
Not bad, but there is obviously something to sort out.... good luck, and thanks for posting it up, I will be sure once my car is back together to do a full disclosure on build, with the tune package being the only thing I will hold back, as I am working from a blank sheet of music as it were..
Good luck, and I look forward to going shooting next year at the fest!
Old 07-24-2010, 11:47 PM
mudbuddha
mudbuddha's Avatar
Mike - Definitely low for this type of turbo at those psi especially for a dynojet. I am thinking freeing up the exhaust, hard pipes, and check for leaks etc. will give you better numbers. Is the compression ok?
Old 07-25-2010, 12:04 AM
Magnoliarichj1
Magnoliarichj1's Avatar
hmmmmmm.
Quick Reply: Guess what I dyno'ed at today
