Project Thread
Project Thread
I was going to wait to start a project thread until I was a little furthur along, but I had a few requests to post. My car is a real mess currently, but I guess it has to get worse before it gets better.
Following is a list of some of the car's planned upgrades.
Engine
-DTA s60 pro Standalone EMS
-K 27/6 turbo
-COP ignition (coil on plug)
-replaced hoses on A/C lines.
-PICO fuel injectors
Brakes and suspension (86 944T)
-Big blacks
-87 hub and spindles
-adj camber plates
-F Koni ADJ w/ 400lb springs R Koni coilovers w/ 600lb (had T-bar delete done on aboandoned track project, have not deleted yet, may go w/ helper springs)
-MO30 F&R swaybars
-968 castor blocks
-Waiting on Custom A-arms to finish R&D
Interior
-rollbar and harness.
-PLX Display in tach (if works out)
-custom seats w/ shoulder and sub harness mounts.
-rear seat delete
-new steering wheel (either 930 or quick disconnect)
Exterior
-new paint
-968 style rear wing
Here is where i currently am. Have the engine in after repsraying the engine bay. Hope have running in a month or two and on the track early next year.
Steve
Engine
-K 27/6 turbo
-Big blacks
-adj camber plates
-MO30 F&R swaybars
-968 castor blocks
Interior
-rear seat delete
Exterior
-new paint
Steve
Yeah, your right. It will look much better when the rotor delete plug is installed.
Thanks again.
Really I am just ready to get it back on the road, been nine months. Have not really been much accomplished on the car this year. Been alot of set backs and moving componets form track project to this car. But its on it now.
Steve
Thanks again.
Steve
Ha, Guess so, it feels like a mess to me w/ about 40 projects going on at the same time. ALso progress is so slow, since I had to have 2 hand surguries and 3 months of antibiotic threrapy for a strange mycobacterial infection that set up in my hand. I guess I am fortunate to be progressing at all.
Anyway, starting on the igniton system. I had planned on running a single larger Bosche coil, but mounting it was going to be ugly w/ me retaining alot of stock stuff. Also I saw Jasonlp's setup from Vic which prompted me to move to a coil per cylinder setup as well.
I have mocked up a template that I will have someone fabricate me up a Al. mounting bracket. These MSD coil specs seemed to be agreeable to Wayne @ TPG, and the design will be able to be mounted cleanly on the cam tower. There obviously will be four coils, but this is as far as im am going.
Steve
Steve
New I am not really sure, you could contact Wayne @ TPG.
http://tpgproducts.com/index.html . I purchased an complete engine he was selling at the time and it came w/ the DTA standalone. It was plug and play as the wiring harness came with the engine. I am changing a few things , so I will need to have a new tune. It seems like a nice setup and can't wait to finish.
I am hoping to have running and ready for a tune in a couple months.
Steve
Steve
Went ahead and mounted them, to get a better idea of the bracket design. May just have a local welder fabricate it for me.
Also needed them mounted so I can start wiring up the harness which is about half done.
Looking from the front, the coil tip is about level with the top of the fuel dampner. Any one have an idea with plug wires if I will have a clearance issue??
I will probably have magnacor make me a set of plug wires, not sure if they have any connectors to help clearance issues.
Steve
Steve
If you’re not going to use cruise control, (I do see the cable though), mounting the coils in place of the CC module is an option. Also sending the battery out back or using a smaller battery would free up space. Either of these options would at least keep the coils away from the headers.
I rather keep the coils close, so not a long run of plug wires. I am not anticipating a heat issue from the headers, they are coated to keep the heat down, but that is a good point, and I will check w/ MSD about heat tolerances.
Steve
Went by welder yesterday and had a bracket welded up, not too pretty but will get the job done. When i was working on the template, I relaized it would need to be designed on the car. Will finish lining up the coils and having enough glearance for the bolts, before having the nuts welded in place. Should have finished today, and get ready to have the intake back on.
Steve
Steve
Nice project!
Those are not however coil on plug but coil near plug. Coil on plug is where the coil sits directly on the spark plug without a plug wire.
BTW your coils are mighty strong!
I will need to get back to the welder and notch the back of the bracket and flush mount the nuts, as two of them contact one of the cam tower plugs.
Glad I added the fire wall port, to get the ignition harness though and other harnesses such as Plx device's. Opening is a bit larger then the size of a quarter, and filling up. Working on adding a PLX fluid temp sensor that I will mount in the oil level sender spot.
Steve
