Gauging interest in Oetiker clamp kit
They are a lot cleaner looking and take up so little room and they are supposed to hold better ( at least that's their pitch ) ( constant tension, 360 degree hold yada, yada, yada If you go to their website they give ya a whole sales pitch... which needless to say, I bought
There are sooo many clamps, but the better the fit, the better the seal. I like to have at least two to choose from and sqeeze on the tightest. I have a list of 22 (may have something to do with the amt of compartments in the storage box) so a better price would help offset the cost.
Steve
If you have that contact number, I would appreciate it, for the packs of 10.
Steve
Steve
I contacted him through email he responded back in 10 mins ...(On the weekend!)
His name is Tom Hargrave thargrav@hiwaay.net ( he sells home brew kegging equipment)
The website is http://www.kegkits.com/Merchant2/mer...P&Store_Code=W
Just remember, as I stated earlier, the only problem is that he doesn't carry sizes above 27.1 ( if I remember from your previous thread you were looking to do some bigger lines ? ) I bought his sample set, because I needed a number of sizes, and since it was just me buying ... I didn't know what to do with the rest of the clamps? I might be interested in splitting some of the sizes with you ... but since I bought the sample pack I don't think I need that many?
Hope that help
Regards
Ed
Thefu
Hi Steve
Hope that help
Regards
Ed
Hope that help
Regards
Ed
http://www.aircraftspruce.com/
If you need larger sizes, you'll want to go with the stepless screw clamp. You can get these through aircraft spruce.
I actually wanted to get those clamps for that front water pipe that comes off the forward water neck ... that damn pipe always leaks
Best regards
Ed
Thefu
Thanks... I saw your earlier post on that in the other thread ... I was looking for a 31.1?, that's used on the ISV hose ... I think that type of clamp will have a hard time fitting there ...
Best regards
Ed
Best regards
Ed
Man I would love to see some shots or your engine with those clamps if you can post'em
Best regards
Ed
Thefu
That engine is long gone. My only remaining 944 is an all-original '89. I'm trying to keep the OEM clamps on that, but it's hard to find those old Oetiker screw-drive clamps that were original to the car and I don't really like re-using old clamps on new hoses.
Hope that helps
Regards
Ed
Edit Oooppss I guess you were referring to DrZ1 .... sorry
Regards
Ed
Hi Steve
Hope that help
Regards
Ed
Hope that help
Regards
Ed
Thanks Ed,
Big help, I am going to try and contact him today or tommarow.
Edit : I just checked out his website, and when I called Hydralic supply and gave them the part numbers, they were actually less and you can order what ever quantity. On the downside, the website is harder to navvigate, but CS is helpful.
Steve
