Where to Buy a Curtis Impulse Counter?
Old 04-28-2014, 07:41 PM
refresh951
refresh951's Avatar
Originally Posted by Sixline
Well they have a few different models and a bunch of sub-models all at different prices. I can only guess which one would be the best option.
I think this is it:
https://store.redlion.net/store/come...idProduct=1280
Cost is $74 which is not bad. We need to have Rogue or Tom M look at the data sheet and make sure the counter is capable of capturing the pulse.
Old 04-28-2014, 08:14 PM
Sixline
Sixline's Avatar
This is Eric's response when I asked him how he wired it.
Hey Eric,
I saw that you used a Red Lion CUB counter as a knock counter and was curious how you wired it. I tried to do some searching and the only thing I found was someone mentioning the use of a NPN transistor.
Thanks,
Sixline
I wish I could remember exactly. But, yes I wired a transistor between the signal and counter. If I find my sketch I drew I'll let you know. I think the counter needs a 12v trigger, so I used the dme output 5v knock signal to trigger the transistor to open the 12v circuit to the counter. I also needed to add a resistor to limit the current to the transistor to stop it burning out.
I have to say though it does work very well.
Cheers
Eric
Old 04-28-2014, 08:39 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Originally Posted by refresh951
I think this is it:
It doesn't look like it would be fast enough to reliably catch the knock events. The data sheet says 60Hz max, while the knock pulse is around 1000Hz.
Old 04-28-2014, 08:45 PM
Sixline
Sixline's Avatar
You might of been looking at the wrong datasheet. High frequency mode is 5kHz.
Edit: http://www.redlion.net/Products/Grou...Docs/01025.pdf
COUNT INPUT:
SNK mode (DIP switch 1 off, internal pull-up to battery)
VIN High Min = 1.25 VDC; VIN Low Max = 0.45 VDC
IIN Max = 5 μA; VIN Max = 3.6 VDC
Count Speed: (count on negative edge)
High freq mode (DIP switch 2 off): max 5 kHz @ 50% duty cycle
Low freq mode (DIP switch 2 on): max 50 Hz @ 50% duty cycle
SRC mode (DIP switch 1 on, internal 20 kW pull-down to common)
IIN Max = 5 mA; VIN Max = 28 VDC
Old 04-28-2014, 09:00 PM
Rogue_Ant
Rogue_Ant's Avatar
I probably was looking at the wrong one - I just took a quick glance.
5kHz should be fine for picking up the knock events.
Old 04-28-2014, 09:10 PM
Sixline
Sixline's Avatar
I added the link to the correct datasheet.
What would be the recommended way to connect it? According to the bottom of the datasheet both of the high frequency modes are showing the use of a transistor.
Old 04-28-2014, 09:13 PM
Rogue_Ant
Rogue_Ant's Avatar
Page 3, "current sourcing output."
The transistor is in the KLR.
Old 04-28-2014, 09:21 PM
Sixline
Sixline's Avatar
So it looks like when the voltage gets above 1.25VDC and then below 0.45VDC it makes a count. Is that correct?
Old 04-28-2014, 09:37 PM
Rogue_Ant
Rogue_Ant's Avatar
Yes, that is just the built-in hysteresis to prevent false triggering.
Old 04-28-2014, 09:40 PM
Sixline
Sixline's Avatar
So is there a maximum you would want to go on the counting speed? It looks like the CUB7 counter is cheaper but is 8 digit and counts at 10kHz, same low voltage input.
Old 04-28-2014, 09:42 PM
Rogue_Ant
Rogue_Ant's Avatar
Assuming it is also edge triggered, then you can have a faster counting speed without worry.
Old 04-28-2014, 09:47 PM
Sixline
Sixline's Avatar
Yeah it is count on negative edge.
Here is the datasheet for it. http://www.redlion.net/Products/Grou...Docs/01024.pdf
65 bucks for the backlit one with free 2 day shipping.
https://www.mrosupply.com/product/86..._Lion_Controls - Green
https://www.mrosupply.com/product/86..._Lion_Controls - Red
Old 04-28-2014, 10:16 PM
Meine44
Meine44's Avatar
So what is our best option at this point?
Old 04-28-2014, 10:30 PM
Scott H
Scott H's Avatar
Have you guys checked eBay yet? I'm sure there's a cheap Chinese solution on there.
Old 04-29-2014, 01:40 AM
Meine44
Meine44's Avatar
Forget cheap Chinese electronics, you'd be better off trying to listen for knock and counting on your fingers.
GTFO
Quick Reply: Where to Buy a Curtis Impulse Counter?
