Factory boost gauge ?
Old 03-23-2011, 10:33 PM
Andral951_S
Andral951_S's Avatar
Question Factory boost gauge ?
I am in the process of building a 968 turbo cabriolet and want to make the factory boost gauge work, Could someone point me in the right direction ? TIA
Old 03-23-2011, 11:02 PM
Darwantae951
Darwantae951's Avatar
It is controlled via the DME/KLR. On turbo cars there is a small plug where the Tach signal/oil level among other things is sent out. That as far as I know is where the boost signal is sent to the dash gauge. Altho it isn't that accurate and most choose to run an aftermarket gauge with a greater resolution.
Old 03-23-2011, 11:13 PM
Andral951_S
Thanks Darwin, I am looking for wire colors or pin numbers and which of the 3 plugs on the back of the cluster to add the wires to ! I spent today chasing wires and making custom manual harness. Originally car was a tiptronic.
Old 03-24-2011, 01:03 AM
Tom M'Guinn
Tom M'Guinn's Avatar
This thread may help -- it's the red-white wire in the red 4-wire connector under the glove box, but I've never traced it up to the cluster. I'm sure it's in the wiring manual...
https://rennlist.com/forums/944-turb...e-control.html
Old 03-24-2011, 01:23 AM
Darwantae951
Just to add to Toms post, in early Turbos (86) it is a 4 wire connector but in later turbos it is a 7-8 wire connector (not sure if it started in 87, but my car was the 7-8 wire connector).
Old 03-24-2011, 01:24 AM
Ben951S
Ben951S's Avatar
Please run a second gauge with factory one.
Old 03-24-2011, 08:58 AM
Andral951_S
Thanks guys
Old 03-24-2011, 09:01 AM
Andral951_S
lol, I do have a second gauge. I just want to keep the cabin as functioning as possible.
Old 03-24-2011, 12:02 PM
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
The 968 electrical system is quite a bit different than a 951. Are you going to convert to a 951 gauge cluster? You may run into some interesting issues if you do that.
What are you running for engine management? The 968 DME is way different than a 951…..
Old 03-24-2011, 12:09 PM
Andral951_S
I am converting to a 951 cluster, 951 engine management.
Old 03-24-2011, 12:13 PM
Andral951_S
I already changed the front body harness ( engine bay) to a 951 harness, I am trying to retain as much as possible of the 968 body harness.
Old 03-25-2011, 08:52 AM
Andral951_S
Second day of dissecting the turbo harness... Maybe I'll practice my bundle lacing when I am done.
Old 03-25-2011, 09:45 AM
Chris White
Rennlist Small
Business Sponsor
I had to modify your avatar to reflect your project…..’casue it takes some ***** to attempt what you are doing!!!
BTW – take note on the ignition system (968 & S2 use a different ignition power set up) – the A/C system is also powered differently, in the 968 the DME controls the A/C clutch.
Old 03-25-2011, 09:54 AM
Andral951_S
Thanks for the new avatar. When I am done with it, it will be all turbo ignition system, as I did for the manual transmission harness ( 5 wires).
Old 03-25-2011, 10:09 AM
JohnKoaWood
JohnKoaWood's Avatar
That is some funny **** Chris... Nice Photoshop!
Quick Reply: Factory boost gauge ?
