Turbo and Boost for 500-550hp?
Hi,
what turbocharger would you prefer for a 3l 8V 500rwhp project?
Garrett GT30r/GT35R - Turbonetics GTK-550/650 ?
How much boost i must drive? More than 22PSI ?
Thanks for all information.
Cheers,
Sven
Cheers,
Sven
Streetable, why not? My friend drives an Audi 2.2l, GT4094 0,96A/R, 100mm intercooler, 84mm Downpipe, 850er Siemens Deka, 2xBosch-Motorsport 413er Pump (200L@8bar) .... with only one pump and lower boost he had 650PS.
slowly startet: 3,9sec,
100-300 20sec.
1/4 with GT35 11,1sec..
100-300 20sec.
I have only experience with my GT30/KKK hybrid, but I have always felt that a 3.0 engine was too small for getting a GT35 working in its efficiency area on a load/rev engine range area wide enough to offer a satisfying drivability/yield ratio.
If you consider a 4094 with a .96 hotside on 2.2 ,streetable then your version of "streetable" is far different than many around here.
Personally I'd try to use a gt30r for best response. Unless you don't car about the powerband then go wild
It's all relative. I'd go GT40 if I were into just bigger power on pump gas. I'm not. My GT30R nailed it. I don't think I could have ever been happier, which is why I'm going with a slightly stronger version of the same turbo mildly adjusted for a 3.0 instead of the 2.5 I had. \\
I'm expecting 500 whp.. or more, but It won't be living there. And that's the beauty of a turbo. you can CONTROL the amount of boost. So, rarely would I need to stress out the motor at full boost giving me max hp. The turbo won't be in its efficiency range at 500hp like Thom stated, but who cares.. I would rarely be in that boost level anyway. BUT.. if I needed it to show off, it would be available. Super Saiyan 2. imadork.
1 Post
To make a reliable 500 whp on pump you need a modern turbo w a billet wheel, Precision, GTX, FP etc appropiate header,crossover, downpipe , exhaust combo , significant headwork/cam and meth with a Aquamist Hfs and last but not least think outside of the rennlist vendor box....also need logging capabilities to monitor A/f, knock, timing ,injector duty etc in real time.
Btw don't be afraid of boost, the only way you increase power in a Otto engiine is a increase in cylinder pressure either thru comp or Fi.....done right you should see a spike to 25/26 and settle for 22/23 to redline.
Then you don't need as much cylinder pressure as you say.
The gt#s are a reference more for the compressor side, and just because they're either a little bit on the small side or the big side, that doesn't necessarily determine the power characteristics/powerband. That is determined more by the hotside. That being said, looking at compressor maps, only the biggest gt30s will flow enough air, on the compressor side, to accommodate the above power goals. Otherwise, a gt35 (I think the 600 crank hp is a misprint; they're all good for 650)
Yes, I agree with Sid. When you look at charts of a lot of these later model modded cars they have very steep and late spooling power curves. They'd probably look at some of ours and think they were diesels.
you need header,crossover, downpipe
exhaust combo
Now i need only the perfect turbo I think about the GT35 or the Turbonetics gtk650.
