3" to 2.5" cat back adapter plate
I recently picked up a SFR 3" testpipe w/cat and wanted to still use my B&B 2.5" cat back muffler. Didn't like the idea of the exhaust flow having an abrupt step down from 3" to 2.5", so I made this 3/8" thick 304 SS adapter plate to better smooth the transition. Sent a drawing to Stainlessworks.net on Monday and got the plate delivered by FedEx on Thursday. Hit it with a die grinder to make the chamfer today. Will have a 2.5" copper gasket on back side and 3" copper gasket on front side. Going to put it on this weekend. Is this cool or crazy?
Eric
Eric
I'm good with the setup. I have to run a cat in Austin, so SFR 3" w/Magnaflow cat is about the best I can do and still be legal. Figure necking down to 2.5" shouldn't give up too much since I have a cat restricting the flow further upstream. Also, like the idea of 2.5" cat back muffler may be a bit quieter than a 3". I like the compromise in theory. Will see how it works out when I hit the road.
Have a Vitesse AFM chip for stock injectors and FPR, good up to 15psi. Original K26/6. CV for boost control. Putting on a Lindsey DP wastegate in single port mode at same time as the SFR test pipe w/cat. Next step may be a MAF for better drivability. Not planning on pushing it too much further than this.
