Transaxle explosion at first ever DE!
Old 05-09-2011, 12:38 PM
RobE952
RobE952's Avatar
Default Transaxle explosion at first ever DE!
Ok, so maybe there wasn't an explosion but there was definitely some carnage.
I have owned my 88 Turbo S for about 8 years and have been looking forward to tracking it for most of that time. I have spent the last several years with that as my goal and have finally built it into, what I thought, was a strong and reliable machine.
So I attend my very first track day EVER yesterday. It was basically a DE to get my WCMA Solo 1 licence. I did about 15 laps with an instructor and had a great time. My heal-toe downshifting was far from perfect but we noticed no strange noises, smoke, or smells all day. Then as I was driving away from the track I noticed a faint grinding noise from the rear. I was thinking I might have a rock in my caliper or toasted a wheel bearing then I see the oil spray all over the back of my car, and oil dripping from my trany.
Upon closer inspection I found that the rear "cap" of the transaxle had been blown out and I pried a half of a shattered bearing carrier out of the back!
I have not had time to inspect or take pics yet. So only based on the above I am wondering, how bad does this sound? Is my cup trany toast or is there a chance of rebuilding?
Old 05-09-2011, 12:40 PM
PorscheDoc
PorscheDoc's Avatar
It's bad. Had a buddy have the same failure happen to him on the street in his S2. Talk to Kevin Gross.
Old 05-09-2011, 02:05 PM
86 951 Driver
86 951 Driver's Avatar
Its pretty rare from what I have seen for one of these trans to fail. Good luck with the fix.
Old 05-09-2011, 04:04 PM
Josh B
Josh B's Avatar
What fluid where you running in the trans and when was it last changed?
Old 05-09-2011, 04:15 PM
RobE952
RobE952's Avatar
From what I remember, it was RedLine fluid. I can't remember the viscosity, but it would have been what was recommended in the manual for the LSD.
It had last been changed 4-5 years ago (!) but I bet it had less than 10,000km (6,200mi) on it.
Old 05-09-2011, 04:32 PM
User 52121
User 52121's Avatar
Guess this is a good place to ask what the recommended fluid brand/type/weight would be for track'd 951's....
Old 05-09-2011, 05:47 PM
User 41221
User 41221's Avatar
#1, +1 on Kevin Gross. He built my tranny and I have been WAY more than pleased with it.
#2, regardless of what fluid you run in it, change it once a year and it will go a LONG way towards keeping your gearbox happy for a long long time. Talk to Kevin about this if you don't want to take my word for it.
#3, as long as its suited for limited slip, it shouldn't really matter what name is on the label if you are changing it regularly. Kevin told me he runs Mobil One and has no problems with it, or Castrol. Redline is fine as well.
Old 05-09-2011, 06:32 PM
adrial
adrial's Avatar
I had the exact same failure in my trans ... and I don't abuse it.
The good news is that it is a pretty easy fix, I had a mechanic do it back in the day -- but it was not expensive. I'd say maybe $200-$300 including labor?
Old 05-09-2011, 07:05 PM
blitz951
blitz951's Avatar
Rob and Adrial, how many miles on the tranny's when they failed?
Old 05-09-2011, 08:34 PM
Jeff N.
Jeff N.'s Avatar
Sorry to hear it!
How dry was the transaxle before the incident? I wonder if you weren't low on fluid due weepage. When was the level last checked?
Old 05-09-2011, 09:04 PM
hp18racer
hp18racer's Avatar
For a dedicated track car, do you have an idea in terms of track hours for changing the fluid? My Chump Car has about 52 hours track time in 2 races + a DE.
Old 05-09-2011, 09:10 PM
john durdin
john durdin's Avatar
THERE IS A REINFORCING PLATE AVAILABLE, TO PREVENT THIS PROBLEM FROM ONE THE v8 CONVERSION KIT COMPANIES . JOHN
Old 05-09-2011, 09:20 PM
Bri Bro
Bri Bro's Avatar
Do you have an oil cooler on the trany? That can make a big difference in oil temps. One way is to smell the fluid, it will have a bad smell if it gets too hot. I change mine in the spring and then keep a nose on it the rest of the year.
Old 05-09-2011, 09:41 PM
xsboost90
xsboost90's Avatar
swepco only for me.
Old 05-09-2011, 09:42 PM
hp18racer
hp18racer's Avatar
My GT car has a cooler but not the chump car. I'll remember the smell test, thanks!
Quick Reply: Transaxle explosion at first ever DE!
