GTX3071R or GTX3076R - 2.5 Litre?
Old 05-09-2011, 05:45 PM
Penguinracer
Penguinracer's Avatar
Smile GTX3071R or GTX3076R - 2.5 Litre?
I'm looking at a GTX3071R with a .82A/R hotside for my 2.5 litre which will be running a N/A head with 2mm oversize valves, cam & standalone. I'm retaining hydraulic lifters & want to maintain the stock rev range.
Should I be looking at the GTX3076R with a .82A/R instead or will this be too laggy?
The guys at the turbo shop recommended a .82 hotside on the GTX3071R stating that a .63 would strangle it too much.
I want the car to be streetable with the odd trackday. I suppose I'm wanting at least the mid-range response of the stock car but with the added bonus of much more top-end.
My goal - something which can scare a GT3 for a few laps on a DE day & then drive home!
Old 05-09-2011, 06:07 PM
Paulyy
Professional Hoon
Paulyy's Avatar
I've ordered a GTX3076R with a TiAL .63 a/r but i wont get it untill i get home from my holiday. which im in London, England right now
Old 05-10-2011, 12:24 AM
xtaC
xtaC's Avatar
I don't have anything to add, but I am in an identical situation, and am interested in hearing about this one too.
Old 05-10-2011, 04:51 AM
Duke
Duke's Avatar
What boost and power levels are you aiming for?
You should do the GTX3071R with 0.63 a/r unless you're aiming for 20+ psi.
Old 05-10-2011, 05:13 AM
333pg333
333pg333's Avatar
From personal experience with a GT3076 .63 and .82 on a 2.5L with n/a head, cam, exhaust, front mount...but not bigger valves...I found that the .63 was a great street and occasional track turbo and the .82 was more a track turbo running a bit of boost. Depending on how high you want to rev and how much boost you want to run would help in advising you. Maybe the 71 with an .82 might just be a good option.
Old 05-10-2011, 06:24 AM
Penguinracer
I'm looking at running modest boost in the interests of durability/reliability but perhaps a little more than the norm, say 18-22 PSI.
I'm looking to run to the stock rev limit but will be running a SFR front mount, SFR N/A head, cam & Motec & the appropriate fueling system.
There's then the the matter of the cross-over between a 71R running a .82A/R & 76R running a .63 hotside.
Will the 71R give me plenty of head-room for my set-up?
Old 05-10-2011, 06:34 AM
333pg333
333pg333's Avatar
I would think so. You have to google up those turbos and read what other's are getting. There's a pretty good write up on another forum, EVO or Scuby I think. Have to dig around a bit. Not a lot of experience on the GTX series out there yet.
Old 05-10-2011, 07:04 AM
Paulyy
Professional Hoon
Paulyy's Avatar
GT vs GTX
I've posted this before but these guys pulled some dyno runs with gt and gtx turbos and .63 vs .82 runs. some good info there. i havnt searched for any other info latley yet.
Old 05-10-2011, 08:29 AM
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
The entire GTX line is pretty much unattainable. Be prepared for a long wait if you want one.
I have an interesting alternative I am trying out for a 3.0 engine – it’s a GT35 with a new billet inducer wheel and a Tial hot side housing that is supposed to be similar to the GTX35 with a little better spool up……and its available now (if you have the right connections!)
Old 05-10-2011, 08:38 AM
Thom
Thom's Avatar
Turbine A/R?
Pics?
Old 05-10-2011, 08:53 AM
Penguinracer
Question BW EFR 7670 & 8374
Chris, my turbo guys reiterated your comments regarding availability of the GTXs, but as I'm not in a hurry that's not an issue for me.
They did recommend I look at the Borg Warner EFR turbos which they felt had a number of class-leading features & were pretty cutting edge.
I'm assuming the EFR 7670 (rated at 375 - 600 bhp) is comparable to the GTX3076R but the EFR 8374 (475 - 750 bhp) is getting up there in exducer & turbine wheel diameter for a tuned 2.5 litre.
The EFRs have a T4 mounting flange, internal wastegates & BOVs, ceramic dual BBs, stainles steel turbine housing, water cooled & can have a speed senor fitted & a V-Band outlet.
Has anyone had any feedback on these units?
Are their physical dimensions feasible for our cars?
Tim
Old 05-10-2011, 08:55 AM
Duke
Duke's Avatar
Tim
Probably not, they are huge.
EDIT: With internal WG they definately won't fit.
Old 05-10-2011, 10:35 AM
Penguinracer
Paulyy, thanks for the link to the Scooby site. Perrin seemed to think (on a 2.5 litre) that the spool rates of the 71R & the 76R would be comparable given they share the same turbine wheel, even though the 71's compressor wheel is probably marginally lighter, he felt this would make an insignificant difference.
His reasoning was that if the spool for the 71 & 76 were almost the same you'd be better to go for the 76 for more headroom.
Old 05-10-2011, 11:00 AM
blade7
blade7's Avatar
You'll need another holiday when you get home after the return flight.
Old 05-10-2011, 02:21 PM
Paulyy
Professional Hoon
Paulyy's Avatar
Same reason im going for the gtx3076r, gives expandability and you wont leave the efficiency islands no matter how much boost you run.
i actualy left london today and now in paris. but yes i am not looking foward to that flight home.
Quick Reply: GTX3071R or GTX3076R - 2.5 Litre?
