Seeking assistance re: coilover springs
Old 08-04-2011, 08:06 PM
V2Rocket
Rainman
V2Rocket's Avatar
Default Seeking assistance re: coilover springs
Hi,
I am searching for information on a set of 2.25" rear coilover springs I picked up.
They are black in color with a single blue paint mark. They are about 8-3/8" long uncompressed and are very clean without real signs of wear, so they may be in "new" condition. There is no part number to be found.
They appear to be a progressive spring type as the coils get tighter towards one end, and the wire decreases in diameter from ~10.5mm at one end to ~8.1mm at the tighter-coiled end.
In searching the archives here these descriptors have me loosely convinced that they may be 1987+ Turbo Cup springs. In this thread, about halfway down the page is a picture and these springs look just like those pictured.
https://rennlist.com/forums/944-turb...p-springs.html
Anybody got any suggestions to identify them? One person has already supported the possibility of them being Cup springs.
Old 08-04-2011, 10:01 PM
Oddjob
Oddjob's Avatar
If they look exactly like this, then they are what you suspected they are.
Old 08-04-2011, 11:08 PM
951Saga
951Saga's Avatar
Hi Spencer, are you interested in selling them?
Also I have a few questions for you Jim… would you know where I could find a set of the upper spring hats? I have the shocks, but I’m without hats and springs.
Finally Jim did the turbo cup and turbo S cars use the same torsion bars?
TIA!
Old 08-05-2011, 12:22 AM
V2Rocket
Rainman
V2Rocket's Avatar
Here they are. You can see the decreasing wire diameter and the tightening of the coils around the blue dot.
Old 08-05-2011, 09:21 AM
Oddjob
Oddjob's Avatar
TIA!
Upper hats for the rear koni 8242 series (escort) shocks? Will probably have to have a set custom machined. Can call Koni or Truechoice and see if there is a snow ball's chance, but they have been out of production for years. So finding NOS spare parts, especially for a 944 specific application, is pretty unlikely.
I need some replacement rubber bushing inserts - so if by chance you do find some spare parts for these shocks, let me know.
The 87+ Cups used 25.5mm t-bars (same as the TS production cars) in combination w/ these coil springs (on bilstein or koni coilover shocks). They were indexed lower to maintain a low ride height w/ the helper spring/coilover setup.
Old 08-05-2011, 05:47 PM
951Saga
951Saga's Avatar
Thanks Jim for the t-bar and ride height scoop!
The 8242 you refer to must be an option number? Mine have PN: 951 333 032 34 and 031 34 stamped on the lower body.
I sent these to Koni in KY for a rebuild requesting the hats. They also expressed the exclusivity of these shocks, but sent me standard flat hats which I may be able to work with, at least use for measurements. If only they could be run inverted.
Looks like Spencer’s springs are the real deal.
Old 08-06-2011, 12:10 AM
Oddjob
Oddjob's Avatar
8242 is the koni model number.
The yellow ones are a NOS koni aftermarket set w/ the 8242 koni number on them. The orange set is the original 951 part numbered pair off my Esort/Cup car. They were originally yellow zinc plated, but were rebuilt at some point and got painted koni orange at that time.
Old 08-07-2011, 10:14 PM
piperporsche180944
piperporsche180944's Avatar
Are you looking to sell a set?
Old 08-07-2011, 10:58 PM
lart951
Basic Sponsor
lart951's Avatar
I have the original set of 4 perches for the red ones.
Old 08-09-2011, 08:47 PM
951Saga
951Saga's Avatar
Hey Lart, you have a set of the upper perches I circled?
If so, please PM me with a total to 43026!
Sorry Spencer for the hijack, moving this to PM…
Old 08-09-2011, 10:26 PM
lart951
Basic Sponsor
lart951's Avatar
this ones see the difference in diameter compared to the perches for the front struts picture # 3 and # 6 shows the same #
Old 08-09-2011, 10:41 PM
Oddjob
Oddjob's Avatar
Those are both factory front strut perch sets. The large OD are for Koni struts and the small OD are for Bilstein struts. They will fit M030 and Cup front springs.
Old 08-09-2011, 10:42 PM
Oddjob
Oddjob's Avatar
No, not yet. Just posted pics for reference.
Old 08-10-2011, 12:44 AM
V2Rocket
Rainman
V2Rocket's Avatar
No worries on the threadjack, it's your thread now...the springs have found a new home
Old 12-14-2013, 04:52 PM
Doyle623
Doyle623's Avatar
How much would a set of the 8242's be worth?
Quick Reply: Seeking assistance re: coilover springs
