FS Turbo tub and Longblock motor
I'm thought I would check and see if there is any interest in my 2.7l Darton mid sleeved turbo motor and tub before pulling the motor to sell it separately.
Included with the longblock motor would be the headers, Lindsey Ultramounts,, waterpump, head, a spec stage 2 clutch with lightened factory flywheel. The motor is a 104mm bore darton mid sleeve, JE pistons, lightened crank, crank scraper and windage tray, lindsey pan baffle, welded pickup tube, arp head studs and rod bolts, factory turbo rods, balance shaft delete. The head has a mild port and polish on the intake ports.
With the tub would be the rear suspension (minus torsion bars and shocks), torque tube, doors, fenders, hatch, outer sunroof panels and glass and comes with a clean Florida title.
I'd be willing to let it all go $1300 just to get it out of here. You must be able to come get if from here for this. You will need to bring a couple of tires and a trailer at least or some way to haul it off.
If you are interested and in a position to come pick it up, send me a pm and I’ll give you all the details on the motor and tub.
Thanks,
Rob
Thanks,
Rob
If you are interested in either the motor or the tub and are able to come pick it up, feel free to make me an offer. The Hood and Fenders are sold.
