Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > 924/944/951/968 Model Specific Technical Forums > 944 Turbo and Turbo-S Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 08-28-2011, 11:00 AM   #1
Baptizo
This didn't cost
me any drachmas
Baptizo's Avatar
Baptizo baptizo
Default LSD option - Wavetrac Differentials?
I was researching some options for my FSB and came across a company called Wavetrac Differentials. I've been considering Truetrac's or Aussie's for it, front and rear, but some guys mentioned the Wavetrac's as another option.
Click the image to open in full size.
http://www.wavetrac.net/technical.htm
After looking at their applications list I found this under Porsche:
http://www.wavetrac.net/application.htm#
944 incl turbo 1986, 40.309.170WK, $1,295.00
Note: "944 turbo and turbo S models with OEM LSD and
trans oil cooler option must convert to open-diff style drive gear, part number 016.155.165A and rollpin N.100.792.01"
Has anyone tried one in a 951? Mine is an open diff with a OEM trans oil cooler.
To remove this ad, register today or login if you already are registered!
Derek
1986 951
Baptizo is offline   Reply With Quote
Old 08-30-2011, 12:37 AM   #2
Droops83
Droops83's Avatar
Send a message via AIM to Droops83
Depends on what you are doing with the car.
If it is primarily a street car or used autocross, then the wavetrack might be a good option. It only locks up during acceleration, so is good for traction out of tight turns.
If you do a lot of track events, might want to try a clutch-type diff like the factory unit or one from Guard. These also lock up during deceleration, which is great for stability during hard braking before/into a turn, but can cause some mid-corner understeer, depending on how aggressive of a lockup ratio you are running. This would not be desirable for autoX.
If you do serious track work, do not get a Wavetrack. If not, it should be fine.
Chris A.
POC/PCA instructor
'86 951 grey, factory LSD w/ Guard internals, sports seats.
LBE, Ground Control coilovers 400#F/650R, GC camber plates, Elephant spring plate bearings, Delrin everywhere else, Tarett swaybars, engine totally stock!
'73 BMW 2002tii Chamonix white. Flares, 15x7s, Bilstein Sport/H&R, LSD, E21 Recaros. Again, engine totally stock.
'87 944S to 944 Spec race car conversion in progress . . . FOR SALE
Droops83 is offline   Reply With Quote
Old 09-27-2011, 08:23 PM   #3
sig_a
User
sig_a's Avatar
You seem to have a good understanding of the Wavetrac diff. Have you ever driven a Wavetrac equipped car on a road course?
Here is what Wavetrac says about their torsen type diff in deceleration mode.
"In the case where both wheels are on the ground during zero axle load, such as during a transition to deceleration, the Wavetrac® device is able to prepare the drivetrain for when the zero torque condition stops, eliminating the delay seen with ordinary gear diffs.
What this means for you as a driver is that power is delivered to the gripping wheels for more time and in a more constant manner – making you faster and improving stability."
sig_a is offline   Reply With Quote
Old 09-27-2011, 08:27 PM   #4
Baptizo
This didn't cost
me any drachmas
Baptizo's Avatar
Baptizo baptizo
I'm still seriously considering getting one for my 951 since it's primarily street driven and will only see occasional DE's @ Mid-Ohio with the PCA.
Derek
1986 951
Old 09-27-2011, 08:40 PM   #5
gruhsy
LR sell that Diff
gruhsy is offline   Reply With Quote
Old 09-27-2011, 08:40 PM   #6
gruhsy
sells
Old 09-27-2011, 08:45 PM   #7
Baptizo
This didn't cost
me any drachmas
Baptizo's Avatar
Baptizo baptizo
Quote:
Originally Posted by gruhsy View Post
LR sell that Diff
That's good to know, I'll head over there and see if I can find it!!!
Derek
1986 951
Old 09-27-2011, 08:46 PM   #8
sig_a
User
sig_a's Avatar
derekc23:
Yes. I'm having the Wavetrac installed in my 911 G50 at BMC&G by Brian Copans in Athens, Ohio next week. Salisbury clutch type LSD can be tuned to chassis, suspension and road course, but is much more expensive to tune, setup and maintain. Wavetrac or Quaife is "install and drive" using commonly available synthetic gear oil. My installer talked me out of clutch type and recommended Wavetrac.
Old 09-27-2011, 08:57 PM   #9
Baptizo
This didn't cost
me any drachmas
Baptizo's Avatar
Baptizo baptizo
Quote:
Originally Posted by sig_a View Post
derekc23:
It's good to know that word is spreading about the Wavetrac, it seems like a lot of bang for the buck as far as LSD's go.
Derek
1986 951
Old 09-28-2011, 12:37 AM   #10
ninefiveone
User
ninefiveone's Avatar
Not to be pedantic but by definition, an LSD is a clutch based diff. Wavetracs, quaiffes and the like are torsen diffs.
The differences only matter to a few but for those few, the differences are important.
What wavetrac says about their diff under braking is like saying "our lightbulb doesn't work when there's no electricity but it's quicker to light than a fire when there is electricty. "
ninefiveone is offline   Reply With Quote
Old 09-28-2011, 01:14 AM   #11
s14kev
Torque sensing differentials are excellent if you drive your car at 8/10ths which is the majority of us street and occassional DE types like myself. Amateurs like myself never drive at 10/10ths. I would never risk my self built/funded car.
If you are a serious track type they are unpredictable. Especially running slicks/track tires with high levels of adhesion you are more likely to lift a wheel while cornering. As soon as this happens, torque sensing differentials effectively become open diff's.
Personally. I prefer clutch pack style LSD's. A good clunky 2-way is awesome.
s14kev is offline   Reply With Quote
Old 09-28-2011, 07:38 AM   #12
sig_a
User
sig_a's Avatar
You are mistaken.
Torsen style Quaife, Wavetrac are mechanical devices that limit wheel slip. They are automatic torque bias type LSD, not clutch type.
Old 09-28-2011, 12:35 PM   #13
ninefiveone
User
You are mistaken.
This is such an old misconception.
See, you're letting the terminology trip you up. You're operating under the misconception that there are open diff's and there are limited slip diffs. And that within limited slip diffs there are clutch type and torque biasing type.
Actually there are open diffs, torque biasing diffs, and there are limited slip diffs.
It's all about how the work. Google LSD's and torque biasing diff's and you'll better understand the differences, as well as why an LSD and a torque biasing diff are not the same thing.
As I said before, the differences only matter to a few but they are very real. As someone else noted, for 90% of people they do the same thing.
Old 09-28-2011, 12:50 PM   #14
sig_a
User
sig_a's Avatar
Well, if you're sure you're correct, perhaps its time you edit out the misinformation at Wikipedia -- Limited Slip Differential. You would be doing the motorsport world a great favor. I doubt I'll see your "correction" posted.
"Types
Two main types of LSD are commonly used on passenger cars; torque sensitive (geared or clutch-based or cone-based as shown in figure at top of page) and speed sensitive (viscous/pump and clutch pack). The latter is gaining popularity especially in modern all-wheel drive vehicles, and generally requires less maintenance than the mechanical type.
[edit]Torque-sensitive
The use of the word mechanical implies that the limited slip differential is engaged by interaction between two (or more) mechanical parts. This category includes clutch and cone and helical gear limited slip differentials. For road racing, many prefer a limited slip differential, because it does not lock the two output shafts to spin at the same rate, but rather biases torque to the wheel with more grip by up to 80%."
[edit]
Old 09-28-2011, 01:43 PM   #15
ninefiveone
User
[edit]
Ah! You're basing all this on wikipedia. Yes, the entry is incorrect in a lot of substantial ways. What's interesting about wikipedia is that as misinformation or incorrect terms get propagated there, they become "truth." The world would be simpler if we all stuck to proper definitions rather than convoluted ones.
Here's a simple version of the original definition:
http://www.guardtransmission.com/tech_faq.html
It seems like you're getting very upset by all this, but you really don't know how these things work. Here's the thing, that's ok. If the differences don't matter to you, then they don't and you can use whatever term you like!
Paid Advertisement
Tags
1986, 2011, 40309170wk, 944, 951, 996, cayman, differential, limited, lsd, porsche, review, road, slip, spins, turbo, wavetrac, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
