Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > 924/944/951/968 Model Specific Technical Forums > 944 Turbo and Turbo-S Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 09-20-2011, 10:05 PM   #1
refresh951
Moderator
refresh951's Avatar
Default Saturn Studs for Exhaust Manifold - Where to Buy?
Found the Saturn/GM Part number: 11518152
Anyone know a good place to order these?
To remove this ad, register today or login if you already are registered!
__________
Shawn Deal
1986 951
www.refresh951.com
refresh951 is offline   Reply With Quote
Old 09-20-2011, 10:18 PM   #2
kinglenario
User
kinglenario's Avatar
yeah, i got mine here. let me know if you have problems with the link. i haven't used them yet so if you need them right away and want to order a set to give me that would be fine.
http://www.trademotion.com/partlocator/index.cfm?action=searchCatalogOEM&siteid=214643
kinglenario is offline   Reply With Quote
Old 09-20-2011, 10:19 PM   #3
kinglenario
User
sorry, you need to search for part # 11518152
Old 09-20-2011, 10:28 PM   #4
refresh951
Moderator
refresh951's Avatar
Colin - Thanks man, perfect. Just ordered them. Might take you up on your offer if the machine shop has my head done by Friday.
__________
Shawn Deal
1986 951
www.refresh951.com
Old 09-21-2011, 12:07 AM   #5
gregeast
gregeast's Avatar
Glad you found a source.
My first thought was "just go down to the local Saturn dealership like I did" but that's not gonna work so much these days is it...
Greg East <- Why is my name here?
Loveland, Colorado USA
Click Here for my 3-spoke wheel install thread
'87 951 K27/6 7200, Vitesse MAF w/Rogue M-Tune, Tial 38mm, Konis, Weltmeister springs, 968 MO30 sways, vision by IceShark, interior by Classic 9 Leather
BMW CCA Driving Instructor 040212-2901
gregeast is offline   Reply With Quote
Old 09-21-2011, 12:11 AM   #6
refresh951
Moderator
refresh951's Avatar
That is exactly what I found in the old threads....
__________
Shawn Deal
1986 951
www.refresh951.com
Old 09-21-2011, 12:14 AM   #7
zerMATT951
zerMATT951's Avatar
Matt Platts Matt Platts
Order 8 extra... those things are EXTREMELY handy on the intake too, and save time and money on future intake R&R's with LR rubber/aluminum gaskets.
Edit: I had to cut down one of the Saturn studs on the exhaust to get the rear nut on the #2 tube, there's no room at that spot with the SFR stage I headers.
Matt P.
'86 944 Turbo
LR Super-53 (T04E 60-Trim Stg 3), Dual Port, Full 3" | M-Tune w/E85 @ 20 PSI | Late Offset M030 | LSD
'87 924S
Gone to a new home | '07 Avalanche 4x4 Family Hauler | '08 Volvo V50 T5 Wife's DD
zerMATT951 is offline   Reply With Quote
Old 09-21-2011, 12:20 AM   #8
zerMATT951
zerMATT951's Avatar
Quote:
You can still get Saturn (Pontiac and Oldsmobile too) parts at most GM dealerships. They may have to order it, but the parts shouldn't be too far away at a regional warehouse.
Matt P.
'86 944 Turbo
'87 924S
Old 09-21-2011, 12:22 AM   #9
refresh951
Moderator
refresh951's Avatar
Cool, I ordered 12 extra just to have some laying around as they were only 84 cents/each.
__________
Shawn Deal
1986 951
www.refresh951.com
Old 09-21-2011, 02:10 PM   #10
kinglenario
User
i called all around and nobody stocks those in atlanta. easier to just order them online. what is the advantage to have them on the intake? isn't it just as easy or easier to use the stock bolts? the bolts are pretty easy...
Old 09-21-2011, 10:01 PM   #11
zerMATT951
zerMATT951's Avatar
Quote:
On a completely stock car, it may not make much difference. On a car with extra or new wiring harnesses, a billet fuel rail with a rear dampener, or anything else that makes the placement of the manifold a bit of a juggling act, the studs just make things simpler. You don't have to mess with gaskets that slide around if you miss the target once or twice, it just makes things simpler. Not to mention if you think you might have the intake off occasionally for maintenance or upgrades, you practically eliminate the risk of stripping the aluminum threads out of the head.
Sure, these are all minor things, but for less than $12, it's one of the cheapest mods you can do that will have repeated benefits down the road. If this will be the only time you are ever going to take the manifold off, or if you are just fixing the car to sell it, don't bother. If you plan on keeping the car until the doors fall off like I do, than it's more than worth that extra $12.
Matt P.
'86 944 Turbo
'87 924S
Old 09-22-2011, 10:51 AM   #12
JohnKoaWood
Super User
JohnKoaWood's Avatar
I can say IMHO that the studs, and SS nuts make for better appearance as the OE bolts corrode over time... the studs and nuts... not so much!
JohnKoaWood is offline   Reply With Quote
Old 09-22-2011, 11:35 AM   #13
zerMATT951
zerMATT951's Avatar
Quote:
I used copper nuts just to match the exhaust nuts, but I may switch them to SS... that would actually look pretty darn good with my shiny intake .
Matt P.
'86 944 Turbo
'87 924S
Old 09-22-2011, 12:01 PM   #14
JohnKoaWood
Super User
I am thinking the copper nuts will look sharp next to my intake... pics will come eventually... FWIW my intake has the same finish right now as my avatar...
Old 09-22-2011, 03:52 PM   #15
Josh B
Josh B's Avatar
I was looking at these studs last night and they have a hex on the outside. Does anyone where you can buy the ones with the 5mm internal hex? I had some that were included in one of the hardware kit group buys that happened on the board.
92 968 blk/cashmere, Bilstein coilovers 500/350lb+t-bars, 28 and 22mm Welt sway bars, Big Reds on two piece rotors, Fikse FM5 18" wheels
Josh B is offline   Reply With Quote
Paid Advertisement
Tags
11518152, 944, black, buy, celica, exhaust, gm, locally, located, manifold, part, saturn, size, stud, studs, supra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
