How to drag race your 951...is it a drag car? :-)
Old 01-07-2012, 03:33 AM
  #31
Paulyy
Professional Hoon
Paulyy's Avatar
Can out show me a picture of your Trans Brace you've made?
Old 01-07-2012, 04:15 AM
  #32
NZ951
NZ951's Avatar
Those are some good 60 foot times really, especially if you are not using drag radials (which will help you immensely).
The biggest issue I found when drag racing mine was shifting (not sure if its a transaxle thing).
Old 01-07-2012, 10:07 AM
  #33
dillon410021
dillon410021's Avatar
I am guessing it would bolt on to the tabs on the side of the trans
heres a pic I found on google:
it looks like something most people could make.
Old 01-07-2012, 12:32 PM
  #34
blown 944
blown 944's Avatar
Thanks, I did try drag radials at the very end and I think they will help. At least for consistency. The problem became worse with my clutch, hence the lower mph.
I havnt had any issues shifting using the two step.
This year should be pretty interesting considering I now have a clutch that is holding and that I will have a couple different power plants to test out.
I'm shooting for consistent 1.6 second sixty foots.
Old 01-07-2012, 02:24 PM
  #35
Black51
Black51's Avatar
What are you, tryin' to beat vettes on the strip too or something?
C'mon now, you gotta give those guys 'something' to feel proud about.
Old 01-07-2012, 03:59 PM
  #36
blown 944
blown 944's Avatar
Believe it or not there aren't too many vettes that can beat me up here even at high twelves. Most run low to mid 13's. I can only think of three that frequent the drag strip that are in the 11's. They either are pro charged or nitrous assisted.
I don't really care to compare to other cars much. I just want to run respectable times and see what I can do with it. Nobody at the drag strip knows how slow these things are anyway.
Old 05-23-2016, 03:53 PM
  #37
951TT
951TT's Avatar
Hi Sid, congratulations for the very good quartermile-time.
I think you use 275/40/17 drag radials ? What kind of rim is the best solution for this tire size ?
Sometimes i visit the quartermile with my 951. I use 10x16" Avon-Slicks (no drag-slicks) on
original 9x16" design 90 rims. This configuration performs also good (best ET 11,55 / 129mp/h).
Upcoming i will change to 17" drag radials at 9x17" rims.
Frank
Old 05-23-2016, 04:33 PM
  #38
fwb42
fwb42's Avatar
Well Frank, You just can't put something like that on here without details of your car etc. Fill us in!!!
Old 05-23-2016, 05:35 PM
  #39
951TT
951TT's Avatar
My car is a 944 Turbo model year `91. I drive the 951 since 20 years (only at nice weather) on the street and sometimes at the quartermile in Germany. Over the years i am are realized miscellaneous updates at the car. It is to much to list all Details (3liter-8V, KKK-Hybrid, HFM/MAF with Bosch DME/KLR & Apexi, KW V3 Suspension, etc).
But the transaxle, the gearbox and the axle ratio is completely original.
Therefore my interest above the drag radials at the 951.
Old 05-23-2016, 05:37 PM
  #40
951TT
951TT's Avatar
at local airfield
Old 05-23-2016, 05:40 PM
  #41
951TT
951TT's Avatar
Old 05-24-2016, 01:40 AM
  #42
333pg333
333pg333's Avatar
Pretty sure Sid has run about 11 sec flat now. Perhaps lower.
Old 05-29-2016, 09:29 PM
  #43
blown 944
blown 944's Avatar
Sorry about being MIA here. I've been having too much fun with my little 4g63 b210 datsun.
I use the 9" boxter wheels with 275 40 17s at about 18psi.
I have ran 10.80 at 134 down here, but it's just not as fun as going mid 9s at 143 in my little car, so I've semi retired the 944. I might take it again soon if I take the little one apart to do some more stuff. I think it will run a mid ten if I use some track prep. This track down here is not very good at prep.
To be honest though, I doubt I'll push it. For the simple fact that I'm just tired of breaking axles etc.
I think I have seen your car on drag times for a few years. Those are some great times!!
I just re read your post. I would use teh 16" wheels if I were you. I'd prefer to have more sidewall. So whatever size is equivalent to 275 40 17
Old 06-12-2016, 04:08 AM
  #44
951TT
951TT's Avatar
10,80 at 134 sounds very good. Instead you need also a lot of horsepower for this time. The boxter wheel`s are a good option. I will go to use 9x17 fuchs wheels (very light). But i hope the tires suit to the wheelhouse. Yes it`s not always fun with the 951 at the track. I have also many issue`s with the axle. Often the drive to the track makes more fun as the quartermile. Please see the pictures below.
Old 06-12-2016, 04:10 AM
  #45
951TT
951TT's Avatar
Quick Reply: How to drag race your 951...is it a drag car? :-)
