Hybrid stroker project
Old 04-12-2012, 02:29 AM
blown 944
blown 944's Avatar
Default Update...Hybrid stroker project....... IT RUNS
I have been collecting parts and having machine work done to build a stroker engine (2.85l) for myself and possibly offer up for sale in the future. I am now getting very close to being able to start the assembly and thought I'd share.
First off this is an idea that has been around for some time and I finally decided to go through with it.
I am however taking a different route using off the shelf parts for a much more inexpensive build cost.
I started with a bare block that I had dry sleeved, half filled, decked to 9.05
then bored out to just over 102mm
balance shaft delete using epoxy and tapping the oil holes
offset ground 86mm stroke
pistons are off the shelf chevy low compression pieces
rods are eagle 150mm for mitsubishi using coated ACL race bearings.
I will be using ARP studs torqued to 100#ft and cometic .040 gasket.
The compression ratio will come in at about 8.5:1 with the 8v head and pistons
I decided to quantify some of the gains by going through stages of power levels using different parts rather than jump right to the 16v head. First I will be running it with a fully stock 8v head to compare to last years mph. Then I will add a custom camshaft I had ground. Then I will change the head to my good 8v head. Later on I plan to add the 16v head and pistons either using this crank/rod combo or build another engine to use these parts.
There are a few reasons that I decided to do this:
*sleeved block-stronger material that is able to withstand potential damage
*ability to use inexpensive off the shelf parts
*better oiling with the smaller rod journals (less surface area)
*stronger rods than factory (initially this was all I was going to do, but decided to stroke it at the same time)
*lighter reciprocating assembly (much lighter)
*because I can
This is the "proof of concept" build that will be followed up by a much more detailed one including: crank lightening, piston squirters, oil pump manipulation and quite a few other items. So far the clearances are looking very good and I believe it will be a success. At some point though, I will be trying to blow it up by running it to extreme rpms to see what it will take.
Here are a few phots of the parts and trial fitments. I will be adding photos to this thread as I progress.
Old 04-12-2012, 03:24 AM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
This is going to be a FUN summer!
Old 04-12-2012, 04:17 AM
Thom
Thom's Avatar
It seems to me this board has been missing an exotic engine build for some time, this thread is going to be both fun and interesting - thanks for that.
Looking forward to following your progress!
Old 04-12-2012, 05:46 AM
333pg333
333pg333's Avatar
Good on you Sid. Hope to see the various stages unravel (in a good way!) over the next year. Be interesting to see what happens with the extra half point c/r?
Subscribed.
Old 04-12-2012, 06:20 AM
JET951
JET951's Avatar
Cool project Sid,
what are your goals? you have done some pretty fast times at the strip do you have a time or MPH in mind?
So the Pistons are a forged item? 4032? or 2618? what sort of clearance do those things command in a steel bore? Sounds like a great project and out of the box thinking.
Sean
Old 04-12-2012, 10:47 AM
blown 944
blown 944's Avatar
Thanks guys.
Sean, They are 4032, iirc we decided on .0055 - .006 clearance for a little more expansion room.
My goals are varied depending on which combo (head)
With the stock head I'd like to see 123mph, with cam 125, worked 8v 125mph plus, 16v over 130. Keep in mind I'm at high elevation where over 120 is GTR territory
Old 04-12-2012, 10:52 AM
toddk911
Drive-by provocation guy
toddk911's Avatar
In the interest of costs, what are your projections for each stage?
Old 04-12-2012, 11:07 AM
blown 944
blown 944's Avatar
Pat, I don't think the half point compression will be of much merit either way. After experimenting with a very high compression 8v I have decided that I'd rather have the room for more boost and less cylinder pressure. I think the added stroke will be plenty of dd improvement. Don't get me wrong I like the higher compression. But with an 8v head it seems to limit the total power output.
Old 04-12-2012, 11:11 AM
86 951 Driver
86 951 Driver's Avatar
Blown944 I have never met you before, but you seem like a really smart guy. Doing something completely out of the box to try and keep these cars going(without a V8). It looks like an awesome project/experiment.
Are you an engineer or just a hot rodder type of guy?
Old 04-12-2012, 11:23 AM
blown 944
blown 944's Avatar
Todd, I'm not sure what the cost of the 16v will be at the moment, but probably around 500-1000 over the 8v.
Using the stock head the build should come in around 3200 including bearings and gaskets. I'll be reusing some parts I already have ie; water pump, rollers, etc. the other stuff is more custom to me so not really expensive.
Old 04-12-2012, 11:31 AM
gregeast
gregeast's Avatar
Now this is my kind of hybrid!
Joshua told me a bit about what you were working on when we did my custom M-Tune, can't wait to see the results.
Old 04-12-2012, 11:32 AM
blown 944
blown 944's Avatar
Just a hot rodder. My only claim to any sort of fame is tuning nitro coupe bitd. Smart... Lol not really.
Old 04-12-2012, 11:41 AM
David Floyd
David Floyd's Avatar
Originally Posted by blown 944
Thanks guys.
That is the clearance I run with steel sleeves and JE 4032
Cool project
Old 04-12-2012, 09:10 PM
White_951
White_951's Avatar
Sound reasoning and solid strategy....a winning combination......
Old 04-12-2012, 09:40 PM
Reimu
Reimu's Avatar
How much does a typical 2.8L run? Just a ballpark estimate
Quick Reply: Hybrid stroker project
