FS: 944/951 Parts
Old 04-25-2012, 10:14 PM
brad-cam
brad-cam's Avatar
Default FS: 944/951 Parts - *MORE LISTED*
** MORE PARTS HERE and LIST CLEANED UP - November 24 **
Now that my 951 is gone I will be posting some parts for sale (I have many!!). PM for details. Open to offers.
0. 951 Transmission ('86 5R with external cooler) - great shape - $400 (will not ship) - http://sfbay.craigslist.org/nby/pts/3191050018.html
1. Control Arm, Right Side, ‘87+, new rebuilt ball joint - $75
3. Headlight motor - $30
5. Power steering pump - $50
7. Fuel pressure regulator, Bosch, NEW, 2.5bar, PN 0280160227 - Quantity 1 - $50 each
8. Coolant thermostat, 1 unmarked brand. NEW, $5
13. Transmission upper mount. Used (excellent cond). PN 944.375.045.04 - $25
21. Driveshaft coupler (the one the connects drive shaft to input shaft of transmission) - $20
25. 951 fuel rail, excellent shape still has yellow zinc finish - $40
27. Crankshaft reference sensor, good used. Bosch 0261210003 - $30
29. 951 Auxiliary Turbo Water pump. Used, good - $80
30. Oil Pressure Relief Valve, '87+ one piece. Used but excellent. Qty:2 - $75 each (check out price of these new!!!)
31. K26/6 Turbocharger. Very little play, but would suggest rebuild to be sure. - $125
33. 951 Fuel Pump, Good working used - $30
35. 951 Fuel Injectors, stock, used, work perfectly - Qty:4 - $100 for the set, $30 each
36. 944 Camshaft gear, Qty:2 - $10 each
37. 944 Timing Belt Tensioner, '87+ - $45
38. 951 Camshaft, Qty:2 - $40 each
39. Seatbelt warning chime relay, used, PN 928.618.102.02 - $15
40. 944 Bellhousing, used, clean. PN 944.116.401.4R - $30
41. 951 Front hubs and spindles, pair, with dust shields, '87-, $120
43. 944 Alternator, $75 (from '87 951)
46. 951 Intake manifold, $30
47. 944/951 Crankshaft (standard 2.5L), $75 each (I have 3 of them)
50. 951 Stock chips for DME and KLR, 24-pin DME chip, $25
54. 951 Turbo downpipe, Qty:2, good used, $30 each
55. 951 Turbo Exhaust crossover pipe (manifold to turbo). flanged WG pipe (no WG pipe). $50 each
56. 951 Radiator lower support (the piece of metal the rad sits on), Red, $25
57. 944/951 Fuel tank - plastic. From '86+. Great condition, big to ship!. $60
58. 944 Steering shaft - the one connecting steering wheel to rack. $30
60. 944/951 Exhaust manifold gaskets, Set of 4, brand new, 944-111-196-00, $15
61. 944/951 Connecting Rod Bearings, Glyco, Brand New, SET OF 6 shells for 3 rods (not 4!), 928-103-143-02, $75
63. 944/951 Turn Signal/Washer Switch Assembly For Cars With Cruise Control, Without Headlamp Washers And Airbag, 944 All (02/85-88), 944-613-507-00, I have 3 of these - I can't test them, but they seem functionally ok. $40 each.
64. 951 Water distribution tube (the hard cooling system line that bolts across the front of engine compartment, 951-110-171-02, Good used, $50
67. 944/951 Valve lifters, Set of 8, excellent condition, solid pressure, $20 each or 8 for $120.
68. 944/951 Brake Booster (power brake booster) - great condition - $30
69. 944 Power Steering Hose, Brand New Old Stock, Pump-to-rack, 944-347-447-00, $70
70. 944/951 Flywheel lock tool (needed for timing belt replacement), $25
71. 944/951 Oil Pressure Relief Valve alignment tool, '83-86, $15
72. 944/951 Oil Pressure Relief Valve alignment tool, '87-Later, $40
73. 944/951 Oil Filter, New, Mahle OC 142, $8
74. 944/951 Front Crankshaft Bolt, New, M16x1.5x60, Grade 8.8. Qty 5. $2.50 each.
Will charge fair lowest-cost shipping on these items. Make me an offer. Pics are coming.
Old 05-09-2012, 08:30 PM
brad-cam
brad-cam's Avatar
Bump...
And it has come to my attention that the radiator listed here now sell for $350-400 these days ($395 at Pelican) so the $225 I am asking is a better deal than I originally thought !!
It is an LR OEM radiator, NIB.
Old 05-16-2012, 04:25 PM
brad-cam
brad-cam's Avatar
BUMP - more parts listed for sale today.... still digging out more
Old 05-16-2012, 07:51 PM
Black51
Black51's Avatar
Have you got the camshaft?
Old 05-16-2012, 09:18 PM
brad-cam
brad-cam's Avatar
yes, I have 2 of them. $40 each. PM if interested.
Old 05-17-2012, 12:14 AM
Tom M'Guinn
Tom M'Guinn's Avatar
I'd like the turbo coolant hard line #17 assuming its in decent shape.
Old 05-17-2012, 12:32 AM
Crazy Eddie
Crazy Eddie's Avatar
Hi Brad
I take the # 16
AC dryer
Let me know
Ed
thanks
Originally Posted by brad-cam
** MORE PARTS LISTED **
First up:
1) *SOLD* Factory Porsche (NOS) 944/951 Oil Pump: Part Number 944.107.104.9R
Casting date is 1986. Includes crankshaft seal. New in factory Porsche box.
Asking $175 (these are $800+ new but I know nobody really pays that!!)
2) *SOLD* Factory Porsche (NOS) 944/951/928 Main Bearings, Full Set for 85.5-88
Qty 3: 928.101.115.02 Half bearing shells (top)
Qty 3: 928.101.115.03 Half bearing shells (bottom)
Qty 2: 944.101.139.00 Center bearing shells (2 halves, thrust bearings)
Qty 1: 928.101.117.08 Front main bearing (1-piece bearing)
Date stamps vary from 05.07.88 to 31.03.89. Retail on these now for OEM is over $500. Will sell for $150. New in factory boxes.
3) *AVAILABLE* Radiator, New in box, OEM 944 Turbo (951). Bought about 5 years ago and never used. Asking $225 (sells online over $350).
MORE PARTS LISTED on May 16, 2012 - PM for details:
2. Springs, front, H&R, 200lb. Blue color, almost brand new. - $75
4. Tie Rods, ‘87+, New, includes rods with inside joints and brand new tie-rod ends. - $75 for pair
6. Oil pressure sensor, FAE brand. - $25
7. Fuel pressure regulator, Bosch, NEW, 2.5bar, PN 0280160227 - Quantity 2 - $50 each
8. Coolant thermostat, 1 Wahler, 1 Behr, 1 unmarked brand. All NEW, - Quantity 3 - $5 each
9. Coolant fan switch, Behr, NEW - $5
10. Front strut dust boots, OEM Porsche, NEW, Qty 2, PN 431.412.135 - $20
11. Clutch fork, Used, Qty: 2 - $25 each
12. Clutch fork pin, Used, Qty:2 - $5 each
13. Transmission upper mount. Qty 2. 1 is NEW OEM Porsche, I used (excellent cond). PN 944.375.045.04 - $40 for new, $25 for good used
14. Rennbay headlight wiring/relay upgrade – NEW in the bag - $100
15. Horn, NEW OEM Porsche (in box). PN 944.635.206.00 - $20
16. A/C Filter/Dryer, NEW Sealed. PN 944.573.943.00 - $35
17. 951 Turbo coolant hard line (the one with the threaded sensor hole) - $15
18. Outside mirror, passenger side, gray metallic. - $30
19. Starter heat shield, New OEM Porsche. PN 951.604.054.00 - $20
20. Fuse box with cover including all relays - $40
22. Exhaust headers - $175
23. 951 DME, 24 pin, stock chips - $125
24. 951 cylinder head, fully loaded - $175
26. Sunroof seal, NEW OEM Porsche still in bag, PN 944.564.623.00 - $15
28. 951 Exhaust Header heat shield, Brand New, OEM Porsche. PN 951.107.053.01 - $40
29. 951 Auxilary Turbo Water pump. Used, good - $80
Old 05-17-2012, 12:38 AM
Crazy Eddie
And the sunroof seal
Old 05-17-2012, 12:41 AM
jmj951
jmj951's Avatar
I'd like the following:
PM sent!
Just out of curiosity, what is a 'fully loaded' cylinder head? Do you just mean it's complete, or has there been any refresh or performance work done to it?
Old 05-17-2012, 01:37 AM
brad-cam
brad-cam's Avatar
Following up with PM's folks. jmj951, by "fully loaded" I just mean it comes with valves, springs, retainers, seals...
Old 05-17-2012, 12:46 PM
brad-cam
brad-cam's Avatar
For those of you who have sent me payment, shipments will go out today USPS Priority !
Old 05-17-2012, 02:25 PM
darek_u
darek_u's Avatar
I'll take FPR, transmission mount (new) and coolant switch. PM on the way.
Old 05-18-2012, 01:04 AM
brad-cam
brad-cam's Avatar
More parts added.
Old 05-19-2012, 04:15 PM
Tom M'Guinn
I asked about the turbo pipe Wed night after 8pm. You responded in minutes. I sent paypal that night. Part then arrived in good shape 57 hours later. Not bad!
Thanks for the ridiculously fast/easy transaction!
Old 05-19-2012, 09:48 PM
jmj951
jmj951's Avatar
^^Ditto
Got my parts today, 100% satisfied. Thanks for a very quick transaction!
Quick Reply: FS: 944/951 Parts
