968 tranny install in a 951 what do I need?
You don't need to change the cross member. LSD won't work. Different. You need to modify the shifter rod too. There must be a thread about all this somewhere with pics.
968 Trans swap in a 951
I did this conversion, and it was a very simple deal.
The only big difference is that the Left Side 968 Axle is shorter that the Right Side (RS is the same as the 951's) I used the OEM 951 cross member and a Lindsey solid mount. You don't have to change the 951 shifter or rod, as long as you have the 968 transmission mounted shift linkage.
The only pisser is that I don't have a speedo. Not sure how to retrofit the 968 speedo to fit my 89 Turbo S.
The conversion took me less than 2-hours to install: 951 out & 968 in.
Very NICE on the track. Used this configuration at Sebring and turned consistent low 2:27's. Missed a couple of shifts (forgot that I was driving a 6-speed) but the close ratio worked very well for me.
Here is a link to see & hear a 968 trans in a 944TS.
http://contour.com/stories/sebring-p...-944ts-porsche
Does anybody know about the speedo conversions ?
Cheers Rokket
Cheers Rokket
Basic Sponsor
would a S2 tranny be a better choice than?
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
needs a taller 3rd, 4th, 5th and 6th for all that hp.
3rd; 1.230 :1
4th; 0.920: 1
5th; 0.729 :1
6h. 0.680 :1
compared to stock:
3rd; 1.435 :1
4th; 1.111 :1
5th; 0.912 :1
6th. 0.778 :1
3rd; 1.230 :1
4th; 0.920: 1
5th; 0.729 :1
6h. 0.680 :1
compared to stock:
3rd; 1.435 :1
4th; 1.111 :1
5th; 0.912 :1
6th. 0.778 :1
Basic Sponsor
Cheers Rokket
Cheers Rokket
http://www.lindseyracing.com/LR/Pors...68-SPEEDO.html
also a video of another 951 with a 968 tranny
Basic Sponsor
Team Owner
for the track, S2 box is perfect...
for the street the 968 is probably better than a 44T box on a bone stock turbo....
why ? cuz you're able to get to peak hp at (whatever speed the car happens to be moving) in a hurry.
for cheap top end... the stock 951 has a taller 5th than the 968's 6th, right ? the 968 final drive is 3.778.
'44T box mated with the '44S 5th, even taller.
I just built a 1991 944S2 trans and put in a Guard LSD. The 944S2 trans is nearly identical to the 968 with out a 6th gear. At Sebring I was running out of gear/engine at nearly all of the straights. My best times at Sebring 2:27.03 with a 951 AOR , 2:27.3 with 968 and 2:28.01 with 944S2. All are LSD and on same tires.
Basic Sponsor
See 944 gear ratios here: http://www.clarks-garage.com/pdf-manual/trans-04.pdf
968 Gear Ratio:
6 speed manual:
3.182 :1
2.000 :1
1.435 :1
1.111 :1
0.912 :1
0.778 :1
Reverse is 3.455 :1
Axle ratio is 3.778 :1
For the Tiptronic:
3.152 :1
1.719 :1
1.222 :1
0.907 :1
Reverse is 2.882 :1
Axle ratio is 3.250 :1
968 Gear Ratio:
6 speed manual:
3.182 :1
2.000 :1
1.435 :1
1.111 :1
0.912 :1
0.778 :1
Reverse is 3.455 :1
For the Tiptronic:
3.152 :1
1.719 :1
1.222 :1
0.907 :1
Reverse is 2.882 :1
