new tires+21 psi of boost+ hard launch, what do you get?
Basic Sponsor
sure how many do you need pm sent...
Small Business Partner
But basically, you use either the E-brake or heel-toe it, to hold the car, let out the clutch enough to put a little load on the drivetrain. Then let off the E-brake while smoothly letting off the clutch and going WOT at the same time...
Takes a little bit of practice - but is much easier on the drivetrain than fast clutch dumps.
Lookup pre-loading launch.
E-brake works for testing the clutch on a used car too. I bought a CRX a few years ago for cheap.........pulled the e-brake and it did 6000RPM in first without moving an inch.....got it even cheaper.
Lart do you need some axle bits "new CV's"? I have some spares I'm never going to use. I'm moving Saturday and can dig them out of my bins.
They are new ones. I Loathe building axles......it makes me turn green and smash things
Evo never break, just tell him to keep hammering it.
http://www.youtube.com/watch?v=VGm2eczYyGA
Ahhh...I miss the days of my street legal 4 speed V8 Vega. I had nitrous on it (early non adjustable 200hp Cheater circa 1981). Rev to 4k, dump the clutch and hit the nitrous button at the same time, then row through the gears with the foot pedal flat and the floor and my thumb always squeezing the nitrous switch.
8" Ford axle transplanted.
As far as my 951, I heve yet to and never plan to "launch" the car. The risk/reward just isn't there.
