Refresh951's Hybrid Stroker - A Blown944 Design
Old 06-18-2012, 09:22 PM
refresh951
refresh951's Avatar
Default Refresh951's Hybrid Stroker - Update: It is Running!!
I have been closely following Sid's (Blown944) build thread and I absolutely love his concept. I love the idea of developing reliable, large displacement motors at a reasonable cost. Therefore, I decided a while back to start collecting parts and doing the research to make an attempt at my own 2.9L build. Sid has graciously given me a great deal of advice and I appreciate his assistance. I am close to assembling the motor as I am only waiting on the crank. This motor will be used mostly for street use with occasional track days. I have had a couple people tell me I am crazy to try this. I enjoy a good challenge and if I fail (and I do not plan to fail) it is my time and my money. Either way it will be a great learning experience for me. I have had an absolute blast so far working on this. I have some very high goals for the build:
- 400 rwhp/400 ftlbs torque at 6200rpm
- Near k26/6 bottom end performance
- Total cost under $4200 for everything, including my "High Flow" head
- Using 86 Block, dry sleeved, bored to just over 102mm, windage ports added, half filled
- JE Small Block Chevy Pistons, Forged 4032
- Eagle 150mm Mitsubishi Rods
- 86 2.5L crank, offset grind, 86mm stroke, cross drilled
- Compression Ratio is 8.1:1
- ARP Head Studs
- Cometic Head Gasket
- ACL Race Rod Bearings
- Crank Scrapper
- Stock Cam (still researching options)
- MoCal 13 Row Oil Cooler, 235 mm
My current 2.5L motor is running great but after the Concours this weekend I will be pulling it out of my car to install the new motor. I will be re-using a lot of stuff from the 2.5L to keep costs down (turbo, M Tune, water pump, cam tower, ect.).
Old 06-18-2012, 09:37 PM
V2Rocket
Rainman
V2Rocket's Avatar
Awesome - I too am dreaming of this, but the $$$ just isn't there yet.
That said, how much material did you have to bore out to fit the 102mm sleeve? I measured the other day and the cylinder walls are between 8 and 9mm thick (seems to vary a bit depending where on each cylinder you measure, but I guess if the hole center is right then it's OK).
The intertube says the (dry) LS1 cylinder liners are only about 1.5mm thick. A 102mm bore with that thickness means 105mm hole in the aluminum. That still leaves ~5.5mm (~0.22") aluminum wall...how big can we go and stay with a dry liner?
Old 06-18-2012, 10:05 PM
blown 944
blown 944's Avatar
Right on!!!
Remember, you may need to fly cut the pistons slightly for a fully non-interference fit.
I'm looking forward yo seeming it get done and your comparison dynos as well.
I'm sure you'll love it.
Old 06-18-2012, 10:18 PM
User 52121
User 52121's Avatar
This is awesome... though I gotta say, I was a fan of your stock-ish setup! Your existing 2.5L (w/T04) is pretty much what I want to do with mine....
Good luck - will watch this closely!
Old 06-18-2012, 10:21 PM
86 951 Driver
86 951 Driver's Avatar
Why not 9:1 compression? I would think this would really help with low end performance. Very cool to see yet another stroker motor. I need to learn how to build motors. 2 Strokes are not a huge problem 4 strokes with these valves just trip me up. Hehe
Good Luck!
Old 06-18-2012, 10:26 PM
refresh951
refresh951's Avatar
Originally Posted by blown 944
Right on!!!
Thanks Sid! I REALLY appreciate your help on this.
I should be "claying" the valve clearance this weekend then I will know exactly what I have.
Old 06-18-2012, 10:30 PM
refresh951
refresh951's Avatar
It is a great setup but....wait until you see what this can do!
Old 06-18-2012, 10:32 PM
refresh951
refresh951's Avatar
Good Luck!
I am using off the shelf pistons to keep cost down. This limits the options wrt CR. But with custom pistons as Sid is planning...
Old 06-18-2012, 10:34 PM
black944 turbo
black944 turbo's Avatar
Awesome Shawn. Your car was already pretty incredible, nice to see more people trying this. If my motor ends up having issues, I think I will attempt this as well.
Old 06-18-2012, 10:41 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Awesome Shawn!
Any pics of the windage ports?
Regarding compression, the stroker motor will have so much more bottom-end grunt, keeping CR around 8.0 isn't an issue - it will help keep peak cylinder pressure down and be less likely to knock.
Old 06-18-2012, 10:44 PM
Rogue_Ant
Rogue_Ant's Avatar
Originally Posted by robstah
But more cylinder pressure = more torque.
Notice I said "peak cylinder pressure".
What kills these engines is the peak.
Extending cylinder pressure duration, but at a lower peak will also accomplish the same end-goal (more power/tq).
Regardless, I just had one of my own threads dragged way off due to an irrelevant contention, lets not do this to Shawn's thread.
Old 06-18-2012, 10:54 PM
User 52121
User 52121's Avatar
Knock schmock he's running E85 already...
I wish that stuff was readily available here!
Old 06-18-2012, 10:58 PM
Scott H
Scott H's Avatar
Could this theoretically be done with a 3 liter crankshaft in conjunction with MID sleeves to make some stupid 3.2L+ setup?
Old 06-18-2012, 11:18 PM
David Floyd
David Floyd's Avatar
106mm has worked for me for the last 10 years
Very cool project
CyCloNe!
CyCloNe!'s Avatar
subscribed
Quick Reply: Refresh951's Hybrid Stroker - A Blown944 Design
