Converted A/C to R-134..quick question?
Old 06-29-2012, 08:00 PM
MK_951
MK_951's Avatar
Default Converted A/C to R-134..quick question?
So I converted my A/C to R-134 and I was wondering how many lbs. of refrigerant I put in. I know R-12 is way better and I believe that it also is more dense so the system requires less to put in. Any suggestions?
Old 06-30-2012, 02:54 AM
djantlive
djantlive's Avatar
no, it's the same, 2 lbs. don't overfill because it'll actually make the ac system less efficient and make it less cold. my ac shop played with the pressure to see if the system gets colder. it didn't change. while not ice cold, the r134 did work. r12 that was in there wasn't that much colder actually.
Old 06-30-2012, 03:55 AM
m73m95
m73m95's Avatar
No no. You should only fill the system to 80% of the r12 capacity.
33oz r12 system will take ~26.5oz of r134
Old 06-30-2012, 10:53 AM
CurtP
CurtP's Avatar
According to the Porsche technical bulletin, retrofitting a 944 to 134a takes 860g which works out to 1.9lbs.
Old 06-30-2012, 12:31 PM
MK_951
MK_951's Avatar
K..so A/C blows cold and everything seems to be good but now my alternator isn't charging out of nowhere and it is a brand new alternator only 1month old
Old 06-30-2012, 01:54 PM
djantlive
djantlive's Avatar
are the belts properly tensioned? did the compressor get changed? if so, maybe the belts tension is the issue causing alternator not charging properly.
Old 06-30-2012, 02:51 PM
MK_951
MK_951's Avatar
I'm gonna have to play around with the tensioner then..cause it squeals all the time even when trying to drive
Old 06-30-2012, 07:07 PM
Ben951S
Ben951S's Avatar
Lol, so what are you waiting for, flashing lights too or a phone call from your car? Go fix it.
Old 07-01-2012, 10:38 AM
griffiths
griffiths's Avatar
Follow the Porsche TSB of charge weight as a reference, but ideally you want to charge by "P&T", pressures and temperatures.
A squeal could be caused several things:
grease on belt,
old belt,
tensioner going south,
AC clutch slipping,
belt slipping,
alt bearing going south,
.... time to pin down the source.
Quick Reply: Converted A/C to R-134..quick question?
