My version of the center console gauge panel
#46
I have a couple of these left if anyone is looking for a 3 hole on the cheap. They need to be painted but they fit real nice. $12
http://www.rennbay.com/944-gauge-plate-hole-p-181.html
#47
#50
Well, I gave recovering the front header panel with Alcantara a shot - and failed miserably. I have enough material to attempt covering the A-pillar trim pieces, but after the header panel fiasco, I'm not sure I'm going to even try.
I did manage to get the trim rings on the center console gauges replaced today. Now they're an exact match for the gauge cluster trim rings.
Speaking of the instrument cluster - that's my next project. I replaced the light tunnels with LED replacements and two of the three have failed. I'm working on making the gauges backlit - I'm fed up with this front-lit nonsense!
Curt - sorry to revive an old thread, but you said something here that caught my eye - something about back-lighting your gauges? Did you ever get anywhere with that project?
#51
I recently finished off my set up. I custom mounted a Turbosmart eboost street electronic boost controller behind smoked and painted plexiglass. Covered trim in real carbon fibre and added a "SEND IT" switch for eboost setting 2
