Next years goal... 750 true RWHP
#61
Small Business Partner
So looking at airflow & IDC on the Dyno today, vs Sid's last runs at the track - we were quite conservative today! At the track he was making ~11% more airflow and pretty much a directly correlation to 10-11% more power. That puts his 522rwhp from today to ~575rwhp.
Agreed that 750rwhp is going to be tough. But frankly, the current setup isn't that exotic - boost is still very reasonable (low 20's), the head is still stock valves, and the turbo isn't ridiculously over-sized (GT35r size).
Maybe we it make 750rwhp, maybe not. But either way, it will be fun!
#63
I agree, It will be awesome to do and or fun just trying. I love what you guys are doing and support ya 100%!
ps - Sid knows I love him.
#64
#65
So Dave, what do you honestly think the gain could be via cam and larger valves? I'm talking thin stems too and a minimal overlap high lift cam. Maybe you can help me design it?
Also I know you like my TB diameter,but do you think there may be any benefit to going to 75mm. I have Bruce's old intake that has belmouths welded in. I may flow both and see what they show.
Also, for everyone, I did learn that over 6300 I am coming into a restriction for sure, as the AFRs go rich for no reason.
Also, just to clarify. I usually start my drag races at 160 degrees coolant temp and end at 170. My runs were pretty rushed today and started at 185 and went to 187.
#66
To be honest, flow those intakes and not just one way, suck and blow. What could you gain regarding valves and cam, hard to put a real number there but, a good bit for sure. A real cam does wonders.
The real secret is controlling cylinder pressures. You figure that out and you will be golden. Cam timing will make a big difference.
Also, consider removing as much friction out of the block as possible.
#67
I like where this thread is going...I'm just not sure where that is...
Sid, btw, have you seen any more differences with the 3L water pump during the last few days?
#68
it seems to keep temps down while cruising down the highway and while idling. Otherwise not too much difference.
#69
dyno charts. I don't know what happenned with the last run. It had a hiccup while sppoling up but it shows a big dip.
I'll go back sometime soon and turn up the boost a little more. I was down from what I just ran at the track.
This was just a fun random dyno for me. Josh was a little late so I jumped on the dyno. I didn't even check the oil,, LOL. Josh tuned a couple spots on teh last two runs. For the most part this is exactly how I drive teh car daily. NO PREP for thse runs. It would be like taking any daily driver and throwin git on a dyno. I do wish we had a littel more time. The guy told me Josh was up next so I could just do mine and I knew Josh would let me keep going and then get his on. Unfortunately some other guys showed up and I didn't get as many runs as Id like.
So for those who would like to see the curves
#70
very impressive Sid. I look forward to your work and I must say your hard work with these motors made my decision easy and try something simular to your 2.85l motor instead of just throwing a V8 in. Keep up the good work!
#72
Just read Sept issue of PORSCHE PANORAMA. The new Type 960 with a twin turbo V8 is going to put out over 600hp and will cost between 300,000-400,000 euros.
I think your design is a better deal, plus no import taxes
#73
Sid, what doyou estimate the build cost on one of your short blocks is?
I have tried following the build, but you are INSANE (i sued that in a complimenting way). As soon as you make a little more power, you crank it up more. You also have a pretty big turbo from my understanding.
Taking a step back, what do you estimate that your short block would do (HP) with a reasonably sized turbo? What about pump gas? This means something around 15-17psi in denver and a turbo sized for street.
#75
