Next years goal... 750 true RWHP
#106
Agreed. The single shift is a bit of an unknow but surely you can find a flat'ish enough road.
The bottom line is for me is, I can care less if your +/- 50rwhp as if you are at 700 or 750, that is a lot of HP for these engines, period! So, if you hit the strip and hit a dyno and your within 50rwhp, I would say split the difference and deal with it.
#107
You da man Sid...like the number- current and 2013 goal. Don't doubt you can get there man but traction and gearbox will be a problem I suspect. Time to get a traction bar and a chute Sid. I got to stay away from these thread as it makes me feel a little s-l-o-w.
#109
Going to the larger engine im thinking I can run similar boost levels. So I don't think so. Going to either a better flowing head and cam may create more cylinder pressure so that's a possibility.
I'm more worried about the block flexing and cylinder walking. Filling the block seems to have helped significantly. But, another 200 hp will certainly impose added stress. I am thinking about adding a time cert to the block or go oversize studs. But my main concern is the threads, not really the studs.
The reality is, I think I'm going to end up in a catch 22. Whereas I will be trading off drive ability to keep cylinder pressure down with a large hot side, big cam etc.
This keeps leading me back to just starting with the 16 valve. Too many plus sides and only a torque curve shift as a down side. Again tho that may happen anyway.
It may end up that I will need a VNT to remain happy. As I don't like Honda like torque.
#110
I should have broken a number of trans axles at this point. So far ice broken none. Traction is another issue but josh is working on a traction control circuit for me.
I am really thinking about the bar because I think the mph also dictated a full cage. The parachute is pretty stupid really but I do believe I will run 135... And boom I need it.
I want to have fun with it and not go crazy but after running this thing so much and it just seems to keep producing without effort I just had to reset my goals. If you look back at my engine thread, I have already surpassed those goals and have barely scratch the surface.
I really need a bigger angel on my shoulder because the devil keeps winning.
#112
#113
#114
I am going to build my 2.5 and 2 other engines with one of the PC members here.
Very interested in everything your doing...especially the lower cost.
Can't afford the other way a second time around at the moment.
Have a second LR stage 2 head and just need a cam tower.....My wife is a gonna kill me but well you only live once
#117
I'm thinking about that as well Tom.
I am trying to stay with a 2.5 base do it can be easily repeated by anyone. But, if I did really want to make ultimate power, I should just do a 3.4l. It's all about the Benjamin's tho.
