Rogue Tuning: DME Logger!
Old 10-25-2012, 08:16 PM
  #46
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Originally Posted by Dare
Great stuff, Josh. I have a few questions...
What's the timebase for the data when you export it? It would be great if it was UTC so you could align the data in time with data collected by other systems, e.g. to do a video overlay. I'm assuming the DME isn't keeping a real time clock. Is there an appreciable time delay between data acquisition and delivery to the computer? Does the protocol have a way to measure/compensate for that?
Also, is the protocol to the computer a trade secret? Can I make my own real-time display with a Raspberry Pi and an LCD screen?
Again, great stuff. I'm glad to see people innovating in this space.
Dare, the DME doe not have a real-time clock, so UTC isn't possible. In the logs, timing is displacement from start, with the start being zero... So you would have to manually align the data start point to match your video.
If you want to make your own display, I would be happy to help you out with the protocol info. I think that would be a cool application for R_Pi
Old 10-25-2012, 08:27 PM
  #47
Paulyy
Professional Hoon
Paulyy's Avatar
If only there was a way to get it to display on my LM-2 screen.. so i don't need to hall around a laptop for logging.
Old 11-13-2012, 05:54 PM
  #48
toddk911
Drive-by provocation guy
toddk911's Avatar
Originally Posted by Rogue_Ant
The OS needed is Windows XP or newer.
An Android application would be cool... but I have way too many things to get done before even thinking about that!
Could your system with USB not hook to display on a Tablet? Dashboard screen?
Old 11-13-2012, 06:35 PM
  #49
Paulyy
Professional Hoon
Paulyy's Avatar
If it's a PC tablet then im sure it'll work
Old 11-13-2012, 08:30 PM
  #50
Ben951S
Ben951S's Avatar
Most tablets do not have USB. small ultralite laptop would be best.
Old 11-19-2012, 06:15 AM
  #51
Rogue_Ant
Rogue_Ant's Avatar
Man, you guys can definitely keep me busy!
Just a quick note to say that I'm done with the Logger, AND the Tuner!
I updated the website, and ordering should now be available.
Old 11-19-2012, 11:02 AM
  #52
74goldtarga
74goldtarga's Avatar
Josh, it says on the website that you need the DME in association with the Tuner/Logger - do we need to send you the DME again if we already have the 28 pin conversion? Will be placing my order today - Thanks.
Old 11-19-2012, 11:26 AM
  #53
Zeff
Zeff's Avatar
Just purchased. Look at the pictures... it seems like they'll cut the casing to fit that ribbon cable.
Old 11-19-2012, 12:42 PM
  #54
refresh951
refresh951's Avatar
Just ordered the logger/tuning combo. Thanks Joshua!
Old 11-19-2012, 08:11 PM
  #55
Rogue_Ant
Rogue_Ant's Avatar
Yes, I have to do a component update - and it is something I'm only comfortable with me doing. (the risk of hurting/destroying the DME board is too high for a DIY)
Yep, that is the easy part
Awesome! It will be great to see some DME logs of your stroker motor!
Old 11-19-2012, 09:45 PM
  #56
Lethal951
Lethal951's Avatar
I will be right back... going to website to check it out.
Old 11-19-2012, 11:19 PM
  #57
Scott H
Scott H's Avatar
I'll be selling a 10" Asus Eee netbook (model 1000HE) soon, which is perfect for this application. I used it for school and it's just sat idle since I graduated, I just need to format and reload the stock OS (XP). I was going to toss it on eBay but if someone here wants it I can give you first crack.
Old 11-20-2012, 09:34 PM
  #58
Lethal951
Lethal951's Avatar
Im buying the M-Tune as soon as I can.... Maybe next month Josh.
Old 11-22-2012, 11:05 AM
  #59
toddk911
toddk911's Avatar
Does this not need to tie into the KLR at all?
Also is this a program that has to be restarted on each re start of the car like Zt2 or can it be set up to run and thus display full time when ever the car is running like the SAFC?
Old 11-24-2012, 01:39 AM
  #60
Jeff N.
Jeff N.'s Avatar
Eeek. Logger installation / wiring instructions needed! Can't find on the Rogue Tuning website...
Quick Reply: Rogue Tuning: DME Logger!
