Porsche 968 Turbo by JõuJaam
Old 11-02-2012, 04:13 AM
JouJaam
JouJaam's Avatar
Default Porsche 968 Turbo by JõuJaam
Engine
3.0 16V without variocam
Oil pan baffle kit
PO H-beam rods
OEM pistons
Piston cooling oil injectors
Raceware headstuds
Cometic headgasket
S2 cylinderhead (modified and rebuilt by Windorf)
Oilfilter relocation kit
30rib oilcooler
Custom oil lines with AN connectors by JõuJaam
Custom oil filler tank by JõuJaam
Custom oil catch tank by JõuJaam
Custom crankcase breather lines with AN connectors by JõuJaam
Holset HX40 Super turbocharger
Custom left hand engine mount by JõuJaam
Custom turbo heatshield by JõuJaam
Custom 3,5“ downpipe by JõuJaam
Custom 3“ exhaust system by JõuJaam
Tial 38mm wastegate
Modified crossoverpipe by JõuJaam
Custom 3“ aluminium intake by JõuJaam
Custom 4“ turbo inlet pipe by JõuJaam
SFS silicone hoses
Front mount intercooler
AEM 5“ airfilter
Fuelpump good for 700hp
1400cc lowZ injectors
Mallory fuel pressure regulator
Custom fuel rail by JõuJaam
Custom fuel lines with AN connectors by JõuJaam
SnowPerformance water methanol injection kit with dual solenoid upgrade
034 Motorsport coils
VEMS v3.6 engine management, tuned by JõuJaam
Custom ECU wiring by JõuJaam
Transmission and clutch
Porsche 944 Turbo S 5 speed transmission with LSD
KEP clutch pressure plate
4puck clutch disc
Clutch modified to max clamp by JõuJaam
Suspension, brakes and steering
911 turbo front calipers
968 rear calipers
Brembo discs anf Ferodo DS pads
Bilstein B6 shocks
7rib power steering oil cooler
Custom power steering oil tank by JõuJaam
Custom power steering lines with AN connectors
Body
968 Turbo style front bumper
968 Turbo style rear spoiler
Front lights delete kit by JõuJaam
Custom splitter
Battery relocated by JõuJaam
Custom front body support by JõuJaam
Custom strutbar by JõuJaam
Results
548hp 695Nm @ 1,2bar boost
292km/h @ One Mile Challange 2012
Old 11-02-2012, 05:07 AM
Thom
Thom's Avatar
Beautiful build and staggering numbers - I bet the 951 trans is too short
Apparently you initially had the oil cooler in front of the intercooler but you relocated it in front of the front right wheel, presumably because you were getting excessively high IAT numbers? Is it because of this reason that you apparently further installed a cooling fan behind the intercooler?
Old 11-02-2012, 05:15 AM
URG8RB8
URG8RB8's Avatar
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
Nice build, still pulling at 7K!
Old 11-02-2012, 05:25 AM
Paulyy
Professional Hoon
Paulyy's Avatar
Oem pistons? They're quite weak as far as I've seen.
Old 11-02-2012, 05:34 AM
numbskull
numbskull's Avatar
Wow, nice! What material is the cometic head gasket made of?
Old 11-02-2012, 05:48 AM
Duke
Duke's Avatar
Great job!
Old 11-02-2012, 07:14 AM
flipo
flipo's Avatar
Great ride ,I love it
Old 11-02-2012, 08:27 AM
333pg333
333pg333's Avatar
Not a bad first post!
So what c/r are you running and is this purely through the headgasket or did you get custom shortened rods? What fuel type? Why did you go from a 3.5" downpipe into a 3" exhaust? By 911 turbo brakes I assume you mean 996tt 6 piston or do you mean 965tt Big Reds?
Old 11-02-2012, 08:29 AM
blade7
blade7's Avatar
What I thought, dont think I got a definitive answer on here when I asked if they are cast or forged.
Old 11-02-2012, 10:28 AM
JouJaam
JouJaam's Avatar
Yes, the oil cooler was relocated to get the excessive heat away from the intercooler and radiator.
The first solution mounting the oil cooler in front of the intercooler was a test fit to see how much does it influence the intercooler cooling.
The additional cooling fan behind the intercooler was also a test to see if it helps the cooling of the intercooler.
In dyno you could feel that between the intercooler and radiator there was no airflow.
In reality the fan behind the intercooler does not affect the IAT much.
Old 11-02-2012, 10:40 AM
Duke
Duke's Avatar
The area between the intercooler and radiator must be sealed so that the air is drawn through the intercooler. That makes a big difference.
Old 11-02-2012, 11:51 AM
User 52121
User 52121's Avatar
LOVE IT! Beautiful!
Old 11-02-2012, 12:14 PM
Thom
Thom's Avatar
Yes, and this will work only if there is already some proper ducting between the inlet in the front bumper and the IC.
The pictures suggest the IC is hanging in the air with little to no ducting before and after.
Beautiful build nevertheless, I'm sure this engine shakes the Earth quite well already.
Old 11-02-2012, 12:18 PM
V2Rocket
Rainman
V2Rocket's Avatar
Holy crap...what a monster, and a beautiful one at that! Nice work. That is a big torque number, even in "proper" units
Am I reading right, 292kmh in a standing mile? 180+MPH? WOW
Now just gotta get a cover for the cam gear hole
Old 11-02-2012, 02:47 PM
reno808
reno808's Avatar
WOW
Quick Reply: Porsche 968 Turbo by JõuJaam
