Official V8 Registry.
Old 11-05-2012, 12:16 PM
xschop
xschop's Avatar
Beario from the UK will have a Toyota DOHC 948 soon....8k factory RPM
Old 11-05-2012, 12:20 PM
95ONE
95ONE's Avatar
That would be cool to see "other" types of V8's in these guys.
Old 11-05-2012, 01:16 PM
PorscheDoc
PorscheDoc's Avatar
Originally Posted by 95ONE
Nice.
Exact same motor I started with. If I blow this one, I will just supercharge the stock L33.
I figured the same thing. Start with the $600 motor, and once it is up and running, I will likely pick up another to put on the stand and start building a little more serious.
Old 11-05-2012, 02:58 PM
Howellls2
Howellls2's Avatar
1992 968 ls2, I bough the car from Mike Gokey in Florida. Unbenounced,, it needed a bunch of work. Hopefully Spring track days.
Old 11-05-2012, 03:13 PM
acorad
acorad's Avatar
Mine's an LS1.
Old 11-05-2012, 03:41 PM
aixgelo78
aixgelo78's Avatar
Im in:
88 951s
99 ls1 from a camaro
Ls6 intake
Mellings oil pump
Ls2 chain
Texas speed ms4 cam
PRC springs and retainers
Sanderson mid length headers
"4 exhaust
Red top injectors
Spec clutch and flywheel
Xschop trans mount and shifter
Xschop rx7 control arms
Manual rack
Griffin radiator
Coilovers
Weltmeister rear sway
Big red brakes
Ss brake lines
Wilwood manual brakes(I can lock up all 4 when needed)
379whp
Old 11-05-2012, 05:07 PM
supes6
supes6's Avatar
Stock 04 GTO motor, TPC headers to single 3" exhaust, manual steering, hydroboost brakes, dual headlight motors, hidden hood pins, no crossmember spacers or A/C
Old 11-05-2012, 08:50 PM
LS1Porch
LS1Porch's Avatar
Me!
I'm actually on my second--my first was destroyed in a rear-ender. My first 1987 951:
And now my second, a 1990 S2:
Specs are:
-2001 LS1, mild cam
-A0R transaxle
-Some RH kit, some homegrown
-Hydroboost brake booster
-RH headers -> 2.5" duals -> 3.5" single
-Control arms moved back up
...a million other little things...
Old 11-05-2012, 08:56 PM
PorscheDoc
PorscheDoc's Avatar
Originally Posted by robstah
Very clean setups Doc, Howell, aixgelo, and supes.
Doc, what color orange is that? Is it an official tint for Jagermeister? Looks very close to the orange I am using, which is that off of the BMW 2002 (Inka Orange).
Thanks!
From what I can tell, there were a couple different paint codes used on the jager cars. Some say signal orange, some continental, no one had a real definitive answer. I was finding jager cars that were different tints. One of them was a very flat looking orange which I didn't like, so I started looking around. Found an orange, YS019 is the dupont paint code which was a much more vibrant orange. I think it is called Kubota orange. My painter found the same tint in a different brand which was 1/4th of the cost of the dupont, so we went with that. I've got the cans sitting at the shop, I can look at what brand we used. Glad we did, as it took 2.5 gallons of paint to do the entire chassis.
I've got most of the build documented on my blog, i think you just search LSX and a bunch of posts pop up.
Old 11-05-2012, 09:13 PM
Andrewporsche
Andrewporsche's Avatar
Default here's mine
Hey all..mine is a 87 with a 02 Camaro LS1...not happy with the manual brakes..what should I go with for power brakes ?
PS: sorry for the huge picture..couldnt get it smaller..
PSS: my 86 is for sale..see my avitar
Old 11-05-2012, 10:36 PM
95ONE
95ONE's Avatar
Holy cow. That's a lot of people. Where did you all come from!?
Old 11-05-2012, 11:04 PM
Paulyy
Professional Hoon
Paulyy's Avatar
Agreed!
X-post this in the 924/944/968 section, probably get even more people.. because obviously some probably have conversions and don't come to the turbo sections for obvious reasons..
BTW nice thread, it'll give me something to brows through.
Also - should put the engine type next to their name and a short list of mods for example
paulyy - ls1, ls2 head, Comp Cam 293LR, long tube headers, Maf-less tune, 400 rwhp
like the 3L reg.
Old 11-05-2012, 11:17 PM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
and ALL happy.
Old 11-05-2012, 11:41 PM
2bridges
2bridges's Avatar
Old 11-05-2012, 11:58 PM
arthropraxis
arthropraxis's Avatar
Pics and specs? - for fun and sharing.
I need to take more pictures. The car is an 87 Turbo with a 2004 GTO engine with manual brakes and steering. I use it as my DD.
[IMG][/IMG]
Quick Reply: Official V8 Registry.
