Wossner pistons/Alusil compatiblity?
What about 104.5mm? Heritage in FL has some supposedly in stock, but there is no price listed.
http://www.heritagemotorcar.com/research/index.htm Under Engine Components
Paul.
IIRC, Heritage sells for 16 valve. Shameless plug for anyone who wants 104.5 8 valve here.
Wossner are good, like a European JE. I used a set of them coated for Alusil and they seem to be holding up. If I had the choice, I would go Mahle. They are light years nicer. Lighter and you can get some great options. The slipper skirt, box on box is the best design out there. Custom pin options and coating options make them the best.
Mahle:
Wossner
And yes, they have alusil coatings so that you can run them in your alusil bores. The great thing about Wossner, is they will not only do whatever you want, but it is no increase in price. They also will make you one set, and not want 50 sets made in a batch.
Mahle:
FWIW the Mahles in the photo are a little different then what I have.
I cannot comment on the Wossners except to what is posted on the board which AFAIK is all positive. Distinguishable difference is that Mahle is OEM. Does anyone else know if Mahle continues to be the OEM choice for all Porsches built?
It's been run through a number of times - keep it Alusil vs. sleeving vs. plating with Nikasil or NiCom. Everyone has their ideas, preferences, budgets etc. Think there has been success with all and debatable pros and cons here and there.
Although there are many ways, my choice sticking with Alusil & Mahle, all things considered - good build and tune is not a wrong.
Darwin,
Almost all piston companies will send you drawings before they make them. Once you approve them, they make them. This is how they keep you from saying "thats not what I wanted" when they show up.
Mahle uses the newest box or box slipper skirt style which is much better than the old mahle/Andial style and they come with many coatings.
Here is a pic of I few I made...
I'm inclined to agree and If my project block is in size I'll go with coated pistons, I just wonder if Mahle's pricing is linked to Porsche in some way or stems from when they had the 104mm Alusil market to themselves.
On integral parts I have never minded paying the OEM standard of price for the reassurance of what you get. Not at all suggesting that Wossner aren't up to the task because they're cheaper as it appears quite the contrary. But if I want to save money, I look elsewhere to do it. Problem is much of the time elsewhere seems to be an elusive apparition.
I'm not unhappy that I paid for Mahle, and I doubt you'll find anyone else to say differently.
http://www.mahle.com/MAHLE/en/Produc...soline-engines
<For the application in aluminum cylinder surfaces, MAHLE uses the iron particle reinforced synthetic resin coating FERROPRINT®. MAHLE's new FerroTec® galvanic iron layer is another ongoing development available on the market. The FerroTec® technology coats the entire skirt evenly, resulting in improved running properties. These coatings are necessary to enable the combination of aluminum pistons with pure aluminum engine blocks and hence represent an essential contribution to an overall reduction in engine weight.>
