Wossner pistons/Alusil compatiblity?
Old 11-25-2012, 12:41 PM
  #31
blade7
blade7's Avatar
Interesting Mahle describe the blocks as "pure aluminum" ?.
Old 11-25-2012, 01:19 PM
  #32
Thom
Thom's Avatar
Mahle moved from Ferrostan to Ferroprint for environmental reasons, but Ferrostan remains "better". There are still a very few places that can supply Mahle pistons with Ferrostan.
Old 11-25-2012, 02:39 PM
  #33
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
I have used quite a few sets of Wossners (and JEs, Mahle and others).
Why do I like Wossners? From a technical stand point they are ‘equal’ to the others. The ausil coatings have been accepted by several manufactures such as BMW and Wossner supplies some pistons to Porsche motorsports.
The forgings and alloys are good, no one really has any advantage in that department.
The main thing is that Wossner will make anything you want in low production numbers (as in one set, even one piston if you really want)
If you want a 106.5mm 16v piston in a 9.5:1 compression ratio with low tension rings and DLC coated wrist pins in a non-stock location they will make it.
I suppose the down side is that you are responsible for specing out all the custom design information and you have to review the drawings before production. That’s great stuff if you know what you want and dangerous stuff if you don’t!
From my direct experience JE could not care less for the 944 market. They sell 10,000 chevy pistons for every 944 set. Mahle is getting better but they used to wait until demand grew (and price) and then run a bunch of sets and sell them at higher pricing. I would rather work with a company that appreciated my business and will fabricate the design that I would want.
Old 11-25-2012, 03:25 PM
  #34
blade7
blade7's Avatar
If I wanted a set of Alusil compatible 104.5mm, 8v pistons to use with a 3.0 crank, that made 8-1 comp when used with a 2.7 head do Wossner have a part number, and can I order these direct from Germany ?.
Old 11-25-2012, 07:47 PM
  #35
lejams
lejams's Avatar
This is the primary reason why I picked up the Mahle's off the shelf.
When I bought these, I recall you were just beginning to explore the Wossner's. They really hadn't been proven in the 951 at that time except by a few.
If I were starting a fresh build today with you or another qualified builder, it's very likely I would want to use them.
Old 11-25-2012, 10:31 PM
  #36
evil 944t
evil 944t's Avatar
Mahle's can be had in 3-4 weeks. They do not make you "wait" until production numbers come up or anything such. They will make you 1 piston or 100 sets, the lead time is the same. They will even expedite them should you want to pay a little extra.
Quality equal?, not even close. Or I should say, not unless they changed over the years! The last set I saw had a very thick, crappy looking coating on it. I wanted to measure the piston and couldn't get an accurate reading. I was told to "trust" that the coating was fine. That being said, the piston did work fine but, that is not the type of company I want to work with. Hopefully things have changed..
Old 11-26-2012, 03:34 PM
  #37
blade7
blade7's Avatar
Heritage have let me know the price for their Mahle pistons, $2200 .
Old 11-26-2012, 07:41 PM
  #38
lejams
lejams's Avatar
If you want Mahle, see what a good deal mine are
Old 11-26-2012, 09:02 PM
  #39
blade7
blade7's Avatar
Yes, $170 less than Andial .
Old 11-26-2012, 09:58 PM
  #40
Fluidplay
Fluidplay's Avatar
Wow! confirms my chioce of Wossners, though Mahles can be found for less...that's high.
Old 11-28-2012, 03:20 PM
  #41
blade7
blade7's Avatar
Neither Wossner or Mahle seem to reply to questions via their websites.
Old 11-29-2012, 01:14 PM
  #42
Duke
Duke's Avatar
I used Wössners in my 3.0l 16v turbo engine. Worked fine! (Until a bearing went south and a rod broke )
Old 11-29-2012, 04:00 PM
  #43
blade7
blade7's Avatar
I mailed Wossner in Germany a few days ago and I've heard nothing back. Contacted a Wossner dealer here in the UK and he wants 30% more than US suppliers and when I told him the spec he went quiet. A US supplier of Mahle pistons told me Wossners wont last. Someone posted up a turbo 968 on here running original pistons and everyone said how marvelous it was.
Where did you buy your pistons from Duke ?.
Old 11-29-2012, 04:32 PM
  #44
Thom
Thom's Avatar
... Revline Racing? (!)
Old 11-29-2012, 06:30 PM
  #45
Darwantae951
Darwantae951's Avatar
Completely unbiased statement right there...
Quick Reply: Wossner pistons/Alusil compatiblity?
