Wossner pistons/Alusil compatiblity?
Old 11-17-2012, 08:15 PM
Fluidplay
Fluidplay's Avatar
Default Wossner pistons/Alusil compatiblity?
Well... I'm having no luck finding a used set of 100.5 Mahle pistons, so I'm considering the next best thing (I hope). Cost & availability is dicatating this direction...Is anyone using Wossners without Nikasil coating? From what I've found/read it sounds as if they have a coating compatible with our Alusil bores.
Old 11-17-2012, 08:23 PM
p5th
p5th's Avatar
I would contact Chris White. I'm sure he can answer all your questions.
Old 11-17-2012, 08:36 PM
Oddjob
Oddjob's Avatar
What does Karl P. say?
Old 11-17-2012, 09:10 PM
Fluidplay
Fluidplay's Avatar
I read Chris's remarks dated last October in this post "Mahle, Arias, Woessner or JE pistons best? regarding Wossner's compatibility, just wanted to hear if Wossners were becoming the norm and whether more rebuilds are being done using Wossners, since getting pistons from Mahle is getting more difficult and they're cost.
Old 11-17-2012, 11:28 PM
kev951
kev951's Avatar
Totally compatible , just make sure u specify when ordering. Had mine made to order from Germany. Have all your specs ready , like desired compression ratio , turbo or na, head gasket thickness , combustion chamber volumes .. Etc.
Old 11-17-2012, 11:38 PM
Paulyy
Professional Hoon
Paulyy's Avatar
Pm sent
Old 11-18-2012, 07:57 AM
blade7
blade7's Avatar
I'm seriously considering Wossner pistons and rods for a 3.0 Alusil build, I dont see 104mm pistons on their website though, anyone know if they are special order ?.
Old 11-18-2012, 11:16 AM
PF
PF's Avatar
Default Mahle
Hi.
Lindsey racing have 100,5 pistons from Mahle motorsport in stock for the alusil block. Price 1325:-
I think that is good value and I think Mahle is hard to beat.
Regards
Peder
Old 11-18-2012, 01:37 PM
blade7
blade7's Avatar
Originally Posted by peed
Hi.
Regards
Peder
104mm Mahle pistons were quite a lot more when asked Andial adding import duty ruled them out for me.
Old 11-18-2012, 01:54 PM
PF
PF's Avatar
Well 104 pistons from Mahle Might be harder/more expensive as you say. A friend of mine (Swedens most famous 944 expert) uses wössner on his 3l builds. They are 1000 us at Lindsey, ofcourse plus ship/customs for us in europe.
But when it comes to 100,5 which was what he is looking for I'd go Mahle.
/Peder
Old 11-18-2012, 02:39 PM
blade7
blade7's Avatar
I thought Wossner were based in Germany.
Old 11-18-2012, 02:59 PM
evil 944t
evil 944t's Avatar
Wossner are good, like a European JE. I used a set of them coated for Alusil and they seem to be holding up. If I had the choice, I would go Mahle. They are light years nicer. Lighter and you can get some great options. The slipper skirt, box on box is the best design out there. Custom pin options and coating options make them the best.
Old 11-18-2012, 04:03 PM
PF
PF's Avatar
They are but in a strange way it is cheaper to get them from the US!
I am about to rebuild my 89 turbo cup car this winter and most of the parts I got from the US even if most of it is made elsewere...
Good luck!
/Peder
Old 11-18-2012, 04:17 PM
Scott H
Scott H's Avatar
What about 104.5mm? Heritage in FL has some supposedly in stock, but there is no price listed.
http://www.heritagemotorcar.com/research/index.htm Under Engine Components
Old 11-18-2012, 05:39 PM
blade7
blade7's Avatar
I expect to pay up to $1000 for the pistons complete, what hacks me off is paying 23% UK import duty/tax, I thought I would avoid the tax with Wossner. Makes me wonder about machined 968 pistons again.
Quick Reply: Wossner pistons/Alusil compatiblity?
