Side exit exhaust?
Old 12-21-2012, 04:37 PM
Dougs951
Dougs951's Avatar
Default Side exit exhaust?
Anyone done it?
I picked up some 3" oval tubing, its giving me bad ideas about a in front of the drivers door side exit exhaust.
Old 12-21-2012, 06:16 PM
vette951s
vette951s's Avatar
Default Side Exhaust
Here you go! Pipe shown has a SuperTrapp end on it and can be used to install a "Laguna Seca" muffler for sound restrictions. Fender has some "modifications".
Good Luck! John
Old 12-21-2012, 06:18 PM
eman930
eman930's Avatar
thats sick!
Old 12-21-2012, 06:37 PM
JustinL
JustinL's Avatar
My friend Mike in silicon valley did a really great job of a side exit that comes through the rocker panel. I'll hassle him to post up some pics.
Old 12-21-2012, 06:40 PM
333pg333
333pg333's Avatar
Yep, post up pics guys. Looking at ideas.
Old 12-21-2012, 06:42 PM
333pg333
333pg333's Avatar
Ps that pic looks very close to tyres and brakes re heat dissipation.
Old 12-21-2012, 06:44 PM
odb812
odb812's Avatar
Lorax did it on his pearl white car. He posted pictures up here.
Old 12-21-2012, 06:50 PM
Dougs951
Dougs951's Avatar
Did some mocking up and it looks pretty simple. Waiting on some vbands to go any further.
Old 12-21-2012, 08:22 PM
LS1Porch
LS1Porch's Avatar
I can't even fit a jack between the floor and my car, where are you planning on squeezing it out?
If you're going to do it i would send it through a panel. Also, you'll have to do something to the backend to make up for the big hole you're leaving open.
Old 12-21-2012, 08:32 PM
Dougs951
Dougs951's Avatar
Right in front of the jacking point
Old 12-21-2012, 08:33 PM
catamax944
catamax944's Avatar
I will probably be doing something like this next summer to my n/a
I plan on widening the spare wheel well towards the muffler side in order to fit a 50 liter cylindrical lpg tank and i will route the exhaust to exit in front of the rear wheels on both sides.
This mod kills 3 birds with one stone
-looks cool
-the tips will be easily removable and the holes in the rocker placed in such a way to have access to the torsion bars
-it will eliminate exhaust gasses coming through the window when it's open because of the 944's aerodynamics
Old 12-21-2012, 10:00 PM
Weston Dillard
Weston Dillard's Avatar
She isn't pretty, but this mod saved 25 LBS of exhaust and has worked really well. I moved the catch can, and heat doesn't seem to be a problem. I modified a stock downpipe and added a piece of an old downpipe off my buddy's Suburban. Total cost: $5 in welding rod.
West
Name:  Renault exhaust.jpg
Name:  Renault exhaust 2.jpg
Old 12-21-2012, 11:40 PM
944meister
944meister's Avatar
i have crawled underneath my car before and contimplated a side exit exhaust, this is my initial idea. i would surround the exhaust exit with thin titanium plate for its low thermal conductivity, this should eliminate burning up the paint in the heat affected zone. this is a practical area to exit if you still want to keep the exhaust tightly packed under the car, while still being able to utilize a cat and muffler. you still would need to create a divider between the exhaust wheel well area, in order to protect the rear tire.
Old 12-22-2012, 12:11 AM
Weston Dillard
No idea whose this is, but looks like what you want.
West
Name:  Side exhaust.jpg
Old 12-22-2012, 07:18 AM
333pg333
333pg333's Avatar
That looks more like it West.
I've always been partial to this pic as far as location and installation.
Quick Reply: Side exit exhaust?
