AOS connections
AOS connections
I am a little confused about the AOS vacuum connections and would like some clarification. Starting from the top of the AOS:
1. I understand the connection at the top is for pulling vacuum (especially under boost/high air velocity) and it connectors to the J-boot or turbo inlet pipe before the compressor.
2. What does the hose that comes from the side of the AOS connect to Is that connecting to the crankcase from where pressure is relieved?
3. What is the top o-ring connected to? Is this connected to the crankcase?
4. What is the bottom o-ring connected to? I assume this is where oil drains into the pan when filling. Again another crankcase connection?
2. goes to the engine mount to create vacuum at the turbo outlet to help pull the oil going through it. This type of vacuum line is necessary on any engine where the turbo oil return line ends below the oil level in the sump, which is the case on the 944T engine.
3. Yes
4. Yes
3. Yes
4. Yes
3. Yes
4. Yes
3. Yes
4. Yes
Picture of the turbo vent (pardon the mess) Attachment 1365705
The later cars had a little valve in the hose coming out of the top to vent excess pressure when the recirc valve dumps pressure into the J-boot.
Thanks for all the posts and pictures. It appears it is a very simple crankcase ventilation system that goes to the turbo inlet. There is no vacuum in the AOS especially at low throttle so I am not so sure where idea about it pulling oil to drain the turbo comes from.
Another question - has anyone considered running a PCV valve to the intake manifold on this car? It might help with low load crankcase ventilation and oil consumption.
Check this thread. Should give you all the answers you need.
Generally you want as little pressure drop in front of the turbo as possible for performance in order to reduce the operating compressor ratio. The bigger the intake the better but this then seems to require a PCV system.
I am curious if those that ran a PCV valve they noticed a reduction in oil consumption at all due to the higher crankcase vacuum.
Pretty sure Porsche wants you to pay $Alot for a new one complete with the metal line, if they still even make them. Lindsey Racing sells the silicone replacement that's picture. https://www.lindseyracing.com/LR/Porsche/LRA-TDVH.html
