just dyno'ed my 89 951
#61
Small Business Partner
Glad to hear your getting the car sorted... Another way of thinking about it - every boost leak is an energy leak, it is your best interest to eliminate all boost leaks possible.
#62
Yeah that diverter valve leak was messing up with my spool time and boost
I think my last dino while still having welt chips had same boost leak, o well i hoping to see some big numbers next time im hitting dyno
#63
Dont mind the 2nd and 3rd run afr ratio, exhaust came of. im not impressed with the numbers tho, gonna need to check my injector flow, and i have no idea why numbers are low like this, dyno was a mustang btw they say it always reads a llitle bit lower than other dyno
And here is my old dyno run with welt chips
#64
One intresting note first run they did they hadnt turned on 4wd dyno only my back wheels were spining so result was 450whp after that they did 3 runs where my front and back wheels were turning
#67
Hmm...that sounds weird. If your rear wheels are in effect driving the front ones you'd be suffering a heap of parasitic loss. Also, from what I can see, your car registered about 240whp. Where is the 450whp?
#71
They didnt save that run because it was so inaccurate.. im giving up on runing rich solution.. i hope injector flow matching and cleaning will help even out the jaggedeness in power and torque
#75
I agree. OP, your AFR going very rich at the same point on the graph where you're hitting full boost is a pretty good sign of a boost leak.
To touch on a more basic point, you are going to spend a ton of money getting your car in order the way you are approaching it now. Unless it's free, hold off on the dyno time until you know you've sorted out all of your issues. Pick up a wideband O2 sensor and aftermarket boost gauge if you haven't already and spend some time on here reading about how to use them. Then proceed with the dyno runs and go fast stuff after you see the car is running properly.
