bolt-on rebuilt turbocharger recommendations for a semi-stock '88S
Old 11-08-2013, 12:11 PM
MarkRobinson
MarkRobinson's Avatar
Default bolt-on rebuilt turbocharger recommendations for a semi-stock '88S
Rebuilding an engine, have the opportunity to replace the worn/out-of-spec factory turbo with a better, faster-spooling unit...so what do people recommend?
I have a line on a rebuilt factory '89 turbo or can send this in as a core (the 200k turbo) for a modded unit, or can pitch it altogether and go aftermarket. Recommendations??
Mark
Old 11-08-2013, 12:17 PM
eman930
eman930's Avatar
send it out, get a 27/8 built with a 7200 wheel, have it clipped and weight reduced for quicker spool.. cost is about $750 at evergreen turbos... you have to supply the parts... but its a bolt on upgrade that can put you in the 320hp range
Old 11-08-2013, 12:18 PM
MarkRobinson
so where do you obtain a 7200 (K27 I assume) compressor wheel?
Old 11-08-2013, 12:21 PM
eman930
eman930's Avatar
youd have to find one on E-bay or someone here selling, I believe the 911 turbos are k27 but im not sure what year/models... im still learning too because Im looking to upgrade to a K27/8 myself.. currently I have the 26/8, but I e-mailed evergreen turbos and thats what he told me the best option was
Old 11-08-2013, 12:24 PM
67King
67King's Avatar
I have one of these, new in the bag still, from Evergreen. I may let it go. Actually, the impeller is a Holset, will be good for ~350 with the AFM, Charlie thinks 400 with a MAF and supporting system. Reason I'd sell is I was thinking of a 2.5L 16V, but I have now collected what I need for a 3.0L 16V.
Old 11-08-2013, 12:26 PM
MarkRobinson
the '91-94 911 turbos (both 3.3 and 3.6 have the K27-2700 wheels in them. What are you asking for the wheel??
Mark
Old 11-08-2013, 12:36 PM
eman930
eman930's Avatar
pm sent
Old 11-08-2013, 12:40 PM
eman930
eman930's Avatar
Mark
ill have to google it and search beacuse I may have it backwards... 7200/2700 LOL... but im not sure.. i know you want one or the other
Old 11-08-2013, 12:42 PM
MarkRobinson
i mistyped: it's 7200
Old 11-08-2013, 12:49 PM
eman930
eman930's Avatar
There's a K27/6 on eBay for $450... It will still do the job, a little quicker spool.. Perfect for a street car
http://bit.ly/HN8iG6
Sorry link won't work from my iPhone... But search eBay use K27 as keyword
Old 11-08-2013, 03:18 PM
will951
will951's Avatar
I bought a used K26/6 and sent it to Evergreen for rebuild/retro-fit to a K27 & trimmed fins for quicker spool.
If you are interested in doing something similar I have my old K26/6 for sale here:
https://rennlist.com/forums/for-sale...s-k26-6-a.html
Old 11-08-2013, 06:32 PM
eman930
eman930's Avatar
Will, I think you should remove you k27/6, sell it to me and buy a even bigger turbo for your beast
Old 11-08-2013, 06:33 PM
MarkRobinson
I have both a rebuilt and an old K26/8 to use...just gotta figure out what I wanna try :/
Old 11-08-2013, 06:41 PM
eman930
eman930's Avatar
Ive been in Will's 951 that has a k27/6 in it and it pulls like a monster, seems to spool about the same as the factory unit too just puts out alot more. its a nice setup.
Id imagine if you had to compair a K27/6 to a K27/8, the biggest differences will be that the k27/6 spools about 300-500rpm sooner but the K27/8 will hold peak boost longer. SO its really all about what your using the car for.
Old 11-08-2013, 06:46 PM
doabarrelroll
doabarrelroll's Avatar
I've got a k26/8 with the k27 wheel. Supposedly it helps the spool a bit. The shop I took it to did it for free because they didn't balance it properly the first time they did the rebuild!
Quick Reply: bolt-on rebuilt turbocharger recommendations for a semi-stock '88S
